Code 10 cd/dvd - Computers & Internet
    Scholar:
  • 121 Answers
Lets follow this:-
1. Choose Start > Run..
2. Type regedit in the Open text box and click OK.
3. Expand my computer - Expand HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4.On the right hand side, you'll find upper and lower filters, select them one by one and delete.
5.Restart PC and hope it works for you.
Note:Create a restore point before you delete any key from registry.
Thanks
Posted on Oct 07, 2009
    Novelist:
  • 114 Answers
Try This:
3. In the Registry Editor dialog box, navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4. Select File > Export (Windows XP) or Registry > Export Registry File (Windows 2000).
5. In the Export Registry File dialog box, select Selected Branch under Export Range, name the file (for example, CDDVDkey.reg), and click Save to save the file to the Desktop.
6. In the right panel of the Registry Editor, select the LowerFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box.
7. Select the UpperFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box.
8. Close the Registry Editor.
9. Restart Windows
Regards Soumajit
Can't get my cd/dvd rw drivers to work? Can't read the CD/DVD RW Tray?
Description of Code 10-related errors that Device Manager generates in Windows-based computers
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - then RIGHT CLICK the drive - UNINSTALL - REBOOT
this will refresh the default driver stack.
if this not work, replace the device with a new one.
Mar 03, 2015 | Acer 15.6 Inch LCD Screen Panel for Aspire...
Get a code 10 error message. it doesn't run any cd or dvd
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Jan 11, 2010 | Pioneer DVR-107D DVD±RW Burner
Cd/dvd has as error code 10
i had the same problem error code 10 in my laptop, i taught the problem will be in the cd/dvd but i try to format the windows.and it seems the lens is working and reading,and it continues installing until the windows loaded and the cd/dvd working good.
Jan 04, 2010 | Acer Aspire 5315 Notebook
Code 10 no cd/dvd drive found, unable to burn cd?
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Jun 24, 2009 | Apple iTunes
LG HL-DT-ST DVDRAM GSA-T10N error code 10
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Apr 03, 2009 | LG (DAD-8020B) DVD-RAM Burner
CODE 10 ERROR
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Mar 30, 2009 | Samsung Super-WriteMaster SH-S183L Burner
Pioneer DVDRW DVR-K17B ATA Device won't run any CD's;
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Dec 09, 2008 | Pioneer DVR-107D DVD±RW Burner
TEAC DV W28ECT ATA DEVICE CODE 10
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Aug 24, 2008 | Teac CD-Rewritable W28E CD-RW Burner
Computer problem
if the code-10 is in device manager it usually means 1 of 2 things:
1) the drivers installed are the wrong ones
2) the cd/dvd drive needs replacing
if the drive is removable, remove it and reinsert it to see if it is just a bad connection. if it was working before and is no longer working, the drive may need replacing. if it was working before and died after a system or driver update, use "roll back driver" in the device manager properties box for the dvd drive.
hope this helps,
trin
Nov 19, 2007 | Compaq Presario M2000 Notebook
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
