Question about Refrigerators
The fan is moving air in botrh the freezer and frig but it is not cooling. We think it is the compressor relay, but do not have the manual to locate it and check.
  • 4,070 Answers
It's on or near the compressor. Remove the cardboard backing to access the compressor and cut it off for a few minutes and cut it back on while watching and listening to the starter click and the compressor is supposed to start.
Posted on Oct 07, 2009
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Refrigerators
My Frigidaire refrigerator is at 60 degrees Fahrenheit and will not cool down
There are a few possibilities. First, Is the freezer portion working okay? If yes, then the problem is blocked air flow from the freezer to the frig. If no, then the cooling fan could be bad or the thermostat could be bad. First check for temperature in Freezer section, should be about 4-8 degrees no more. If it is cold, then locate the cooling fan behind the back of the frig and see if it is moving or listen for movement. If it is moving then rearrange the food in your freezer compartment.and frig compartment away from the vents. If it is not moving, then the thermocouple could be bad. compressor problems and freon leaks are not that common unless the frig has been moved alot. The cooling fan or thermocouple or overstuffed freezer compartment are the usual suspects in 90 % of cooling problems. cooling fans and thermocouples can be cleaned by using canned compressed air to remove dust which will sometimes cause a failure. The parts are inexpensive but labor is about $80. Start with the freezer because all of the cooling for the whole unit starts in the freezer.
Dec 18, 2010 | Frigidaire Refrigerators
Frig won't cool RM2652
You'll need to get in touch with the store you bought it from but Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 26, 2010 | Dometic RM2652 Refrigerator
Freezer has stopped
If it is a frost free side by side fridge/freezer, check evaporator fun in the freezer. While doing that, check is evaporator is full of ice.
if the evaporator is iced up and the fan can spin freely, you have a broken fan. Replace it.
If evaporator and the fan are iced up, you have a broken thermostat. Defrost ice with hot water.
Turn it on, if it starts to cool effectively, replace thermostat.
Oct 11, 2009 | Refrigerators
Fan underneath frig is running but no cold air is coming into the frig or freezer
The fan that is under the frig is the condensor fan(the fan the cools the condenser coils and the compressor. It does not have a direct effect on the chilled air circulation inside of the frig. The evaporator fan is the unit that circulates the chilled air thru your freezer and frig. I am not sure what make model unit you have, but I have found that this fan motor is 90% of the circulation problems i have seen.
Jul 31, 2009 | Refrigerators
Compressor intermittently starts, loud humming when it doesn't
get a 3 and 1 relay that will help boost the start windings on the compresor and help it start-up. get the one for 1/2 hp and you shoiuld be good to go.
Jan 29, 2009 | Amana ACD2232HR Side by Side Refrigerator
Help frig not cooling model # FRT21LR7A
You have to replace the electrical components on the side of the compressor. The heat from the fan not running by the compressor more than likely has damaged them. These are a safety feature to save the compressor from damage when it overheats.
You can find the factory repair manual here. This will have all the part numbers and what you need to replace to take care of your refrigerator. The Top Freezer Refrigerator one will be about your machine. It covers all the FRT Models.
Thanks
Jan 08, 2009 | Refrigerators
Refrigerator not cooling down below 60 degrees f.
hi!!! make sure your inside fan is blowing and also go to back of your frig and see if the compressor and condensor fan are working if not then thats your problem..If they are working then you have a seal system problem in your frig..make sure when you look at the compressor you try to hear a cliking sound if you do then change the current relay..Good luck..
Jan 04, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
MAYTAG SIDE BY SIDE MSD2356AE. FREEZER NORMAL TEMP. FRIG. 60 DEGREES.
make sure that there is nothing blocking the flow of air coming in. the fridge is cooled by the air in the freezer. also you might think about replacing the relay on the compressor. it may be going out.
Aug 11, 2008 | Maytag Refrigerators
Kenmore 106.52274202 not cooling
By you description of the problem and this model of fridge it sounds like the the relay on the compressor has failed and will need to be replaced. Especially if this happened overnight.
Nov 25, 2007 | Refrigerators
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
