Question about Xante FilmMaker 4 Printer
I had to get a new mac, and of course, the new OS snow leopard does not support xante and i can only get ip printing to work but it will only print letter pages, in portrait, I need to print full size on my filmmaker 4, Please help!
4 Suggested Answers
rooboy
  • 24 Answers
SOURCE: Stretched Printing of Photos and graphics
ok, the issue is most likely technical, but fixable with a mouse click.
your MAC, is most likely running a pc prossessor version.
this causes mis inter[pretation of pc based files and comes into play with CS3 programs..
go into the mac hard drive, and select the appliaction (in this case In Design) go the the info page, and click on "more info"...you should see a check box for "rosetta". check this box. and then print again, problem should be solved....is so, go into all the CS3 applications and do the same..check the rosetta box...good luck...
Posted on Dec 08, 2008
SOURCE: Will Accel-a-writer 4n work running Leopard 10.5.6?
Just download the PPD Installer from here: AW4N_OSX then install the driver. Use System Preferences -> Print and Fax to create new Xante Printer using Default or Apple Talk section of Control Panel.
Posted on Jan 16, 2009
SOURCE: Unable to get Xante printer to work
Have you tried pinging your print server from your Mac? If you can find the IP address of the printer ping successfully, you know that your computer can access the printer.
Then, under System Preferences, choose Print & Fax.
Select the Xante printer name, choose "Options and Supplies"
Under "Options and Supplies" make sure that your printer settings match the ping settings (IP address).
Posted on Feb 26, 2010
Hp color laserjet 2550l need driver for my mac
Sir/Madam
The latest HP printer driver for devices listed below are built into Mac OS X 10.6. You do not need to download or reinstall any HP software for full printing functionality.
HP LaserJet print drivers are included in Apple's Mac OS X 10.6 Snow Leopard DVD and also available via Apple Software Updates.
Please Visit official HP Printer website Below Link URL:
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01844302-4%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N1000E
Snow Leopard - HP LaserJet printer setup instructions
  1. Upgrade install from Mac OS X v10.4, 10.5:
If updating a Mac using the Snow Leopard DVD, the install process should automatically detect your previous HP printer queue, delete, and then create a new HP printer queue using the latest HP printer drivers included in Snow Leopard.
USB printers:
  1. Make sure printer is turnedOnand connected.
  2. Open a document to print, and then choose File , Print .
  3. Open the Printer pop-up and choose your printer.
  4. If you don't see your printer, choose Add Printer , and then selectMore Printersbutton.
  5. In the Name column, select the printer, then clickAdd.
Network printers:
You can connect to HP printers on your local network that use Bonjour, IP, and Open Directory, as well as shared printers connected to an Apple Airport base station.
NOTE:Apple does NOT support AppleTalk in new Mac OS X 10.6.
  1. Choose File , Print .
  2. Open the Printer pop-up menu and choose your printer. It may be in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu.
  4. A dialog appears listing any Bonjour, IP, shared, and Open Directory printers on your local network. It may take a minute or two for your printer to appear.
NOTE:On larger networks, outside the Bonjour link-local network, your printer may not show up in the list. You can connect to the printer using IP. An IP printer is a network printer that uses TCP/IP protocol (such as JetDirect, LPD/LPR, IPP) to communicate with your printer. You need to know the IP address or DNS name.
  1. Click IP in the toolbar.
  2. Select HP Jetdirect - Socket in the Protocol pull down menu.
  3. Enter the printer's information available from printers front panel or printers network configuration page.
  4. The system should automatically bind to the HP print driver in thePrint Usingpull down menu.
  5. ClickAddto create the HP printer queue for your HP LaserJet.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays, duplex unit, or extra memory. If it can't, a dialog appears that lets you specify them. Make sure the settings in that dialog accurately reflect your printer's installed options to enable full functionality.
  1. Clean install of Snow Leopard or setting up a new Macintosh with Snow Leopard already installed:
If configuring a new Mac running Snow Leopard or if performing a new or clean install of Snow Leopard:
For USB connected printers, the install process should automatically create a new HP LaserJet printer queue using the latest HP printer drivers included in Snow Leopard.
For network connected printers, follow steps below.
