Question about Philips GOGEAR SA6045 MP3 Player
Am I supposed to disconnect the device from the computer to turn it on?
    Problem Solver:
  • 7 Answers
Yes
Posted on Oct 07, 2009
Router disconnects computers from wifi requiring router reset
Go to settings and connection type and check maximum idle time is not highlighted! Sounds like it is timed to disconnect after a time limit from your description!
Jan 11, 2015 | Belkin (F5D7230-4) Router (587009)
Tip
Internet connection disconnects
If your ethernet card or wifi adapter disconnects when the computer goes into sleep mode, and the only way out is to restart the system, try this:
Open the Device Manager, under the Properties, Power Management tab for your ethernet card or wireless adapter, deselect the box that reads "Allow the computer to turn off this device to save power".
If other devices are sketchy as to how long they'll stay active, try the same trick:
Open the Device Manager, open every USB Root Hub, and under the Properties, Power Management tab, deselect the box that reads "Allow the computer to turn off this device to save power".
on May 29, 2015 | Computers & Internet
03 grand am wil turn over but not start after changing o2 senser
I suppose you could have disconnected a wiring harness some how.
The sensor only tells the computer if the fuel mixture is rich or lean, so the car would run with the sensor disconnected.
Does the check engine light come on when you turn the key switch on ? ?
Are you getting spark to the plugs ?
Jan 08, 2013 | 2003 Pontiac Grand Am
Error 210 Stuck key 69
Hello Scott,
Make sure that there are no objects placed on the keyboard, or
if you have one, the external keyboard. Turn off the computer,
and turn off all attached devices. Turn on the computer first;
then turn on the attached devices.
If an external keyboard is connected, do the following:
v Turn off the computer and disconnect the external keyboard;
then turn on the computer. Make sure that the built-in
keyboard operates correctly. If it does, have the external
keyboard serviced.
Make sure that the external keyboard is connected to the
correct connector.
Please feel free to ask me if you any further questions or concerns.
Also please rate me if you like my answer, that helps me alot.
Thanks.
Apr 19, 2012 | Lenovo ThinkPad R400 Notebook
Have never owned one so I want to make sure I am doing this stuff correctly. It didnt come with much of a guide.I plugged it in to my laptop to charge it then it automaticlly says ok to disconnect. when im...
If you are trying to charge it, and your computer says "OK to disconnect", then you can just ignore it. This is your computer telling you that disconnecting the device will not adversely affect the computer. If it's your MP3 player that is saying "OK to disconnect", I can only tell you that keeping it plugged into your computer via a USB cord will probably continue to charge it.
If you're unsure, disconnect it from the computer and see if there's an indicator for the amount of battery life remaining on your player.
I hope this helps.
Mar 06, 2011 | Audio Players & Recorders
How can I change the fan inside my computer? It's making too much noises
  1. Shut down the computer through the Start menu.
  2. Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
notice.gif NOTICE: To disconnect a network cable, first unplug the cable from your computer and then unplug it from the network wall jack.
  1. Disconnect any telephone or telecommunication lines from the computer.
  2. Disconnect your computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before opening the cover. notice.gif NOTICE: Ensure that sufficient space exists to support the open cover—at least 30 cm (1 ft) of desk top space.
  1. Lay the computer on its side so that the arrow on the bottom of the computer points up.
  2. Open the cover:
    1. Facing the back of the computer, press the release button on the right side of the computer with one hand while pulling up on the top of the cover with the other hand.
    1. Press the release button on the left side of the computer with one hand while pulling up on the top of the cover with the other hand.
    2. Hold the bottom of the computer with one hand, and then pull open the cover with the other hand.
caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before you open the cover.
  1. Open the computer cover.
notice.gif NOTICE: Before touching anything inside your computer, ground yourself by touching an unpainted metal surface, such as the metal at the back of the computer. While you work, periodically touch an unpainted metal surface to dissipate any static electricity that could harm internal components.
  1. Disconnect the cooling fan power cable from the FAN2 connector on the system board.
  2. Disconnect the power cable from the PWR connector on the system board.
  3. Lift up the airflow shroud.
caution.gif CAUTION: The heat sink can get very hot during normal operation. Be sure that the heat sink has had sufficient time to cool before you touch it.
  1. Remove the heat sink:
    1. Release the retention module clip by pressing in on the tab and lifting the retention module clip up.
    1. Pull the release lever out until the heat sink is released.
    2. Lift the heat sink away from the microprocessor.
notice.gif NOTICE: Lay the heat sink down with the thermal grease facing upward.
May 12, 2010 | Dell Dimension 8300 PC Desktop
Player not reconized
What operating system are you using? The Zen uses the MTP driver so if you have Vista or are running windows media player 10 or 11 the driver should be present and the device ought to be recognized. If not, check device manager for your zen device. If it's there, right-click and uninstall, disconnect your player and after a few seconds plug it back in. Windows should then reinstall your driver.
Jul 31, 2009 | Creative Labs Zen MicroPhoto MP3 Player
Alarm:68-107
That refers to a device connected to a port which is not supposed to be. Port 107 may have a fax machine or computer connected to a Norstar digital telephone port. Disconnect the suspect equipment immediately. Good Luck!
Sep 04, 2008 | NorStar M7324 Corded Phone
How Do I Charge my Sans Mp3 Player
Make sure you ran the install CD first
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Sep 30, 2007 | iLO (2 GB) MP3 Player
PROBLEMS!!!
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Mar 06, 2007 | Philips GoGear HDD1850 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
46 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
