I want to remove the deep freez but still there
    Novelist:
  • 194 Answers
I found a suggested solution in Wikipedia under Deep Freeze. It says connect the hard disk to another working machine such that Deep Freeze is not initialized or running on the system. Then clear the remaining Deep Freeze code from the disk and replace it into your system.
Posted on Oct 07, 2009
How to remove deep freeze from my PC that has been downlaoded from the internet? please help
hi! you must look for the same version of your deep freeze on the web, then install to remove the old version of deep freeze.
Jun 30, 2011 | Cycling
How can i uninstall deep freeze
First disable deep freeze in next log on by pressing shift+alt+ctrl+F6.. Then restart your system. Lastly remove deep freeze in add/remove programe.
Apr 30, 2011 | Computers & Internet
How to remove deep freeze in the computer
Hi archie,
I see that you want to uninstall Deep Freeze from you computer, See steps below.
  • First open Deep Freeze.
  • On the Deep Freeze window click to select Thawed.
  • Then Click on Apply and reboot.
  • Once the system restarts back up you now go to the Add remove programs or programs and feature to uninstall Deep Freeze from your computer.
  • If you have XP go to control panel then select classic view on the upper left side then look fo Add remove programs then look for Deep Freeze then click on change/remove to uninstall the program.
  • If you have Vista or Win7 click on Start then control panel look for programs and features, this will show you all the programs you have on teh system just like add remove programs.
  • Look for Deep Freeze right click on it then left click on uninstall.
I hope that this will help you uninstall your Deep Freeze program from your system.
Thank you for choosing Fixya,
mvincent
Apr 25, 2011 | Computers & Internet
Yahoo.comHow to uninstall deep freeze 6 software from PC
Faronics Deep Freeze is a very powerful application, it prevents any unwanted changes on the system by freezing an entire hard disk or partition without restricting user access. Unlike older version, Deep Freeze 6 cannot be disabled or uninstall this Deep Freeze without password. Before u reformat or install a fresh OS, try the steps below, without password. 1. Boot yr PC from the CD with windows XP, if u have Windows XP OS 2. Now enter R to repair after booting. 3. Let it continue until finish 4. Now prepare the DeepFreeze to install, u will come across a option "Uninstall Deep Freeze", select this option and click next. After finishing the uninstall, reboot yr PC. 5. Now u will find that the Deep-freeze has removed from your computer.
Aug 25, 2010 | Computers & Internet
Remove deep freeze from computer
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Aug 19, 2010 | Computers & Internet
How to uninstall deep freez from my pc
If you cannot uninstall the application from "Add/Remove Programs" then you will need to get "Microsoft windows installer Cleanup Utility" from the M/S Website... install that, and remove deep freeze from the list that comes up when you launch the cleanup utility.
May 14, 2010 | Computers & Internet
How to disable deep freeze without a password
How to Uninstall Deep Freeze for Windows 2000/XP/Vista without the password.
Note: Without a complete uninstallation you may not be able to reinstall Deep Freeze on your system.
What we are going to do is edit the registry and delete the startup references to Deep Freeze. This will prevent the Deep Freeze driver from starting up the next time you boot. (c:\windows\system32\drivers\deepfrz.sys)
1. First we need a way to edit the registry. The way to do this depends on your situation. If your computer is thawed you can simply use Regedit. If your computer is frozen or if it doesn't boot you'll need to find another way. Here are some alternatives:
If you have a multiboot computer with another copy of Windows 2K/XP you can boot from there. Or, you can physically mount the disk on another computer that uses Windows 2K/XP.
You will probably use a tool that lets you boot and edit the registry. A good example of this is PE Builder that lets you build a Windows PE CD and boot Windows from there. Or use Bart's, http://www.nu2.nu/pebuilder/ or Winternals ERD Commander. There are several, including some USB memory sticks capable of booting like a CD. The goal here is to boot separately from your hard drive and access it while it is "asleep".
2. If your computer is thawed run Regedit. If it's not thawed follow one of the alternatives described above, and run Regedit (or Regedt32 on Windows 2K).
3. On the Find dialog box type UpperFilters and check only the Values checkbox. Then click Find Next.
4. The program will find a value with the name UpperFilters. Open this value and if there's a line with the name of the Deep Freeze driver (DeepFrz or DepFrzLo) delete it including the return, leaving the rest of the lines intact. Also, if you are using ThawSpace and you want to get rid of it delete that line too (ThwSpace), if you want to keep the ThawSpace leave it there. Press F3 to find the next match and repeat the operation until you have fixed all the UpperFilters values inside the HKLM\MySystem key.
