Question about Intertherm Heating & Cooling
I have a Intertherm heating and air conditioner it is a Manufactured Home. The furnace model number is E2EB-017HA. When you flip the switch to heat and move the control arm up nothing happens. You can go all the way to the top and still nothing. Now if you flip the switch to on it will come on. Or if you flip it to cool and move the control arm down it will click and come on I am not sure what to do. Jerry
    President:
  • 1,015 Answers
When you turn the on/off switch to on you are turning on the "fan switch" and the blower motor is only coming on. When you turn the switch to cool and move the tempature control lever down you are turning on the air conditioner...So it sounds like your heater is not working. Is the heater electronic ignition or does it have a pilot? If it has a pilot the heater may not be working because the pilot is out and will need to be lit. If it is electronic ignition you will need to inspect the unit to determine what component is faulty. Could be the igniter,gas control valve,ect. Verify that gas is not shut off to unit at line valve and gas control valve on unit.
Posted on Oct 07, 2009
I have a intertherm model e2eb-017ha the blower wont shut off i have to turn the braker off
One The blower relay is stuck in the on position. Two at the thermostat, fan switch should be set to auto. Set it on the blower wont quit.
Jan 29, 2014 | Intertherm Heating & Cooling
I have a E2EB-017HA air handler and I want to change it to a variable speed motor. Is this possible
Some companies do sell a variable speed kit. It includes the motor and controls. Get your model and serial number of your unit and contact your local Payne dealer. The can locate the proper kit if available for you.
Feb 03, 2013 | Intertherm E3EB-017H Furnace 17Kw 2
E2EB-017HA HOW TO SLOW SPEED DOWN ON BLOWER
Go to the blower motor find 3 wires.Black is high,blue is med, red is slow. Find what wire is on blower relay. then adjust to what you what. hope this helps.
Aug 21, 2011 | Intertherm P3RA-048K Air Conditioner
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
Condensation leaking out of unit
if it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
May 16, 2009 | Intertherm P3RA-048K Air Conditioner
Blower will not come on
could be the fan relay is bad. or the run capacitor. if these check good. you may have a bad heat sequencer. hard to tell, if you thave a/c you can turn thermostat fan swith to on and if blower comes on then relay and capacitor should be ok. some units have two or three heat sequencers 1 controls fan and the others control heat strips hopefully this helps good luck
Jan 04, 2009 | Kitchen Appliances - Others
I NEED THE WIRING DIAGRAM FOR A NORDYNE MODEL #E2EB-017HA
contact nordyne local dealer and they should be able to get on for you. otherwise go to google and search for factor and e-mail them for 1.
Dec 11, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
210 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
