Question about Sony Playstation 3 (PS3) Console
Frequent blank screen
I bought the new PS3 slim last Sep 3 and it was working perfectly until Sep 28 when it started to have blank screens (no video and no audio). Initially I thought it was an overheating problem, so I rested the console. The next few days, I will try to play or watch a movie but after 10-15 mins the blank screen shows up again=(. The PS3 has still the green light on, no red light, no blinking... I can see the HDD blinking orange. I most of the forums regarding blank screen but still cannot find the answer. I tried the HDMI and composite connection, same story, the screen blacks out but the console is still running. I tried resetting the video outputs, turning on and off the TV still not working. Please help!
  • 18 Answers
SOURCE: Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Posted on Aug 19, 2007
Benimur
  • 6966 Answers
SOURCE: PS3 with no video / no audio
Hi and welcome to FixYa,
Initially, the blinking controller lights indicate that it is charging. If it is continuously doing so, might it not just indicate that the battery requires replacement since it will not longer accept a charge. The average charging time would be about an hour and would be indicated by the absence of the blinking light(s) on the controller.
To verify, when the PS3 displays the startup screen, pls press the PS button (middle of the controller) on the top right hand of corner of the screen, battery status of the controller would be displayed. if the display shows running/changing mnumbers 1,2,3,1,2,3,1,2,3, then the controller is charging.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 29, 2008
SOURCE: Playstation 3 Does not display on TV using HDMI or regular video
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Posted on Jan 12, 2009
  • 7 Answers
SOURCE: My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
Posted on Jul 06, 2009
rwss
  • 178 Answers
SOURCE: ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Posted on Sep 03, 2009
When i turn my ps3 on there is no display on the tv and remains blank. i have bought a new HDMI cable and it still doesn't work?
Try holding down the down the power button until you hear one beep then it should come up with a message saying that a hdmi cable has been detected and just follow the on screen instructions.
Sep 17, 2010 | Sony Playstation 3 (PS3) Console
My new ps3 slim doesnt display on tv
Well, after seven months I hope you have gotten this issue resolved, if not it sounds like your tv isn't on the AUX channel. Try switching your input to AUX. It should fix the problem
Mar 09, 2010 | Sony PlayStation 3 Slim Black Console
My screen is blank and the contollers won't sync up
Sounds like it may be a video problem. Try reseting your system:
1. make sure the system is off
2 hold down the power button for 5-6 seconds, until you hear a second beep
You should be able to use it.
If that doesnt fix it, please let me know the serial number on your ps3, how you are connecting it to your tv (composite, hdmi etc) and the last time it was working and what you have done since.
Dec 05, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turns on with green light an doesn't show users screen blank
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is showing a blank screen.
if you barly bought it then return it and get a new one because it was dropped when they ship it
Apr 03, 2009 | Sony Playstation 3 (PS3) Console
No video output
well it might be the tv you are using because this happend to me but when i bought a plasma tv with built in hd it started to work perfectly.
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
61 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