5. Navigate to HKLM\MySystem\Select and check the value with the name Default. It has the number of the control set key that the system will use when booted. If it is 1 the control set is ControlSet001, if it is 2 the control set is ControlSet002, and so on. We'll assume the control set is ControlSet001 but you should use the one specified by the value Default.
6. Now go to HKLM\MySystem\ControlSet001\Services and delete the keys with the name of the Deep Freeze drivers (DeepFrz or DepFrzLo and DepFrzHi). Also, if you decided to get rid of the ThawSpace delete the key with the name of the ThawSpace driver (ThwSpace).
7. That's it. Now reboot and Deep Freeze will not load.
QUESTION: What if the BIOS settings prevent me from booting from CD or USB? Answer: Deep Freeze prevents you from decrypting the BIOS password, but it does not prevent removing it, if you have the right tool! Most of the BIOS hacking programs will not work to remove the BIOS password on a Deep Freeze protected computer, but CmosPwd by Christophe Grenier does.
You'll need to know how to use a command line and install the driver. Yes, it uses a driver to remove the BIOS password. But it works, even on Deep Freeze protected computers. Use CmosPwd to remove the BIOS password and reset the default BIOS settings. Then you'll be able to boot from CD or USB and edit your computer's registry and remove the DeepFrz, DepFrzLo, and DepFrzHi references which start Deep Freeze.
Now here is a little known secret: Faronics (the makers of Deep Freeze) uses a special driver to remove broken or malicious Deep Freeze installations. They do not have any backdoor passwords, so they use a special driver to remove a Deep Freeze installation where the password is not known or that someone is having trouble with. Will they send it to you, or even admit to you that they have it? I don't know. But, even if you do have it, you will still have to boot separately from the hard drive and replace the existing Deep Freeze driver with the special one and reboot. And after that, you need to use a Deep Freeze installation file to fully uninstall Deep Freeze (it will be thawed when you boot up with the special driver). If you want to re-install Deep Freeze, you'll have to first delete the special driver too.
Only a few people have this driver. It is the only solution Faronics has for those who need to remove Deep Freeze without the password. And, like I said, you will have to be able to boot from CD or USB and access the NTFS hard drive. If the boot-up order is locked (hard drive first and only) in BIOS settings, use CmosPwd to reset BIOS and boot order. Then you can boot from CD or USB.
Booting from CD or USB and removing the registry references works also, but then you should uninstall Deep Freeze with an installation file once you are able to boot thawed.
If you are dealing with a trial version of Deep Freeze, just forward the BIOS date past 60 days and then restart.
If anyone is wondering if Deep Freeze has ever been hacked, the answer is "yes" it has, several times over the years. Most of the time these were weaknesses that Faronics was able to quickly fix or prevent. However, there was one hacker that really, REALLY gave them headaches. His name was Emiiano Scavuzzo from Argentina. He was really good at low level programming and used OllyDbg to come up with about five versions of his "Deep Unfreezer" which gave Faronics their greatest challenge to date. Deep Unfreezer now only works on older versions of Deep Freeze.
Faronics is doing very, very well right now (as of 2008). They sold Apple Computer their Mac version of Deep Freeze, which, if you know how to look for it in the Applications folder on a Mac, is used in all the Apple Stores on both their desktops and their laptops. So, if you're ever in a Mac store playing around with PhotoBooth or whatever, and the computer settings are all messed up, just restart the Mac and thank Deep Freeze.
Apr 11, 2010 | Computers & Internet
While installing deep freeze my system rebooted and then some error happened. following which it kept on rebooting couple of times, so i used system restore setting to run it. when the system recovered i...
This is the coomon error of the deep freeze . I you can not access deep freeze then download deep unfreezer from http://www.brothersoft.com/d.php?soft_id=171878&url=http%3A%2F%2Fusfiles.brothersoft.com%2Futilities%2Fmiscellaneous%2Funfreeze_quicksetup.exe
Then disable deep freeze with out password after that use the same istaller to unistall the deep freeze which you have used to install .
Nov 02, 2009 | Computers & Internet
Deep freeze removal
You need Deep Feeze removal. Ask google for the same.
May 19, 2009 | Computers & Internet
How to uninstall deep freeze from your pc?
To uninstall:
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
