Question about Reddy Heater-10-12-15,000 Btu L.P.
Empire DV-210: Pilot light will light and stays lit, but when I
Empire DV-210 (w/thermostat): The pilot light seems to work fine. It lights and stays lit, but when I try to ignite the main burner, it will light but quickly blows out along with the pilot light.
  • Anonymous Mar 17, 2014
    pilot light will not light
    President:
  • 3,433 Answers
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Posted on Oct 07, 2009
  • rudyjoe Nov 08, 2011
    but yes your right if thats the case
    Problem Solver:
  • 18 Answers
Ummm, not thinking its that.
Since it does stay lit i'm thinking the rush of gas is blowing it out, i've seen it happen with no fault of the thermocouple. Could be a blocked/dirty pilot orfice or something close to that. just my thoughts on it...good luck!
Posted on Nov 08, 2011
  • rmcmurtry
    rmcmurtry Jan 11, 2013
    The wire coming out of the place where the termocouple attaches to the frame is connected to nothing. When should it be connected?
Empire dv-25. Pilot lights fine, good blue flame. Burner rail won't light or stay lit - sometimes it starts to catch. Orifice was removed and was clean - no debris. Not sure where to look next? T.Y.
Do you have an electrical meter that measures millivolts?This sounds like a millivolt system. The pilot orfice and pilot burner need to be clean so they are producing a hot flame, hitting the pilot generator to create enough millivoltage to open the main valve coil. If you know how to jumper the thermostat circuit try it, Millivolt systems will give you problems if there are loose connections or to much resistance through a switch. Again, there could be some type of safety switch that is wired into the thermostat circuit to prevent the heater from coming on if it isn't safe. Call a pro if its not obvious
Jan 01, 2017 | Empire Heating & Cooling
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Jan 14, 2015 | Heating & Cooling
My dv35 wall furnace pilot light on main burner will not light
lightly tap on the area where the wires are connected. the valve will stick at times. try that.
Oct 30, 2011 | Empire DV-35 Heater
Empire Hearter (old unit) Model # DU 215-7SG Pilot light goes on and stay on but the main burner will not ignite.
I notice that I have the same problem and the wire coming out of the frame on the outside opposite where the thermocouple attaches to the frame on the inside goes nowhere. Shouldn't that wire connecting to something? If so, exactly where is the point of attachement of that wire? It should control the opening of the main gas value somehow.
Richard
Nov 02, 2010 | Empire DV-35 Heater
Soupydf1@netzero.com My Empire DV-210-6sg, the pilot lights and I can turn on the unit, but it will not sense the themostat to heat the room. themostat tested fine. what is wrong
There is another sensor called a thermopile or pile generator that most likely needs replacing. Look for two wires connected to the gas valve that has a metal strip wound around the outside of the wire. This will go to the pilot assembly and controls the main burner.
Feb 01, 2010 | Empire Heating & Cooling
I have an Empire dv 210 gas heaterand pilot wont stay lit
The thermocouple has went bad Here is a link that describes what a thermocouple is how to replace it and has instructional videos
http://www.ehow.com/way_5185498_thermocouple-replacement-procedures.html
I could try to describe the procedure. But the link is more detailed and the videos are really good.
Hope this helps
Please leave feedback
Dec 11, 2009 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Pilot light wont stay lit
You need to replace the pilot safety switch which is usually a Thermocouple. It is connected by a thin tube from the gas valve to a bulb near the pilot burner. It should be available at Home Depot or online.
Ray
Dec 17, 2008 | Empire ECS HB06M HearthRite Heater
Empire BF-30-1 Main Burner problem
flame sensor,just take some fine sand and lightly sand,it will be where the flame hits one of the burners,should look like a probe,if this helps please give me a fix ya
Jul 11, 2008 | Empire Heating & Cooling
Pilot and burners
You need to check a couple of things, first is the flame sensor, second is the thermostat. Without anymore detailed info this is the most I can give you.
Nov 08, 2007 | Uniflame 200209 Open Flame Patio Heater
Heating & Cooling Logo
592 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
