Question about Canon EOS 40D Digital Camera
Code 99 I am able to shoot an image, it is recorded, then I get a code 99. I recycle the power off, I can shoot another single, then I get the code 99 again. Any quick things I might check before I ship it off for repairs? I tried different batteries, checked the voltage on the 3V battery, it's OK, removed & reseated the lens after checking contacts. Thanks
bmwrider
  • 215 Answers
SOURCE: Canon A75 won't power on
The only advice I can give is to check for a fusible link close to where the battery cables connect to the PCB. Look for a component with an F prefix eg f1001 or f001. I never desolder the fuse if it's open circuit, I just break a glass type fuse and solder the wire across the surface mount component. Just make sure the fuse wire is the same value as the original.
Posted on Jul 12, 2006
poolseman
  • 206 Answers
SOURCE: Canon error code 99
Your camera performs a quick 'integrity' check before each shot and goes into error 99 mode if the lens in incompatible or has a diaphragm problem. ( it will also display e99 if the shutter or flash unit is not ok but this does not apply here ). This is how you can check whether the diaphragm mechanism is ok : attach lens to your old camera and set camera to AV and set F stop to 16 . open back and release shutter and look through the back to see if your lens is closing to F 16. If it is closing fine then the lens is ok but is not compatible with your D400.
Posted on Sep 10, 2007
SOURCE: Error 99 only when flash pops up
We ended up sending the camera in to Canon. $200 unless they find something more wrong. Luckily we have my Nikon D80 still. I will say that Canon replied via e-mail fairly quickly and one paid, said 7-10 business days for the repair.
Posted on Dec 09, 2007
  • 17 Answers
SOURCE: Error 99 Code on 5 month old Canon 40D
error 99 can be several things. Try the following. Check that the contacts on the lens housing are clean if not clean them with a swab of denatured alcohol available at walmart. also if there is extremely cold weather your shutter could be creating the error. Try using a blow dryer and on the warm setting warm up the camera with the lens off. Blow around the mirror area. I know it sounds silly but it has worked in the past. Good luck.
Posted on Feb 20, 2008
  • 10865 Answers
SOURCE: Canon 40d-pressing the shutter seems to short out the camera.
I recommend that you remove both batteries for ten minutes to get a full reset. you spoke of the main battery. When you open the battery compartment, look at the lower right toward the camera with the LCD facing you.
It is a little hard to see, but will say CR2016 3V. Stick your fingernail under the lip and just pull it out.
As I said I left both batteries out for about 10 minutes.
You will have to re-set the date and time after your done.
Posted on Oct 16, 2009
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
Error 99 and jerky fixation of focus between 17 and approxinately 30 mm works perfectly at zoom lengths beyond this with normal rapid fix of focus and records image normally. the error and failure to...
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
For the jerky focusing ring, you need to get the lens serviced by an authorized service center.
Aug 28, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Nikon D80 Camera
During shooting, or when the shutter-release button is pressed halfway, the number of images that can be stored in the memory buffer at current settings is shown on the exposure-count displays in the control panel and viewfinder. "r06" indicates that six images can fit in the camera's buffer, "r08" would indicate eight frames. Any other number could be displayed as well. Burst mode is used when you want to hold down the shutter button and continuously shoot. You are probably shooting in burst mode and your buffer is full, set the camera to single shot and see if that helps.
Jul 02, 2008 | Nikon D80 Digital Camera with 18-135mm...
Sb-600 not beeping, images completely black (underexposed)
Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
Apr 04, 2017 | Nikon Speedlight SB-600 TTL Flash
PANASONIC DVD RECORDER DMR EZ27
I had the same problem with my first unit, took it back they had to unscrew it all to get me back my DVD. They gave me a new machine. Checked it out seems it's a Auto Tuning problem, i went into the menu and restricted the auto tuning, problem is now, every time i switch it on it wants to update the tuning!! Pain in the ass. Contemplating taking it back again. Panasonic said it must be a one off, they hadn't had any other complaints!! Yeah right.
Nov 27, 2007 | Panasonic DMREZ27 DVD Recorder
No image
No image in shooting mode on Canon S500. Flash operates and shutter clicks. Whats wrong?
Nov 12, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Cannot set "HI" Mode to shoot TIFF Images
In order to shoot "HI" TIFF images first set the Image Size option to either "5M 2592x1944" or "3:2 2592x1728." Next, choose "HI" as the Image Quality option. "HI" is only available in one of the manual exposure modes (P, S, A or M) and is not available in the "Auto" shooting mode. If "HI" is selected and the camera is switched to "Auto" the Image Quality will automatically switch to "FINE" mode and a JPEG image will be recorded. Additionally, "HI" is only available in "S" Single frame Continuous shooting.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Canon EOS 40D Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
