Question about Samsung WF337AA Front Load Washer
How do you attach the drain hose to the wf448aaw
The Drain hose comes attached to the drain motor inside the washer and exits the back of the washer. It is gray in color. You need to place the drain hose into the main drain in the wall. It does not need to be attached. Usually there is a Black ruber section of hose that is in the shape of a "j". Just b sure that it is secure and doest pop back out.
Posted on Oct 07, 2009
Washing Machine wont drain, gives empty filter error message
If there was items stuck in your pump/ tubes-you may need to now reset your machine to clear the error and have your machine back up and running.good luck.
Jan 24, 2013 | Samsung WF448AAW 4.5 Cu. Ft. Front Load...
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
We have Samsung WF448AAW steam, silver care washer. This problem only occurs on towel cycle. When we wash colored cotton terry bath towels and wash cloths there area areas about the size of your hand or...
Hi
This type of issues usually occur when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 2 cups of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the bleach marks should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Jun 17, 2011 | Samsung WF448AAW 4.5 cu. ft. Front Load...
How do you remove the filter on the back of a VRT Steam Samsung washer?
Actually there should be a little door you can access at the bottom front to clean out your pump filter, I'm including my washers pictures. 1) You first open the little door at the bottom. You do not need any tools, just something to drain the water in to. 2) Unscrew the hose closure, put your hose down into the drain bucket. Drain all the water out, you may have to empty the bucket so you can get the hose lower next time. 3) Next unscrew the filter itself. Get anything out inside the hole, in my case it was a toothpick, I take a paper towel and dry out any grit or hair. 4) Put your hose closure back on, it is held in a clip, Then screw the filter back in. That's it. I would also recommend cleaning out the drawers that hold soap, bleach and fabric softener. Also clean around the rubber ring, it will help your washer last longer. lanijo58_3.jpglanijo58_2.jpglanijo58_1.jpglanijo58_0.jpg Hope this helps you
Jun 02, 2011 | Samsung WF448AAW 4.5 cu. ft. Front Load...
/my dehumidifier has a hose attachment on the back. how does that work?
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
Hope this helped.
Mar 20, 2011 | Amana Dehumidifiers
I attached a hose to the drain hose connector. When I insert it into the drain hole it is blocked by the back of the dehumidifier. What iw the correct way to insert? Can you send a better diagram?
The drain hose connector MUST be attached to the unit, before attaching the garden hose.
First, the connector is attached to the unit. Second, the hose is hand tightened to the connector.
If you haven't been doing it in this order, that's the problem.
Mar 13, 2011 | LG LHD459EL Dehumidifier
Water wont drain
You use your dishwasher so often with no problems that any issue can seem like a major disaster. But you can fix a drainage problem with a trip to the hardware or plumbing supply store and a few minutes of effort. If your dishwasher doesn't drain properly, the drain hose is probably kinked or damaged, interfering with the flow of water out of the dishwasher. You can fix the problem by replacing the drain hose yourself.
Difficulty: Moderately Easy Instructions And 4 Tools (Material) Needed To Solve The Drain Problem.
  • Shallow dish,Pliers or screwdriver,Replacement drain hose,Replacement hose clamps
  1. Turn off the water supply to the dishwasher. Turn off the dishwasher's power supply by unplugging it (under the sink) or turning off the appropriate circuit breaker.
  2. Pull the dishwasher all the way out from the cabinet so you can access the drain hose and pump near the back.
  3. Locate the drain pump and hose. The drain hose is the larger of the two hoses attached to the dishwasher and is generally located close to the bottom back of the dishwasher.
  4. Place a shallow dish under the drain pump. Loosen the clamp on the drain hose close to the drain pump, using pliers or a screwdriver. Pull the drain hose off of the pump, allowing any water to drip into the dish below.
  5. Remove the other end of the drain hose from the garbage disposal or drain by loosening the hose clamp and pulling the hose off of the connection.
  6. Attach the replacement hose to the drain pump and the drain or garbage disposal. Attach new hose clamps, and tighten them to hold them in place.
  7. Turn the power and water back on, and run the dishwasher through a cycle to make sure that the dishwasher drains properly and the hose doesn't leak. Tighten the hose clamps if you find any leaks.
Good luck and thanks for using fixya.
Jan 30, 2011 | Kenmore Dishwashers
WF448AAP Drain hose short, door swings to left, washer on right?
plumbing in the wall is usually placed according to where your unit is going to be placed,..not the case here as i/you can see,..you should be able to get a piece of hose (from private appliance store) and an "insert coupling" (has little "barbs" on it so it stays put after you clamp it) and make your extension,...don't make it to long or to tight, you don't want tension on the hose,....baby sit this "custom repair" to insure it dosn't leak, ya know, watch a couple loads go thru it's cycle,......if you can't get this happening, you can have the drain in the wall moved,....not a big job if your drain is plastic. good luck.
Jan 03, 2010 | Samsung WF448AAW 4.5 cu. ft. Front Load...
How to drain the rheem 135 litre tank
1. turn off the electrical power first.
2. attach a garden hose to the hose bib attachement on the bottom of the water tank and run the hose outside to allow the water to drain out by gravity.
3. Turn the valve that is on the inlet of the water heater. Now that the power is off, you can drain the tank.
4. open the drain valve where the hose has been attached.
5. To release the pressure, you can open a hot water faucet in your kitchen. This will allow the water to drain out easier.
Sep 12, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Samsung WF337AA Front Load Washer Logo
156 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
