Question about Samsung Refrigerators
How do you force defrost a 4 door Samsung refridgerator RM255. I have the service manual but it is still confusing
  • 31 Answers
Go into freezer
take off back wall.
you will see the ball of ice around your evaporator.
hair dryer; plug in, turn on, go crazy.
Posted on Oct 07, 2009
Freezer door opens every time we close the refridgerator door
You need to defrost the refrigerator completely there is an air vent from the freezer into the refrigerator with a valve that valve is stuck open so when you close the door at forces air back into the freezer
Oct 17, 2017 | Refrigerators
How to access service Menu on Samsung Refrigerator 26Cf French model RF261 BEAE
look on the internet for a service manual from samsung and goo from there maybe it wants a new memory card fitted
Oct 31, 2014 | Samsung RF261BEAEBC 25.6 Cu. Ft French...
Is my defrost timer or control board defective
that would seem to indicate that the defrost timer is bad yes? the fan is blowing right?
Sep 08, 2014 | Whirlpool Refrigerators
Samsung RF217ACBP keeps freezing the ports inside the refridgerator. Then the fan motor starts
Their is a fan circulating air through out the unit. If this fan is not working you will experience what you have discribed.
Jul 21, 2014 | Samsung Rf217acbp Black 20 Cu.ft. 33"...
My Samsung RB1855SW refridgerator not cooling
You may just be catching the unit during normal defrost cycles. Next time, allow the unit some time to complete it's needed task. If you allow it 30-minutes, it should restart on it's own. The cycles are necessary to keep the unit working properly. The cycles will be more frequent as the weather warms. If you allow the unit 30-minutes and it does not restart on it's own, then there could be a problem. You might consult the owners manual for more details.
Apr 06, 2010 | Samsung Refrigerators
Running to cold, after while evaporator coils are packed with ice even defrost timer ,termostat and heaters are new.
Hello, Most likely you have a bad defrost timer, If you have a mechanical defrost timer it will normally be located either in the control panel inside the fridge or behind the panel beneath the doors. To test this once you have found the timer advance it to the defrost cycle and the wait to see if the heater makes a spitting noise. If the defrost cycle fires up then the timer is bad and you should replace it. If you have a digital defrost timer it will be a circuit board located in a panel behind the refridgerator. locate the tech sheet behind the panel under the doors and force it into the defrost cycle...once again if the defrost cycle kicks in your going to have to replace the circuit board. If you have any other questions please feel free to comment again. Mike
Oct 17, 2009 | Refrigerators
Refrigerator side not cooling
The fresh food section is cooled by the freezer section by forced air supplied by a fan. If you have air flow, check the temp inside the freezer. It should be between 0 and -10. If not look inside your freezer and see if you have ice built up on the back panel. If so you have a defrost problem that is most likely a bad defrost heater, a bad termination thermostat or timer. If ther is no ice then check your fan under the refrig. If you can hear the compressor running it should be turning. If this all checks out then you have a freon system problem like. Low Freon pressure or a restriction.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
197 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
