Question about Ulead Videostudio 8 for PC
Easycap002 on windows vista
I am trying to install easycap on my new laptop. I am running vista and I have mcafee. i install drivers and then the software. after install is all done i go to open easy viewer i get an error that says "Not found valid video capture device"
  • 17 more comments
  • Anonymous Mar 05, 2008
    "NOT FOUND VALID VIDEO CAPTURE DEVICE" AS WELL...I ALSO HAVE WINDOWS VISTA...
  • Anonymous Apr 05, 2008
  • jackhole Apr 26, 2008
    same prob here only it says that the software is expired and i need to check the licence key? wtf?
    As for all 4 channels at once.. use snagit with easycap. It should do exactly what you need.
    I still have yet to get my software working grrrrrr.
  • Kola Bello May 24, 2008
    To fix the issue, click on property,Video Proc Amp tab, click on the drop down menu and select NTSC_M for color, NTSC_M_J for black&white. It should work. The only issue I'm having is compression rate.
  • Anonymous Aug 19, 2008
    el problema es similar
  • revosute Aug 19, 2008
    hola necesito ayuda de alguien que hable en espanol
  • Anonymous Sep 03, 2008
    had same , was not compatible with Vista, put it on XP works great,apart from the compression
    had same prob, not compatible with Vista, works ok on XP. my problem now is compression, 30 min clip takes 20 GB hard drive
  • fire_beam Oct 06, 2008
    Also me, I have this problem.
  • tjordan_08 Oct 14, 2008
    my problem is i lost my CD and cannot install the driver correctly. i got the driver off the altnux website under H71
  • Anonymous Nov 11, 2008
    hi my easy cap works fine on xp.But on my laptop with vista basic ,,no joy ,itwont accept the driver and quarantines it,then it tells me :no video device found,,what are my chances before i go grey...Help
  • Anonymous Feb 07, 2009
    same : (
  • wallyutah Feb 10, 2009
    I have a two computers in the one, One with XP and one with Vista. The Easycap works on the XP but not on Vista. I get sound, but no picture. The capiture devise does not show up, and the install page shows that the device install failed. Is there a web site with another driver for the capture device that will work with Vista?
  • blackBoy1980 Mar 02, 2009
    i can use 2 easycap 4 channel for 8 camera
  • Anonymous Mar 02, 2009
    I have the same problem. I ordered the easycap from ebay that says it is compatable with vista dc60 ver2.1c but I still can not install the driver on my vista laptop.
    What can i do? anybody?
  • 8749michelep May 20, 2009
    Hello. I wanted to know if you know how to configure a EasyCap 002. In practice I can not configure SMTP Server. I put the server out of the mail in my case out.virgilio.it, then also enter your username and password, but when I try to test me says test failed. Could you help me somehow? Thou I'm very grateful!
  • Anonymous May 24, 2009
    me too.
  • sammyjod May 11, 2010
    vista drivers for easy CAP device
  • Harsh
    Harsh Dec 30, 2012
    For this You Have To Go to Devices And Printers in Controle Panel Then Click on USB 2.0 Video Capture Contoler Then Hardware then Syntek STK 1160 Then Drivers then Follow the instruction I hope it helps
  • 3 Answers
From what I have experienced, EasyCap 4channel USB DVR (model: easycap002) does NOT do simultaneous 4-channel updates, rather successively updating each of the 4 channels one after the other, each taking, at the fastest update speed, about 1/2 seconds per activate channel. Also, I've been unable to make the included EasyViewer software do audio recording. Furthermore, in video record mode, EasyViewer ONLY captures ONE channel's video, not all 4 together.
I had better recording results, albeit only 1 channel with sound, using the software on the same CD named D:\drivers\files\stkatvap.exe although it requires some menu configurations to get it working --I'll cover this at the end of this post.
You are FAR better off finding some third-party recording software that MAY be compatible with this 4-channel easycap002... I don't know if there even are any compatible ones, however, but I know this EasyViewer crap they provided sucks.
I have had a LOT of problems with easycap002 4 channel USB dvr as well (hardware name is Syntek ST1160). I have it working periodically. Because I had the drivers already installed (as I am sure you do) I plugged in the easycap and clicked start > administrative tools > computer management > system tools > device manager .. right pane: +imaging devices .. right click on Syntek STK1160 and choose Uninstall and [x]delete the driver for this software. Unplug the easycap USB cable. Reboot. Login and insert the install CD that came with easycap run the autorun. Whith Easycap unplugged, choose Install Driver. If it asks you to "completely remove" then answer "yes" and after it is done eject and reinsert the CD again and choose "install driver" yet again to do the actual install this time. Click OK to the prompts to get the driver re-installed. Although you're on Vista, it installs as XP. After install is complete, plug in the easycap002 4-channel USB cable. Wait about 10 seconds to be safe then click start > administrative tools > computer management > system tools > device manager .. right pane: +imaging devices .. you should again see the "Syntek STK1160" there not having a yellow symbol over it. For the heck of it, reboot again then install the 4-port imaging software if you have not already. Be sure to plug in at least one device/camera so you have something to test. NOTE: I could NOT use the icon it put on my desktop, I had to literally go to the install location of the softwrae and run NOT easyviewer.exe at the root of the CD, but go into directory SYS\XP\ and use EasyViewer.exe there!!!! It will come up saying there is "no signal" initially but you'll see at bottom center it saying "search[ing]" so wait until that search is done so it can identify the cameras plugged in. Normally it takes up to 10 seconds for it to realize a source is plugged into one of the 4 video ports which makes debugging this thing take FOREVER. Also, initially try to use short length higher quality RCA cables so you don't risk signal loss which will complicate your troubleshooting. If you unplug a video source or the source shuts off, EasyViewer will say "video loss" and you are best to just kill and restart the EasyViewer software again - I've rarely had it re-recognize a reconnected source after plugging it back in without needing to restart the software.
