Question about Toshiba Satellite M55-S3293 Notebook
Bios backdoor for toshiba laptop
Is there a bios backdoor for toshiba laptop satellite M55-S3293
  • joecoolvette
    joecoolvette May 11, 2010
    Reasoning? Further clarification is needed, as to why you wish to access BIOS on the laptop without going the proper way.
    President:
  • 2,600 Answers
System (BIOS) Password Reset
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
Posted on Oct 07, 2009
  • sp1ke0kill3r May 02, 2013
    Why not just use a standard jumper to short?
Hi i have a toshiba satellite l300 the battery
For Award BIOS' try these backdoor passwords:
AWARD_SW
j262
HLT
SER
SKY_FOX
BIOSTAR
ALFAROME
Lkwpeter
j256
AWARD?SW
LKWPETER
syxz
ALLy
589589
589721
awkward
CONCAT
d8on
CONDO
j64
szyx
For AMI BIOS' try these backdoor passwords:
AMI
BIOS
PASSWORD
HEWITT RAND
AMI?SW
AMI_SW
LKWPETER
A.M.I.
CONDO
For PHOENIX BIOS' try this backdoor password:
phoenix
Jan 14, 2011 | Toshiba Satellite Pro L300 Notebook
How I can open my toshiba satellite m55-s135 and reset the bios password
open the screw under your laptop & then open the cover then there near your button cell on your motherboard there is a three pin sokit in in which two jack pin are plunged ,pull it out & plug it into thurd & second pin & again into second & first through which your laptpo will restart & your bios password will be broked
Sep 21, 2010 | Toshiba Satellite M55-S135 Notebook
HOW DO I RESET THE BIOS PASS WORD ON A TOSHIBA LAPTOP L355
Hi if you want reset bios password ( asume you forget it) You need reset bios find reset CMOS jumper or take out battery for few sec. All settings in BIOS will be reset. Let me know if you need more help
Aug 25, 2010 | Toshiba Satellite L355-S7811 Notebook
I need to know how to unlock a toshiba laptop m55 "enter password" comes up as soon as I turn it on...
You might be able to get past it by removing any batteries and then removing the bios battery while it is unplugged.
May 20, 2010 | Toshiba Satellite M55-S3512 Notebook
Can I access the memory module under the keyboard to upgrade with a 1GB memory module on my Toshiba M55 3293 Laptop?
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1132280&rpn=PSM50U&modelFilter=M55-S3293&selCategory=3&selFamily=1073768663
The link above has a picture of where the memory cover is on the bottom it is basically right in the middle. Once you remove the screw then you can install/upgrade the ram. You can use this video as a guide as to how it is done.
http://www.youtube.com/watch?v=D1oTz-F6xME
Also make sure you have the correct/compatible ram for your laptop.
If you have any other questions let me know.
Thank you,
Lee
Nov 05, 2009 | Toshiba Satellite M55-S3293 Notebook
My right arrow key will not work, the key does not respond in any fashion.
Contact could be most probably defective or dirty. You may find a new keyboard on ebay at a very affordable price : 10-30$. Have it replaced by a professional.
Oct 06, 2009 | Toshiba Satellite M55-S3293 Notebook
Satellite (A75S206) runs well from outlet but never from battery. Was told that mobo can't accept dc. Need new mobo. True?
hello loyd516,
Have you tried a new battery? They are much much cheaper, and a whole lot easier to replace than a motherboard.
Here are replacement batteries that I found searching with Google.
http://www.google.com/products?q=Satellite+A75-S206+battery&hl=en
According to Toshiba, there has been a battery recall for your specific model.
If that is the case I would definitely contact Toshiba support about it. Maybe you will get a free battery out of the deal. Who knows.
Here is the link and the list(your model is highlighted)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1501060
Sony Battery Pack Recall Programs Document ID: 98082080 Posted Date: 10/10/06 Last Updated: 10/30/08 Operating System: N/A Category: Battery Distribution: Public
Applicable Models:
Satellite A70-S256, A70-S2561, A70-S2362, A70-S2491, A70-S2591, A70-S2482TD, A70-S2492ST, A70-S259, A70-S249, A75-S206, A75-S2091, A75-S2292, A75-S2291, A75-S229, A75-S209, A75-S2061, A75-S226, A75-S2261, A75-S276, A75-S1255, A75-S1254, A75-S1252, A75-S1253, A75-S1251, A75-S125, A75-S2131, A75-S213, A75-S2112, A75-S2293, A75-S2311, A75-S231, A75-S2111, A75-S211, A75-S2761, A75-S2762, M30X-S1592ST, M30X-S1593ST, M30X-S191TD, M30X-S181ST, M30X-S171ST, M30X-S221ST, M30X-S221TD, M35X-S149, M35X-S1491, M35X-S109, M35X-S309, M35X-S3091, M35X-S329, M35X-S1631, M35X-S163, M35X-S1143, M35X-S1142, M35X-S114, M35X-S3111, M35X-S311, M35X-S1611, M35X-S161, M35X-S111, M35X-S1492, M35X-S3291, M35X-S349, M35X-S3491, M35X-S3112, M35X-S1141, M50-S418TD, M50-S4182TD, M50-S5182TD, M50-S5181TD, M55-S135, M55-S325, M55-S3262, M55-S2253, M55-S3251, M55-S1351, M55-S1352, M55-S3511, M55-S351, M55-S3294, M55-S3293, M55-S3292, M55-S3291, M55-S329, M55 Series, M55-S2252, M55-S3512, M55-S3315, M55-S3314, M55-S321, M55-S3313, M55-S3312, M55-S3311, M55-S331, P30-S6362ST, P30-S6363ST, P35-S609, P35-S6091, P35-S6111, P35-S6311, P35-S631, P35-S6112, P35-S6053, P35-S6052, P35-S6051, P35-S605, P35-S611, P35-S6292, P35-S629, P35-S6291
Tecra A3, A3-S731, A3-S611, A3-S711, A5-S416, A5-S237, A5-S516, A5-S136, A5-S3291, A5-S3293, A5-S3292, A5-S329, A5-S118, A5, A5-S6215TD, A5-S116, S2, S2-S511TD
Jul 11, 2009 | Toshiba Computers & Internet
Can't get past bios password
try use omnipotent bios password. here is the list
Apr 15, 2009 | Toshiba Satellite M55-S135 Notebook
I need user manual book of my M55-3293, please.
Hello!
Your user manual is available from Toshiba here:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_docTOC.jsp?moid=1132280&coid=105484&soid=1083054&modelName=Satellite%20M55-S3293
Feb 17, 2009 | Toshiba Satellite M55-S3293 Notebook
Toshiba Satellite M55-S3293 Notebook Logo
528 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
