Question about HP LaserJet 3055 All-In-One Printer
When trying to scan it says Not Setup on PC. What can I do to solve this issue?
  • 330 Answers
Check the connection if its not working means you can reinstall the driver and check it....
Posted on Oct 07, 2009
I can print but i cant scan to my network printer
Network changes?, Scan folder on the PC still setup for the scan, or is this scan to email issue, mail server problems?
Mar 13, 2015 | Konica Minolta Bizhub C253 Copier
My pc suddenly can't download any files from internet. Anyone know how to solve this issues?
Try to re boot. Have you done a malware scan, if not reboot in safe mode with networking, try to download MALWAREBYTES AT:http://www.filehippo.com/download_malwarebytes_anti_malware/. Run a FULL SCAN and delete any results. Are you sure you are connected to the outside world? When you open "Network and Sharing Center" and verify your connection,if you haven't already.
Nov 04, 2012 | Toshiba Notebook 883974582570
When I try to scan, the scanner setup window will not open and nothing will scan
first reinstall operating system
and after it install scanner setup if scanner setup not run
then
downlode another setup and install it
problem will solve
Oct 22, 2012 | Nuance PaperPort 12
How come my pc cant link to scan doc???? this is an office pc. my pc at 1st can link to this canon IRC3220N , it can photostat can scan from the canon to pc into scan doc file. but for right now my pc...
try to reinstall the driver s for the printer/scanner ...and see if the issue is solved.....Another thing ....if the scanner is used by multiple computers you have to give the scanning command from the computer ...and not from the scanner itself...This way you will be able to import the scan result into the library of the program that drives it ..
another thing that may happen is the link to be broke ...so ..get to the fax and printers in the start menu ...and open it ..and redo the link ..by scanning for printers and choose it again from the list ..(by name ) ..and make it the default printer/scanner..
Jul 05, 2011 | Office Equipment & Supplies
I am using auto feed on HP 4345 MFP printer, the issue is I have documents with one side printed but printer is scanning both side and printing. How can I change setting to single side from Duplex scanning...
Mr. Agarwal
you have to turn off the duplex scanning option under copy settings this will solve the issue
You can go to settings and look for Copy setup or copy settings i dont remember well but you get an option of DUPLEX COPY or DUPLEX SCAN you have to turn off this.
DO RATE MY SOLUTION PLEASE
Saleem
Jun 30, 2011 | HP LaserJet 4345mfp Printer
Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Mar 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I have a Ricoh Aficio 2022sp that refuses to send scans via smc to ONE Vista PC. Other users have no issues. I have disabled virusscan and firewall and tested all securities and permissions. Still PC and...
Are you using ScanRouter or SMB (SMC?) ?
How are the others setup?
Does the laptop have connectivity to the machine (print,Webbrowser)
I've solved these poblems hundred of times
Aug 05, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Scan feature is not working.
Without a little more information, it's hard to say exactly what the solution to your issue would be, but please look here and try to choose from the search list the most appropriate solutions that apply to your issue.
Otherwise, check here and use the solve a problem or setup and install sections to work through the scanning setup and find the source of your difficulty.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Photosmart C5280 Printer -scanning
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Jul 20, 2008 | HP Photosmart C5280 Printer
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
HP LaserJet 3055 All-In-One Printer Logo
361 people viewed this question
Seeker5211
Seeker5211
