Question about Traulsen Reach in Freezer - G22010
There is no power from the relay module for the evaporator fans. there is power to the module- compressor is working. I just don't know what tells the relay to allow the power to the evap. fans. the fans do work
  • dalehardy422 Oct 07, 2009
    g22010 is the model #
    and where is the fan delaly? A new relay module was put in the unit and still did not work.
    Brigadier General:
  • 3,614 Answers
It could be only the relay or the evaporator fan as a who;le has a problem.
Posted on Oct 07, 2009
  • 612 Answers
It comes from the fan delay. I would think it's bad from what your telling me. It is either that or the microprocessor It has a 1 year factory warranty.
The fan delay controls function upon termination of a defrost cycle is two-fold. First, to prevent blowing warm air into the food storage area. Second, to prevent any condensation on the defrost coil from being blown into the food storage area. The microprocessor control is set from the factory to terminate defrost at 20 minutes in the event of a sen- sor failure. This setting should never be tampered with, without first consulting the factoryIf you would like more info you can call Traulsen Service at (800) 825-8220. If you can give me a model number, I'll be glad to try to help you more but if you need a wiring diagram, you will have to call company service at the 800 #. .
Please rate solution
Arctic air freezer
motor humming is from 2 things
start / run capacitor is failed
compressor is seized and the motor is not turning
call in an technician for a proper diagnosis and quote
Jul 08, 2016 | Artic Air Arctic Air F22CW12 Commercial...
Cooler don't keep temperatur at 36 to 38 evaporator frozzted
Your model number on the body of the freezer will have that. You can also get size of comp. and fan and rotation located on the pieces itself.
Feb 13, 2013 | Traulsen ARI332LP-FHS 208 - 3-Section...
Delay on evap. fan sistm.404a
Give the evaporator a chance to get cold, then check you've got power to the fan, via the evaporator thermistor and door switch
May 02, 2012 | True Freezers
I have a True Cooler GDM-35SL-RF. the fans are not working but the compressor is. What can I do to fix this and where on the cooler would I find the problem?
They have a support line here:
http://www.truemfg.com/24HourTech_en.aspx?language_id=1&event_id=401&from=food
Our Technical Service department is available via Internet or phone
Monday - Friday 7:30 AM - 5:30 PM CST and on Saturday 8:00 AM - 12:00 PM CST.
Via phone please call 1-800-325-6152 and ask for the Service Department
You can also use the page to ask any questions. I suspect you have a fan relay that has failed as the fans should be running anytime the compressor is running. Since all of the fans are not running that leads me to think it is a relay problem.
One thing to need to make sure is to verify that all fans.. condenser (bottom of the unit) and evaporator (inside the unit) fans are not running. If the condenser fan bottom of the unit is running and the evaportar fans are not running it could be something as simple as a door switch that has failed. Call them during business hours and I am sure they will tell you what the remedy is.... and of course.. do their very best to ensure they get to send a repair tech your way.
Thanks for choosing FixYa,
Kelly
Sep 04, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Clicking noise in the circuit board and everything in the freezer is thawed
Hi. this will be a failed relay on that circuit board. This is called the PCB(main unit power control board). This board controls the compressor relay functions, and the compressor power current, as well. The evaporator fan, and condenser fan, receives their respective current from this power control board, also. When a circuit board of this nature begins to malfunction, it will cause the unit to not cool properly, due to limited, or no fan actions, or a failed compressor cycle. I would recommend to replace this damaged control board, asap.
Dec 04, 2009 | GE Freezers
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
My slush machine wont freeze
the first thing i would check depending on your make and model is ensure the compressor is running
if not check the overload and relay pluged in on the side for continuity
then make sure your cooling fans are working
this should be a good first step but let me know
if not let me know the make model and ill take a look at the scematic
Oct 24, 2009 | Grindmaster Freezers
Evaporator fans have no power from the relay module
Make sure there is power to the relay. If you have power to the relay but no power coming out the relay needs replaced.
Oct 07, 2009 | Traulsen Reach in Freezer - G22010
T-23F FEERZER
fan burnt or relay fauly or fuse blown
Mar 10, 2009 | True 23 cu. ft. / 651 liter Commercial...
Cold tech commercial reach-in freezer
sounds like an issue witrh the microprocessor to me as well, although you tried bypassing it it still didnt work its quite possible that the fan aand compressor are runnig on different voltagfe the 110v , new energy effient compressors are starting to run w/ 220, an inverter built into the circuit board could be steppin up power,
Apr 08, 2008 | Freezers
Traulsen Reach in Freezer - G22010 Logo
42 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
