Zenith D52WLCD 52 in. Rear Projection HDTV-Ready Television
Problem for Zenith D52WLCD 52 in. Rear Projection HDTV-Ready...
Zenith model D52wlcd projection TV
By randymerrylo on Oct 07, 2009
zenith model D52wlcd projection TV
has been saying replace lamp for several weeks. Has had a small pink spot in middle of screen. Now full screen is pink. is this a lamp problem or just DOA?
Best Solution
posted on Oct 07, 2009
Very Helpful)
vinnyq
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 49 votes
The Lamp will no cause any color distortion. The "Replace Lamp" message comes up after a certain amount of hours after watching the TV because the lamp only last a certain number of hours before needing a replacement one.
It sounds like a light engine problem. There is no quick fix, you need to replace the whole light engine which is very costly (light engines usually run at least $500) and time consuming (need to take whole TV apart to replace part).
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks. My son also thought it was a light engine. You advise is very helpful! " - randymerrylo
Popular Solutions for Zenith D52WLCD 52 in. Rear
Questions and Unsolved Problems for Zenith D52WLCD 52 in. Rear
Do you recommend Zenith D52WLCD 52 in. Rear Projection HDTV-Ready Television?
Answer
Answer
I have a 65 inch 1080. We moved yesterday and when I turned tv on it shows red on lamp button, tv... (More)
Answer
tried the solution to reset the lamp counter on my d52wlcd zenith tv but but nothing happens. No... (More)
Answer
replaced bulb and still have yellow glow and blue dots in center of screen
Answer
TV was on, weather great, went to another room and heard a loud pop. TV had shut off. I tried to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zenith D52WLCD 52 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
