Question about Whirlpool RBS305PDS Electric Single Oven
Whirlpool Accubake won't turn off
If finishes running the timer but stays on no big deal hit off keeps running in fact no matter what I press cancel off it keeps running.
Then I press bake and cancel at same time get E0 F0 but finally the piece of **** turns off. I am no house hold electronics expert but off should turn it off pressing combinations of button until you get the desired results seems like a problem. Once it finally turns off it beeps at me every 2 minutes reminding what a piece it is after a few hours you can hit cancel and it resets but I dont know what the right time period because if you hit it too soon the piece turns right back on. Is this a problem with the stove or where the controls just not that intuitive?
SOURCE: whirlpool accubake oven problem
I had the same problem and followed the process listed above....yes, I did unplug/turn off the circuit and am alive to share this update! Right off I noticed that the ribbon cable was loose. For those who have tinkered around with other electronics such as a PC, etc., note that this ribbon cable is not secured by the connector (atleast in my case). Reseated the cable and turned the power on. Voila- the bake option works. Tested it by turning it on for 20-30 seconds. Touched the bake element and got proof that it was working fine (via a singe of the ring finger ;-)).
About three minutes or so later, the display started to beep with an error code - E0 F2. A shorted keypad is what it stands for. The clock was still operable. I could still select the bake option, broil option, etc. Ran a test bake cycle but it turned off after a minute or so and started to display the E0 F2 code again.
Started the process all over ie turn power off, take panel off, reseat ribbon cable. Turn power on and test by holding the Cancel button for five seconds. Still displays the E0 F2 error. Waited for 10 minutes but this time no more beeping or error display. Ran a preheat cycle for 4+ minutes without any problems. The oven warms up and the bake element glows red. Hopefully, all is well. Will see what it does when we bake something the next time.
Thanks to PropHeadTwo and others for their contributions.
Posted on Dec 18, 2008
  • 22 Answers
SOURCE: whirlpool accubake oven door will
F5 fault codes are latch mechanism problems. One means the latch won't lock, the other means the latch won't unlock. Odd you're getting both...
Posted on Apr 25, 2009
  • 189 Answers
SOURCE: just bought a used whirpool accubake sc 465, keep
Hello- The F3 error code indicates an open circuit in the temperature sensor. Pull back cover to access sensor wires.  At room temp the resistance should be 1000-1100ohms. If open, replace sensor. This should solve the problem. Let me know if this info helps- have more if needed. Thanks- Ed
Posted on Mar 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Have Whirlpool Electric Range super capacity 465
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Posted on Oct 01, 2010
TheMobilian
  • 8220 Answers
SOURCE: E0 F3 Is the
You should check the sensor for 1100 ohms at around 75F If shorted to frame or open then that is your problem.
Posted on Dec 17, 2010
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
I have a whirlpool Gold Accubake System When turn the oven on turn up temp, only goes to 260 c what is the f under c how to change to f to make the temp go up to bake if problem with temp explaincf
To change: Press and hold PRECISE CLEAN for 5 seconds. A tone will sound, and "°C" or "°F" will appear on the display. Repeat to change back. To exit, press CANCEL/OFF.
Nov 28, 2015 | Whirlpool Ovens
Coil won't turn off
Have it checked by a properly qualified and licensed technician. You can't see electricity and it is a killer.
Nov 10, 2013 | Whirlpool Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
I keep getting a F6E5 error code on my Whirlpool stove. I have tried unplugging it (overnight) and the error won't go away. Any ideas before I call the repair man?
The error code F6E5 means "Cancel key error". Press the "Cancel" and "Start" keys in the following order: CANCEL, CANCEL, START. Verify the error code displayed on the control by observing for longer then 1 minute. If the error comes back then the control board needs to be replaced..
If this was helpful please rate me Thanks
Jun 12, 2011 | Whirlpool Ovens
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
"loc" display
This just happened to me. I have whirlpool double oven accubake. The display went blank and i had to turn the breaker off. I left it off for several hours. When I turned the breaker back on my oven display read "Loc" in big letters to the right of the time. I held the start button down for 5 secs. The display went away and the oven started to work as if nothing had happened. I hope that is stays that way.
Dec 08, 2007 | Whirlpool Ovens
Whirlpool RBS305PDS Electric Single Oven Logo
94 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
