Refrigerators Logo
Posted on Oct 07, 2009
I have an old , perhaps 15 years old, hotpoint refrigerator with a top freezer. Defrost water runs down the inside back of the refrig compartment. It appears that the unit is designed for the water to run down this way. Is that possible or is there a drain tube that I have not yet found?
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Oct 07, 2009
Anonymous
Contributor
Level 1:
Answers
31
Questions
Helped
10006
Points
87
Yes sir.
take that whole freezer compartment apart. bottom, back, all that good stuff. you will see the hose.
I have a top freezer Hotpoint refrigerator at a lake home. It's about 6 years old. I've been getting water in the refrigerator compartment. I've tried to clear the hose on the back by...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
3answers
MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
2answers
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
1992 T&B refrig drips water from inside top of refrig compartment Is it a blocked drain tube? Or bad heater evaporator unit?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Water collects at bottom/Ice forms in top
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
Defrost Drain
3helpful
Water dripping inside back of top compartment
It looks as if your drain tube has stopped up and the water is finding the next easiest route. The drain tube runs from the freezer area, down the back of the fridge to the lower area near or on top of the compressor where it evaporates. Some food may have gotten stuck in the tube. If you can get to the back of the fridge and see the tube (it may be in the wall) you may be able to dislodge it. There also may be a place in the refrigerator where it drips from the freezer to a funnel in there. It depends. But that is normally what happens when the refrigerator goes into defrost. It fires up cow-rod coils in the freezer area and keeps the frost off the coils thats why they call it frost free. the water then runs down the tube. Start checking there first.
3helpful
2answers
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
1helpful
2answers
Fan running but neither refrig or freezer is getting cold.
Your refrigerator may be stuck in defrost cycle. I know it has a defrost timer part number 215846602 Most times they are located inside the fresh food compartment behind the control panel. Sometimes below fridge and behind kick plate. The thermostat could be defective also. You can check that by unplugging the refrigerator remove cover and checking continuity between the two male connections located on the rear side of thermostat control turned as cold as you can turn it. Or you can join the two wires together and plug refrigerator back in to see if compressor comes on. When you find the defrost time turn clockwise slowly until the refrigerator starts. If these don't work let me know and we will do some more test. Sea Breeze
Water dripping from freezer when defrost kicks on.
You probably have a plugged drain in the freezer compartment. Open that up and check it. Hope this helps!
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
