Question about Kenmore 64192 / 64194 Top Freezer Refrigerator
It runs for 2 hrs. - Kenmore 64192 / 64194 Top Freezer Refrigerator
  • 31 Answers
Then within a half hour if comes back on?
completely normal.
its the defrost cycle.
Posted on Oct 07, 2009
How long should you run system
Always start high and work your way down...You want to maintain a 3ppm chlorine level..
Start by running a 12hr pump cycle with 10 hrs of chlorination... Check you chlorine level after 2 days and try to hit a target of 3ppm and after that, lower you cycle to maintain that level. For small pools, could be as low as 6 hrs pool pump, with 4 to 5 hrs chlorination??? I hope this helps you.. Good luck..
Aug 27, 2011 | Intex Automatic Salt Water System for ...
16 x 32 ft pool with saltwater generator. first pool. pools getting slimmy.
You are not running the unit long enough. Run your pump for 12 hrs and 10 to 11 hrs of chlorinator. Before you do this... Clean your pool and get the slimmy stuff out... Start with a clean filter and run the cycle i just stated. You should see results within 2 to 3 days...
Hope this helps......
Aug 04, 2011 | Intex Automatic Salt Water System for ...
My pool water has turned green in 2 days. I have an Intex pool with a saltwater system. How do I get it back to normal? I am new to the pool thing so you may need to put the awnser in laymans terms.
As long as you have the correct amount of salt and the electrolytic cell (The thing that makes the chlorine) , run the pump at 12 hrs with the chlorinatior at 10 to 11 hrs in between those 12 hrs for one full week and you will see results. Also, vacuum and clean your pool now before you start the 12 hrs cycles.
Jul 22, 2011 | Intex Automatic Salt Water System for ...
I purchased a Sears Counter Craft Crock Watcher crock pot at an Estate Sale, but there is no instruction booklet. It has low, high, and auto shift on the dial. Can you help provide some instructions for...
From a couple of different slow cooker manuals - most I looked at are the same:
When in the AUTO setting, the slow cooker will begin cooking on HIGH and then will shift to LOW after approximately 2 hours of cooking time. AUTO setting does not turn off the unit. Other favorite recipes may be adapted to the slow cooker. All times listed in the following chart are approximate and should serve only as cooking guidelines.
Regular Cooking Slow Cooker Cooking Times
1 (Low) 2 (High) AUTO
30 minutes 6-8 hrs. 3-4 hrs. 5-7 hrs.
35-60 minutes 8-10 hrs. 5-6 hrs. 6-8 hrs.
1-3 hours 10-12 hrs. 7-8 hrs. 8-10 hrs.
Sep 16, 2010 | Vacuums
My battery is good and i road it for bout 2 hrs then came to stop and now it wont stay running unless i jump start it
Have your battery load tested at a battery shop. You may have a broken cell . You can get the lights to work but the juice doesn't flow enough to start the bike. I suspect a broken cell in the battery.
May 14, 2010 | 1996 Honda CBR 600 F(3)T
Takes 2 hrs to run a 45 min cycle
defo a heating element fault or an ntc fault. More likely to be the element though.
Mar 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Compressor runs loaded continuously even in low/no demand periods
Each compressor should be checked several times per year as to length of time it takes to fill an empty tank to set pressure. This will provide chart of performance / efficiency. I believe that compressor #2 is not running to full capacity. If compressor # 2 is suffering from leaking valves or headgasket the head and air discharge temp will higher than compressor #1. Good luck!
Oct 14, 2009 | Ingersoll Rand Air Tools & Compressors
Error code hrs is blinking, frig is not running.
ERROR CODE HRS IS BLINKING, FRIG IS NOT RUNNING.
Aug 29, 2008 | Refrigerators
Kenmore 64192 / 64194 Top Freezer Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
