Each time I power the camera on to take photos I need to reset the time and date. Is there an internal battery that is malfunctioning? Any other ideas that may be causing this? Thanks
Yes,more than likely there is a little button cell battery that powers the date and time.You'll have to look in your manual to find its location.I just discovered my battery is dead.Yep i checked the manual even tho i already knew where to find it.Took some reading to find but it was there in the manal.Its located in the battery compartment on my canon A720IS.Mine takes a CR 1220 - 3Volt.I'm still trying to find a replacement.Guess i'll have to go to a camera store to get the battery.Couldn't find at any of the usall places.Hope this helps someone,Gary Malcontent
i have the canon a720IS and was having similar problem with my date/time. once i discovered the small cr1220 battery next to the regular battery compartment, i replaced it but the problem still was there.
i looked closely at the cr1220 compartment and took a toothpick and just pulled the metal prongs out a bit, so that they were in better contact with the cr1220 battery. ever since then i've had no problems.
how do we show video that has been recorded already
cannon powershot sd870 is.
which buttons do...
(More)
which buttons do we push to see the video?
when I take a shot close up the image is blurred. It seems to take a few seconds for the shot to be...
(More)
when I take a shot close up the image is blurred. It seems to take a few seconds for the shot to be taken after I have pressed the shutter button??
I have a Canon SD870. I am getting replace battery with a fully charged battery. I have tried 2...
(More)
I have a Canon SD870. I am getting replace battery with a fully charged battery. I have tried 2 batteries. What could be the problem?
My camera will no longer take a picture when a flash is needed. We can take pictures without flash,...
(More)
My camera will no longer take a picture when a flash is needed. We can take pictures without flash, but they may be blurry or dark. It almost seems as though the flash might be broken or it's a dead bulb.
Canon 870 when taking pictures outside they look fine in the lcd screen prior to shot then after...
(More)
Canon 870 when taking pictures outside they look fine in the lcd screen prior to shot then after shot taken a bright light appears almost whiting out the whole picture
