Logitech speakers i accedently pushed in the cone in the speaker. the speaker isnt mine so i was wonderimg if there is a way to fix it. can i take it apart and push it out? please help
  • 26 Answers
Lanailic,
I am wondering if you are talking about the metal grill that covers the speakers. If so you might try to pull the dent outward with a strong magnet but make sure that the maget is covered with something that won't scratch the paint of the grill. The grill might be made of aluminum and if so the magnet method won't help you.
For aluminum you might try making a hook out of a thick paper clip and pulling the middle of the dent out carefully. If you try to take it all apart I would guess some parts are glued or stapled and you will just get further in trouble trying to take it apart. Its worth a carefull look but do it like a surgeon and remember where all the little screws and staples and tape goes when you put it back together. Perhaps you could send a photo..?
Good luck.
Posted on Dec 24, 2007
Fix a torn speaker cone?
If it is a woofer, you would probably fix it quite easy. If the speaker driver is used for both bass and midrange, you have a problem.
Fixing a speaker cone is depending on the material. If it is paper cone, it is very easy by using paper that you glue with wood glue (White water based glue) on to the cones rear side (for estetic reasons).
A midrange or bass/midrange driver is operating in frequencies where the cone starts to break up. Not torn apart, but the break up frequency is the frequency where the inner and outer part of the cone not longer follow each other in the same direction. These properties of a cone determine the sound of the speaker which is that type of speaker drivers "identity". Messing that identity up, you end up with a speaker that does not sound as the original one.
Remember that cross over network used to split up frequency ranges, not only are lowpass, bandpass, and highpass filter, but they also filter irregularities where the speaker driver is not longer providing a linear frequency response (Its characteristic sound).
If the cone is polypropylene, there isn't much glue that bite on that material.
May 02, 2016 | Audio Players & Recorders
How can replace the speaker the bass sound is broken
Dear Rob,
Really Thankful for the detailed description for the Speaker Repair.
It really helped me a lot. I have a unusual situation here with me. I have dissected the whole console and found the outer band of the speaker has just come off....have attached photos to make it clear. does the outer speaker cone will make a difference or i will have to replace the speakers itself.....when i checked pressing the speaker down and played the distortion had gone....but while playing without holding the distortion would come back....Hope you can help me in this situation....Thanks in Advance..... 714812a0-935e-4f95-922e-50c6ba281b9c.jpg 36e62701-6370-491a-a317-a11c69cc9525.jpg
Jan 13, 2013 | Harman Kardon Go + Play Portable Speaker...
SUB WOOFER CONE SPLIT LOGITECH Z5500 REPLACEMENT CONE
you should just buy a replacement speaker and install it, replaceing the cone would not be cost effective, in fact you could buy a better speaker and get better bass out of the sytem, try www.martinsoundproducts.com they are in Cleveland and sell many great speakers in all sizes.
Mar 19, 2011 | Audio Players & Recorders
Logitech OEM S220 2.1 Speaker Black Computer Speakers i just bought off amazon and i cant hear no sound i have put the colourd plugs into the right colour holes but still no sound...i have a laptop i hope...
1. there is an on switch on it, on the round thingy
2. try using an ipod or mp3 player to test, and only plug in the green wire
3. Make sure the volume is in mid range by turning the knob to the middle
4. Check connection to subwoofer
5. that's all I got, maybe it was not meant to be. But the sound on mine is pretty good :)
Nov 02, 2010 | Logitech OEM S220 2.1 Speaker Black...
Logitech THX Z-2300 only one speaker works. theres something wrong with the input. both speakers work fine but the 1 of the inputs on the subwoofer stopped working, causing only one speaker 2 work
try tapping the speaker box in your palm while the speaker is connected. There might be a bad contact of the wires inside. I had to open up my speaker to find that out. i moved around the wires connected to the cone of the speaker and then started to hear music once i did that. it was the left speaker by the way.
Jan 23, 2010 | Logitech Z-2300 Computer Speakers
When I push my subwoofer cone its work and when i release it stops working. how can i fix this speaker? the make of this is 12'' 1210 Watts Infinity sub.
Looks like a broken copper braid that links the speaker terminal to the cone (from there on it goes to the coil which is underneath the cone).
Check the speaker connection terminals (near the magnet), you will notice that each terminal has a copper braid wire going from that terminal to the speaker cone.
Inspect both braid wires carefully at each end (near the speaker terminal and near the speaker cone), there will either be some damage to the braid at one or more of these four locations or the braid could be actually broken at any of these spots.
The braid can actually be resoldered at the point where it's damaged or broken - this task will require good soldering skills, mainly because this kind of braid wires are difficuld to solder (they are a bit difficult to clean because of their structure and solder won't attach itself well to oxydized copper), but also because some speaker cones are made of plastic which may melt if you overheat it with a soldering iron.
Besides that, when resoldering is being done, only a very short portion of the braid should be wetted with solder because the solder point will become rigid when the solder cools down, and the braid needs to remain very flexible when the speaker operates (if it's too rigid or too short, damage to the speaker cone could occur or the braid could get broken again when the speaker will be playing at a loud volume).
Hope you can have it repaired, it can be done at home, but there are also speaker repair shops where you can get it done (i'm not sure about the prices though).
Anyway, the alternative is to replace the speaker itself.
regards
3rq8 (Triarcuate)
Sep 09, 2009 | Infinity PS-12 Subwoofer
Z-2300 Left Speaker and port dont work
did you try plugging in the other speaker into the yellow output. If you can hear music doing that then its only your left speaker that is the problem. Try tapping the faulty speaker into the palm of your hand while connected. There might be a faulty contact to the actual cone of the speaker. I had to open mine up because i had the same problem. It turned out that it was the wires that weren't making contact. I scrapped and moved them around connected the speaker and it worked. I hope that i made some sense out of this. good luck.
Sep 06, 2009 | Logitech Z-2300 Computer Speakers
I have a logitech Z2300 and one of the speakers is damaged. I want to replace it but Logitech says I can only buy the complete system; where can I find the speaker only?
It may prove difficult to replace an individual speaker.
If it is a std size cone you could have a look around the thrift / second hand shops to see if you can find one that might fit in it.
You would also have to make sure it is the same impedance and wattage eg 8 ohms x 20 watt or 16 ohms x 10 watt etc
Aug 27, 2009 | Logitech Z-2300 Computer Speakers
6x9s cone not working!
can you swap speakers with other one?if so do this and if speaker still sounds bad it is definately the speaker. there is really no way to take speaker apart and repair
Oct 02, 2008 | Infinity Reference 6412cf Coaxial Car...
158 people viewed this question
 Grubhead
Grubhead
