Question about Kenmore Refrigerators
The light bulbs (originals) in the control panel became very hot. The sockets are brown and the panel melted so it is now hanging by the wires. Also, the back of the freezer is constantly covered with ice needing defrosting. The refrigerator is only 2 years old. Model number is 795.7730 or 795.7731. What do we do?
    Guru:
  • 1,326 Answers
You have either a blockage in the cooling system for the icing issue or is low on refrigerant. As far as the control panel, if its getting hot to where its melting you have a short somewehere, If only 2 years old may still be under warranty ad I would definitely call Kenmore about that one and if your fuss enough and have them believe you won't buy anymore of their products and will tell people not to buy them they will sometimes repair/replace the appliance...
Posted on Oct 07, 2009
Sonata tail light socket melted. attempting to replace with after market socket. red, green and black coming form vehicle.
If you have a test light or voltmeter, turn park lights on and find the one wire on vehicle that is hot-it will almost surely be red or green, as the black is surely the ground wire. Now on the new socket, you need to know this: If those bulbs are two filament bulbs (one filament for park lights, and the other filament for brake or turn or both) the brake light and the turn light will be brighter than the park lights. You can tell the difference in brightness, and the brake lights are always brighter than the tail (or park) lights.
How many bulbs are on this socket? Do you have 2-filamet bulbs or just one filament bulbs? Maybe you can figure it out by looking at the other side, see how or which lights are for tails and which for brakes.
Feb 15, 2018 | Cars & Trucks
Brake light failure
Bad circuit board tail light asseblise connector pin to board poor connection or burned push in light bulb sockets
On my '93 Chevy PU the new ones went bad within months I repaired the original ones by soldering all connector pins to the board cleaned the sockets chipping out melted plastic been working for five years now.
Care must be taken to keep solder from preventing wire connector install while using enough that plugging it in will not break these delicate unions.
Required pulling them several times to Finnish repair successfully.
Very disappointed in replacement parts.
Apr 22, 2016 | 1987 Toyota Celica
Head light not working I see two brown wires are hanging
Hi, Anonymous if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply to headlight bulb socket.
2. Faulty hi/lo beam switch.
3. Faulty ignition switch.
4. Fuse is good but no continuity on both sides.
5. Faulty wiring between battery positive and headlight bulb socket.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
Taotao ATM150 Evo scooter headlight troubleshooting and bulb replacement
How To Replace Headlight On Jonway Scooter
DOWNLOAD Bajaj Pulsar DTSi DTS UG 180 Service Repair Workshop Manual...
http://www.marutibajaj.com/pdf/Pulsar%20180%20ug3.pdf
http://ondoc.logand.com/d/1735/pdf
Apr 24, 2014 | 2007 Bajaj Avenger 180 DTSi
Where can I purchase the light plug for the trunk brake light on a 2008 dodge avenger
junkyard or dealer if you want the original part; or most parts stores have bulb sockets which can be installed but might look a little different.
Mar 07, 2013 | 2008 Dodge Avenger
Both bulbs on my 2002 S10 Blazer licence plate was burned out I replased them with new bulbs and they will not come on and I have checked the fuses what could be the problem?
you need to check for power and for ground at the lightbulb socket to determine which is not contributing to power the bulb(s). If the marker lights work at the rear then suspect a broken/melted light bulb socket, broken wire, or broken/rusted ground connection. Again, check at the light bulb socket for ground on one side (black wire) and 12V (brown wire) on the other. The light socket should have terminals that actually touch the light bulb; sometimes the sockets will melt not allowing a good connection. a cheap harbor freight multimeter (VOM) will help. Right and left side use separate fuses
Jan 13, 2012 | 2002 Chevrolet Blazer
My taillight (rear - passenger side) is not working - the other one on the driver side is. I change both bulbs in the non-working on (bulb #1157) and the tail light is still not working. What do I do...
Check the bulb socket. They get really hot and heat can cause the wires to melt solder holding them in place. If you have a test light, probe the socket pins for power,(light switch on). If none on either pin, then probe the wires an inch or so back from the socket. If wire(s) have power replace socket. If not, and even if you find power on the pins but the lamp doesn't work, then also check for a bad or loose ground wire.
Aug 21, 2011 | Subaru Legacy Cars & Trucks
Replace headlight on a 98 springer. or replace socket that bulb plugs into. black wires have melted part of socket. replced the bulb.headlight still works. one black wire is just hanging there i taped it...
The black wire is the ground wire. It should be connected to the headlight housing or the triple tree somewhere. The yellow wire is the low beam and the white wires are the high beam and high beam indicator light. I'd purchase a new headlight "pigtail" and rewire it before you have further problems.
Apr 04, 2010 | 2000 Harley Davidson FLSTS Heritage...
I have a 1997 lincoln mark viii lsc has no tail lights no left turn signal, no left brake light. Right turn signal and brake light work fine. New multi-function switch (no fix) bulbs fine. Any ideas would...
inspect all of the sockets that the bulbs plug into. you may have a short in some of them. they can get hot and melt the plastic sockets. causing the bulbs not to work. or try replacing the wiring harness for all the rear lights. i found one in the junkyard for my cougar. and it works fine now, good luck
Mar 09, 2009 | 1997 Lincoln Mark VIII
Halogen bulb melted the socket
most likely a bad socket. if it were bad wiring the problem may have occured somewhere else in the range..
Jan 20, 2009 | Jenn-Air JXT8136ADS Kitchen Hood
795.77573600
I just saved my fridge / home too, smelled what I thought to be an electrical fire when I opened the Trio doors, immediately looked at the bulbs as a probable cause, and sure enough, the base of the bulb sockets were burned-brown and the plastic housing was to hot to touch without a hot-mit.
Unscrewed the bulbs and set aside out of children's reach and combustable materials.
I'm filing a complaint and service repair today. 8/3/08
Sean-Jon
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
20 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
