Question about Miele CVA615 Espresso Machine
It say brew unit missing - Miele CVA615 Espresso Machine
    Problem Solver:
  • 9 Answers
The brew unit missing switch is inside the slot at top back wall where the top of the brew unit puts an angled piece of plastic into the slot. The piece is a slope like a nose so it gently pushes the switch as you instert the brew unit. See if the brew unit reaches this slot on the wall. If it doesn't the brew unit most likely jammed up and was removed while the gears were not in home position. Now the gears are not allowing the brew unit to return fully inserted.
If you're handy you can call Miele tech support and request they walk you through steps to diagnose this. They will discover if the gear is out of home position or not. If it is not and the switch is in contact with the brew unit you may be in luck, the swith is cheap. But if the electronics no longer reads the switch signal it's 800 bucks to replace. Good luck!
Posted on Oct 19, 2009
I called the miele hotline support, they told me to remove the waste-unit on left hand side and then move up and down the "lose parts". Reboot the machine, pull the cord, switch it on and hold your thumbs :)
It worked for me!!!
Posted on Mar 15, 2011
  • 31 Answers
There is actually a brew unit present switch.
that could be your problem.
either that or a bad electronic.
hope you got like 800 dollars to throw on a 3000 unit.
Posted on Oct 07, 2009
Brew unit miss
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed (food grade only), so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Apr 21, 2011 | Saeco Royal Professional Espresso Machine
Brew unit missing
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Aug 27, 2010 | Saeco Magic Comfort Plus Espresso Machine
The display my machine says "Brew unite miss" what it means? How can I fix this?
Hi Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Feb 12, 2010 | Saeco Royal Professional Espresso Machine
W/o manual I have a brew unit miss message?
Hi
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Jan 03, 2010 | Saeco Royal Professional Espresso Machine
Cleanded brew unit as instructed - brew unit miss error
check small switch behind brew unit in machine maybe your brew unit dont touch switch.
Aug 30, 2009 | Saeco Royal Digital Plus Coffee...
Machine states the brew unit is missing when it is fitted
try pushing something which swivel up and down on the right hand side of the brew unit. once done it seems to fit back in properly, it did for me
Jan 04, 2009 | Gaggia Titanium Espresso Machine
Brew unit missing
Make sure the unit is seated properly, if any part flew off or out, it can be replaced at www.partsguru.com
Oct 13, 2008 | Saeco Magic Comfort Plus Espresso Machine
Brew unit missing?
Make sure the brew unit fits in place, press the "press" button when you put in the brewunit.
Let me know if it works.
Aug 06, 2008 | Saeco Magic Comfort Plus Espresso Machine
Brew unit missing
post your email i will send you the guide that shows you how to properly install the brew head
May 30, 2008 | Miele CVA615 Espresso Machine
Brew unit
Make sure you have brewing unit in start positions, if you have a press on your brewing unit make sure to press it to you hear a tick, then you can fit it in the machine.
Mar 02, 2008 | Saeco 762111651808 Espresso Machine
Miele CVA615 Espresso Machine Logo
783 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
