Question about Invacare Health & Beauty
Joystick in programming, inhibit and/or charging modeand chair will not run.
  • 175 Answers
This is usually due to either the joystick getting knocked off center or a fault in the control module. If the joystick has suffered a hit such as somebody falling onto it while getting in the chair, or running the joysitck under a table or counter-top(happens often), it knocks the alignment off so that the controller thinks that the joystick is activated, and it will prevent the chair from moving until it is back in its proper location. Examine the joystick for signs that it has suffered a trauma such as the rubber boot being torn, dents on the cover, paint from a collision, etc. Invacare is going to charge you about $1,300.00 for a new joystick, or, you can try sending it to a repair shop. I found one here that I used once and it turned out cheaper...by a lot$. Here's the link.
http://www.flightsystems.com/cart_controls/wheelchair_powered_scooter_market_cart_controls.htm
Keep in mind, it may also be the controller. The only sure way to tell is to swap out the joystick with a known good one, and see if it fires up, if not, then it's the controller. Get your wallet out. I don't know of anywhere to go but to Invacare for the controller. You don't say what kind of wheelchair it is, but if it is one that the controller is built into the joystick then the link above should be able to fix it. If the controller is separate and located in the base, then you have to buy a separate controller from Invacare. To tell, the all-in-one controller will have a very thick chord running from it down into the base; about 3/4" diameter. A separate joystick and controller-in-base will have a smaller chord, about pencil-sized running down into the base fronm the joystick, and will lead to the controller in the base. Good luck.
Posted on Oct 09, 2009
Does jazzy have to be in certain position to charge it
I tell my customers to charge the chair with the joystick on! otherwise it should be upright in a drive position do not charge a chair upside down! I don't know why someone would do that but...
once the charger is plugged in the chair is inhibited from driving, so if it is plugged in it won't drive.
Strege Mobility
Jun 12, 2014 | Select Jazzy Used Electric Wheelchair
My father has a Jazzy 600 electric wheelchair and it has been working fine, batteries are only a few months old but all of a sudden it will not charge. Should not be able to move the chair while it is...
Sounds like the inhibit function of the chair has been damaged. This function will not let you move the chair while charging. If Dad doesn't have the charger off when plugging in to the chair or removing it it can short out the charger port causing your problem. Unfortunately the only fix is to replace the joystick/controller. If Medicare paid for Dad's chair then they will pay for most of the repair costs. Contact the provider that brought Dad's chair and ask if they can order a new joystick for you Hope this helps
Jun 06, 2011 | Health & Beauty
All the lights are blinking on the speed display.. we've had the chair plugged into both the back of the chair and the armrest.. the chair still won't move.
The speed display will flash whenever you have the charger plugged in. Either in the back or in the joystick. Hopefully you didn't have them both plugged in at the same time. If after you unplug the charger you still get the flashing speed lights then you have an inhibit problem with the chair. The inhibit function will keep you from being able to drive the chair while charging. This repair is beyond anything you can do and must be referred to a Pride dealer or Repair service Hope this helps you
Apr 22, 2011 | Pride Jazzy 1113 ATS Indoor Power...
When I plug it in to charge it does nothing. No lights the gauge doesn't move . Any ideals ? She have had problems like this for years off and on . They send out a repair man and it will work for a short...
Could be the charger or the charger port. Do you have the offboard charger that plugs into the joystick or an onboard charger? I would suggest trying to find an offboard charger from a friend or your provider that you can borrow and plug it into the charger port under the front of the joystick to see if it will charge the batteries. the meter will not work if you use an offboard charger the lights on the charger will turn green when it is fully charged. when the charger is plugged into the joystick and you turn on the chair the lights should scroll indicating you have the charger inhibit function working and hopefully the chair is charging. If you can charge the chair with the offboard charger then look into buying one and using it instead of trying to get the onboard charger working Hope this helps
Mar 04, 2011 | Jet 3 Ultra Power Chair
Don't run light go from left to right on a "Jazzy
carly that indication is the charging inhibit mode and the joystick still thinks the charger is still plugged in. Unfortunately there is no quick fix for this and usually requires a joystick or controller replacement. I would have your provider check it for you and maybe try another joystick from another chair to see if that fixes the error if it does then you'll have to replace the joystick. If Medicare paid for your chair then they will pay for most of the replacement cost Hope this helps
Nov 18, 2010 | Pride Jazzy Select 6 Indoor Power...
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
When i plug in the charger the led light stays on green but on the joystick the lights are moving back and forth as if it is charging but wheelchair does not move
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Sep 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Have an electric powerchair Aspire by Gurdin. The power level is blinking continiously and the chair will not move. Just went out all at once. What could be the problem? Thank You
Sounds like you have an inhibit problem. When you plug the charger into the joystick it keeps the chair from moving while charging. They can retain the inhibit mode because of a problem in the joystick itself. Now if you can count the number of flashes and there is a slight pause between the flashes that indicates a fault in the chair the number of flashes is a fault code and you should be able to look that up in your users manual Hope this helps
Aug 09, 2010 | Electric Health & Beauty
Pride victory and pride jazzy will not charge the batteries and when plugged in. The inhibit function seems to not be working either.
Bad charger port on joystick only fix is to replace joystick or if it has a seperate charger port underneath the jostick that has to be replaced
Aug 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Health & Beauty Logo
451 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