USB printers:
  1. Make sure that printer is turnedOnand connected.
Network printers:
Or
In Case You Have Still Problem Then Please Foll Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet Office Equipment & Supplies
Can't get a Canon LBP6000 to print wirelessly on Mac system running Snow Leopard
Not all printer are compatible with Mac and this one is one of them, sorry.
Jan 12, 2014 | Canon LBP6000 Laser Printer
HOW TO CONNECT MACBOOK WITH SNOW LEOPARD MAC OS X
try using the generic drivers. in Print & Fax, click on options and supplies, click on the Drivers box and type in GEN.. and choose the Generic drivers. Hope this works.
Feb 09, 2010 | Samsung SCX-4100 All-In-One Laser Printer
I have a Mac w/Snow Leopard. I cannot get to hp.com\support to download drivers for an Office Jet 7780. The Mac recognizes it as a printer but not as a scanner.
As from this link , the drivers for most HP printers are already built-in to Snow Leopard. Thus, they didn't recommend reinstalling driver from your HP printer CD. Here are some excerpts regarding scanning feature on Snow Leopard from the link: Scanning: The Scanning interface is now built into Snow Leopard and supported with the Apple Image Capture application. Instructions follow. NOTE: HP Scan Pro software (from Mac OS X 10.4, 10.5) is not supported in Snow Leopard. The HP icon for HP Device Manager still in the dock after upgrade is not functional and should be removed. NOTE: Scan support from pushing the Scan button on the printer is not supported with this version of the scan interface built into Snow Leopard. Scan functionality is supported by scanning directly from the computer.
** there are methods on how you can scan on Snow Leopard from the link that I've given above. But I'll paste here Method 3:
Method three: Scan from Print & Fax > Printer browser
  1. From the Apple menu, choose System Preferences .
  2. Click Print & Fax .
  3. In the list of printers on the left side of the dialog, select the HP All-in-One to view the options in the Print & Fax window.
  4. Click the Scan tab, and then click Open Scanner . The Printer Browser window appears.
  5. Click the Scan icon at top right of the toolbar to launch scanning. The scan interface opens. Click Show Details to view settings and options.
Important Gotcha: If the Scan or Print icons do not appear in the Printer Browser window toolbar, you need to delete the current HP printer queue and add a new one, as follows:
  1. Close the Printer Browser window to return to the Print & Fax preference pane. Or, go directly to the System Preferences > Print & Fax pane.
  2. Select your HP printer in the list on the left.
  3. Click the - sign at the bottom of the list to delete the product from the list.
  4. Click the + sign at the bottom of the list to add the product back to the list.
  5. Select your HP printer, and then click Add to create a new print queue. The next time you open thePrinter Browser window, the Print and Scan icons should appear in the toolbar, providing access to Image Capture.
Oct 22, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Installed mac osx 10.6.1 and my fuji wont print HELP!
Some manufacturers have not caught up and updated their drivers for snow leopard yet.  You gots ta be patient and wait a couple months or call the manufacturer and ask for a comparable driver that will run off snow leopard. Go back to the previous OS if that was working your printer.  Don't fix it if it ain't broke.
Oct 12, 2009 | Apple Mac OS X 10.4 Tiger for Mac
Is there an update for Print explosion deluxe 2.0.2. not listed here! I have an Apple Mac OSX 10.4.11 and am finding my programme very slow when changing anything. Please help me. Frustrated user
For users of Print Explosion Deluxe 3 on a Mac, Nova Development has acknowledged that the software has bugs running on Leopard or Snow Leopard. The software does crash after each operation if you do not save. I filed a complaint with the NYS Attorney General's office, to which Nova's reply was not honest Contact your state's Attorney General and let them know that Nova is selling software that has basically been sitting on store shelves for two + years, and they never tested it with Leopard and Snow Leopard. They should be required to accurately tell us what OS a software product runs on.
Sep 05, 2009 | Nova Development Print Explosion Deluxe...
Jan 02, 2009 | Xante Accel-a-Writer 4N Laser Printer
When I send a job to the printer via Ethernet, nothing happens on the printer. I only get a solid red light. Why?
This is an indication of a media size mismatch. Make sure that the correct media size is set on the tray to which you are printing, and try the job again.
(from http://www.xante.com/support/aw1200/)
John
(Xante ASA)
Nov 19, 2007 | Xante AW 1200 Laser Printer
Xante FilmMaker 4 Printer Logo
77 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
