Question about Bernina Sewing Machines
How do you oil a Bernina 1030 Sewing Machine?
SOURCE: Needle won't move on Bernina 930
If the machines motor is running but the needle isn't going up and down then the baste stitch finger is gummed up and needs to be serviced.  This is a simple fix and it happens all the time on those machines.  Take it to your local Bernina dealer for a standard service.  Also if you really need it in a pinch try pushing up on the needle bar that sometimes will fix the problem but it will still need serviced.
Posted on Oct 22, 2007
  • 619 Answers
SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
Posted on Feb 22, 2008
Mimito7
  • 128 Answers
SOURCE: user manual download bernina activa 140 sewing machine
Try this... www.2instructions.com
Posted on Apr 30, 2009
RickE1
  • 202 Answers
SOURCE: I have bernina sport 801 machine and need to know
You can oil any two metal parts that move togeather or through each other. Do not oil bearings and do not oil gears. Do not use 3 in 1 oil or WD-40. Use regular sewing machine oil.
801's were made from 1979 - 1982. The way Bernina dated these on the machine is by the serial number. Your number would probably start with a 0 or a 1. 1970 is a 0, 1971 is 01, 1980 is 1, 1981 is 11, 1990 is 2, 1991 is 21 etc. etc.
Rick
Posted on Oct 08, 2009
SOURCE: Bernina Bernette 65 sewing machine
I had the same problem. I'm a novice sewer. I just bought my machine. It did the samething, tension didn't work, the thread kept knotting up underneath, and the fabric kept curling up in the back.
I adjusted the tension knobs to no avail. Then it kept bothering me that it was curling up. I then decided to set the dials back to where the factory had them and adjusted the presser foot just a hair counterclockwise and I haven't had anymore problems.
The other day the needle almost broke because the tension was tight on the thread. You have to make sure that the needle is at it's highest point to get it to release the fabric so you have a thread tail.
This is my first purchased machine. I had a New Home years ago that was given to me, however it blew away in the tornado of 1991 in Kansas and I never replaced it. I really do love this machine. I don't believe I will ever want another.
Posted on Nov 11, 2009
The selector lever doesnt work on my bernina 1030 it will only sew straight and ziz zag stitch can it be fixed
Yes, most likely the mechanics are seized due to old oil that has dried. I have a 930 that I frequently clean & lube thoroughly to keep it running smoothly. The only thing is to stay away from the basting stitch mechanism (sorry, can't remember if your machine has it) located in the middle of the needlebar directly behind the take-up lever. Once you give your machine a good lube, you'll be amazed at how quietly and smoothly it runs.
Wheel on right side that controls the needle up and down is very tight...
Here's a Service Manual for your machine:
https://www.manualslib.com/manual/1059902/Bernina-1030.html#manual
Only a caveat, but is generally recommended to NOT use compressed air to clean sewing machines. Frequently, it pushes the lint and dust further into the machine so a technician will have to clean it.
Nov 02, 2017 | Bernina Sewing Machines
Bernina 1030 the teeth will not stay up and cannot feed material through
You should probably take it to Bernina for service. It could just be a matter of adjustment or tightening a screw. On the other hand, a general cleaning, oiling, and adjustment will probably run around $100-$125 which would be beneficial if it hasn't been done in a while.
Jul 23, 2017 | Bernina Sewing Machines
My bernina sewing machine dealer has gone out of business. I need a source of oil for my Bernina 780 and clip for the stitch plate for my 630.
any sewing machine oil will do the job
parts can be obtained from the bernina spares on their web page , and from most sewing machine repair shops on order
Jul 01, 2017 | Bernina Sewing Machines
Instruction Manual for Bernina 801 - need instructions for oiling the Bernina 801
Hi Jim&Bev, The link below in a 23 page user manual for a Bernina 801 Sewing Machine, I hope this helps.......CHEERS..
Bernina 801 Owner Manual
Apr 16, 2016 | Bernina Sewing Machines
Board bernina 1030
As you will have noticed, you cannot open the end of a Bernina 1030.
There are two light bulbs on this machine, visible on either side of the needle bar and presser foot shaft. Viewed from the rear of the machine, you can see the one on the right but the one on the left is beneath a transparent plastic cover that slides out easily (but does not come right out).
To remove either of the bulbs, which are a bayonet fit, open the accessories box attached to the rear of the machine and take out the screwdriver tool from the top row, on the left hand side by the bobbin storage. One end of the screwdriver is a screwdriver (!) and the other end has a plastic tube - this is designed to grip the bulb.
Place the plastic tube on the end of the bulb, push a little and rotate anti-clockwise about a quarter of a turn to release the bulb.
The bulbs are both 6 Volts, 4 Watts. board-bernina-1030-yfctketow5dlawzorpkxttl4-1-10.jpg
Jun 29, 2014 | Brother SE350 Mechanical Sewing Machine
Bernina 1030 needle not moving up or down
I believe the 1030 has a basting stitch, similar to the 930 Record. If the basting stitch is not run regularly, it may lock up the machine requiring a technician's expertise to get it working again.
Mar 31, 2013 | Bernina 1008
I have a 1030 Bernina sewing machine and for the first time in 10 years the needle will not move up and down. It will go side to side. It stopped while sewing and won't restart. I have checked all of the...
Take it to your Bernina dealer, they should be able to determine what is wrong and hopefully fix it, free. You really do not want to do something that could void your warranty. My Bernina dealer is super nice and always helpful, they are very professional. I hope that it is just some silly thing, like mine was.
Apr 03, 2011 | Sewing Machines
Foot pedal not working on bernina 1030 but there is power to the machine (the light comes on)
The problem with you bernina is coming from the circuit board located on the back of the machine, there ar e a couple of fuses you might want to replace, if you change out the fuses and still no power the board will need to rebuilt aprox cost$150.00
Apr 21, 2010 | Bernina Sewing Machines
Sewing Machines Logo
336 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
