Question about Exercise & Fitness
The oomputer display on my recumbent bike does not
The computer display on my recumbent bike does not display the rpm or speed. The display is only reading 0 . Could this be a defective or misaligned speed sensor on the wheel ?
    Habit-Forming:
  • 115 Answers
Check the cable running from the computer to the main drive wheel. Check the alighment of the magnets
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Posted on Oct 09, 2009
How to assemble a weslo pursuit ct 4.2 bike video
Weslo Pursuit CT 4.2 Recumbent Cycle: Relaxing Exercise ...
www.kmart.com > ... > Recumbent Cycles
KmartSep 30, 2012 - Arts & Crafts · Video Games · Learning & Development · Stuffed Animals & Plush · Musical ... Weslo Pursuit CT 4.2 Recumbent Cycle 1 ... With a Weslo recumbent bike you can approach exercise with ease. .... Like all in box items it takes awhile to assemble, but works great, and great value for the money.
Weslo Exercise Bike - YouTube
? 2:55
https://www.youtube.com/watch?v=2ZLzpsk4BdE
Dec 22, 2014 - Uploaded by ReviewTube
Weslo Pursuit CT 2.0 R Exercise Bike http://amzn.to/1vgiQjF ...bike assembly,weslo exercise bike amazon ...
Weslo Pursuit CT 42 Recumbent Exercise Bike ... - YouTube
? 1:41
https://www.youtube.com/watch?v=tYdlVsnDNQo
Aug 20, 2015 - Uploaded by Geraldine T. Lane
SEE MORE Best Sellers in Exercise Bikes http://amzn.to/1frY7Yr The 3 Week Diet is an ... Weslo Pursuit CT 42 ...
Weslo Exercise Bike Product Support ' ManualsOnline.
Jan 17, 2016 | Weslo PURSUIT CT 4.2 Recumbent Cycle
My bike reads E1 when I plug it in
Version:1.0 StartHTML:0000000168 EndHTML:0000001293 StartFragment:0000000468 EndFragment:0000001276
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
test the speed sensor for open or faulty. clean it, and tight the connector very well. see the diagram attached. However RUN the software calibration for easy fix it.
God bless you
Mar 21, 2013 | Schwinn 220 Recumbent Bike
Stopped sensing speed or give resistance
proceed according and fix it. God bless you
  • 1 Press the reset button to reset the system, then unplug the bike from the power outlet. Wait about five minutes, then plug in the bike and reset the system again. This usually solves most computericon1.png glitches or error readings.
  • 2 Check all basic connections first if the system won't turn on, or the display is partially functioning or not functioning at all. Ensure that the plug is securely plugged into a proper working outlet. Check to ensure that the cable is securely plugged into the front of the system, and that the cable doesn't appear damaged. If the cable is damaged, replace it immediately.
  • Sponsored Links
  • 3 Inspect the system display visually, looking closely for cracks. Also check to see if humidity has caused moisture to enter the screen. If so, you may need to replace the display.
  • 4 Check all connection points and latches. Latches should be lined up with all connectors and be securely in position. Push on the connection and listen for the snap when the latch locks into place. The computer or circuit board may need replacement if all connections are fine and the display isn't operating properly.
  • 5 Check all connections for the HR (Heart Rate) sensors. Check to ensure that both HR connections from the handlebars and the cable box are secure. Apply a conductive electrode creme to the handlebar sensor to see it produces a better connection. You may have to replace the handlebars or cable if no connection is being produced.
  • 6 Check to ensure the RPM sensor is properly aligned with the magnet on the flywheel and that the connection is secure on the RPM data cable. Reposition the sensor if it's not aligned properly; replace the cable if the connections are broken or the cable is visibly damaged.
  • 7 Move the bikeicon1.png away from large metallic objects, microwaves or other electronic equipment that may interfere with the bike's computer. Ensure that the bike is positioned on a flat, level area--otherwise, the bike will rock and feel unstable. Ensure that all knobs, pins and levers are installed appropriately, including pedals, crank and seat. Cranks should be connected at 180-degrees from one another. Seat pins should be seated completely and securely in the your designated pin hole for seat position.
  • Read more: How to Troubleshoot a Schwinn 230 ' eHow.com http://www.ehow.com/how_6829448_troubleshoot-schwinn-230.html#ixzz2CgvzNzjT
    Nov 18, 2012 | Schwinn 250 Recumbent Bike
    What's the best exercise bike there is?
    According to me, one of the best Exercise Bike is Fitness form S20 Indoor Cycle Bike. It has adjustable resistance level and adjustable horizontal or vertical seats also. It provides the pulse, distance and speed or has roller wheels to move around easily. In this bike, you can also get a warranty of 12 months.
    Aug 09, 2012 | Exercise & Fitness
    What's better a recumbent or an upright exercise bike?
    Recumbent bike works best for elderly people with back and hip problems because of the relaxed position and the angle that put's less pressure on those areas. Upright exercise bike works on more areas than the recumbent bikes including the lower abdominal muscles.
    Error 3 (E3) on Schwinn 240 recumbent bike. How can I fix it?
    No speed/RPM reading, Console displays "E3" error code
    Check data cable integrity All wires in cable should be intact. If any are cut or crimped, replace cable.
    Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
    Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
    Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
    May 23, 2010 | Schwinn Exercise & Fitness
    Can't get any power running on my 5500 hr life cycle
    You have to start pedaling to get it to start up, some times you have to pedal pretty fast to get it to start up
    May 27, 2009 | Life Fitness 9500RHRT Recumbent Bike
    Error message on recumbent bike
    The problem might be the gearbox. I know because I have the same problem.  Keys fitness is out of business, but "The Treadmill Doctor" has purchased the inventory of parts for the bikes. They will help you troubleshoot, and have parts available if you need them. The number is 1-888-340-0482. Or, you can go to treadmilldoctor.com.
    Jan 07, 2009 | Ironman 430r Recumbent Bike
    Vital Fitness RB-251 Recumbent Bike Manual
    Can I purchase a computer for my RB330P recumbent bike? If so where and how much?
    Aug 23, 2008 | Sport & Outdoor - Others
    Exercise & Fitness Logo
    368 people viewed this question
    Top Exercise & Fitness Experts
    Howard
    Howard
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