If you're using less than all 4 input sources, disable the unused ones as it'll make display updates much faster by option Channel > channel control > [x]automatic ..uncheck what you are not using.. make Fast Turning:[x]enable .. and Turning Time: 1 Sec (the fastest each display will update) [ok]. Trust me, you'll want to do this to have faster display updates which are slowwww to begin with.
If video is in black and white it COULD be you have a low quality RCA cable, but likely is your needing to change setting Property> tab Video Decoder : video standard: ntsc_m (ntsc_m_j is black and white.) .. also Tab IMAGE : Video Sources: [x]Ntsc_m [x]Composite ...if on S-Video you won't see anything on this easycap002 4-channel model as it does not have an s-video input.
* What is annoying is that not all 4 channels are continually displaying. They CYCLE in updates, channel 1 taking 1/2 second, ch2 thereafter takes a 1/2 second, ch3 thereafter 1/2 sec, etc. This is why earlier I said to DISABLE any channels you are not using, saiving you 1/2 second of update time per disabled channel. I was hoping for smooth simultaneous updating. The only way to get smooth video is to watch ONLY 1 channel - do this by clicking at upper right of window Auto Turning Focus:OFF and click on the channel you want to watch in somewhat smooth mode (~15 frames per second (15fps)). Click Auto Turning Focus:ON when you want each to update, taking ~1/2 second each.
This slow 1/2 per channel update is rediculous.. It defeats the purpose of security video in my view, a person can just run across the channel's view and never be caught during the updates of the other channels which can take 1.5 to 2 seconds.
THE WORST PART: I've found NO WAY to record ALL 4 channel's video at once! I can only record a selected frame to video .avi !! Unbelievable. You CAN take a manual "snap shot" of all 4 frames however, but how useless is that. Clicking "RECORDER" locks up the LIVE display of all but the channel you're recording. Clicking "recorder" again to stop recording locks up the display for a couple of seconds but then resumes the alternating channel display updates.
Be warned: viewing the created .AVI is only reliable in Microsoft MediaPlayer, it only sometimes works in Apples' QuickTime viewer.
I've not been able to get sound to record in EasyViewer either.
I was able to get sound to work under another software provided on the CD. As mentioned at the start of this post, I had better recording results, albeit only 1 channel with sound, using the software on the same CD named D:\drivers\files\stkatvap.exe although it requires some menu configurations to get it working.
After running s5katvap.exe, plug your vid source into channel 2 of the EasyCap002 device, yes, the cord labled 2 and put the source audio into the white cord. Choose DEVICES > [x]Micorphone (usb audio interface ... OPTIONS>[x]Preview [x]Audio Preview ...
To make the video display smoother, you need to choose the video output format CAPTURE > CYCLE MULTIPLE VIDEO FORMATS > For the UnitedStates [x]320x240 UYVY or [x]640x480 UYVY
Note: Audio lags behind the video by about 1/2 second in the preview mode, but it is only slightly off when you playback the finished actual recorded .avi video file.
Now set where you want the capture to go to: FILE > SET CAPTURE FILE > ...
Now start recording with CAPTURE > START CAPTURE
Don't know if this helps much.
I'd appreciate any feedback anyone can give on better controlling software for this 4-port/channel DVR.
johnjneumann@hotmail.com
Posted on Jan 05, 2008
Use the latest drivers and applications on the manufacturer's website http://www.szforwardvideo.com/support/Supp_7_2.html Versions on the original CD have necessarily been burned before feedback from users has been obtained.
And don't expect to record live video at full resolution from 4 cameras simultaneously with a cheap USB card on an ordinary computer :-) Try finding an alternative that works better before dismissing this as "****". Johnjn's "best solution" is a useful if verbose description of what the device can do, but his expectations and judgements are unrealistic.
Posted on May 11, 2009
    Problem Solver:
  • 6 Answers
In XP I went to the Program files folder, into MultiView folder (after initial installation) and ran the program called "driver.exe" from there. It first uninstalled the driver. Run it again to re-install the drivers. I worked for me after that. There is still the matter that MultiView kinda stinks.
Posted on May 09, 2008
    Problem Solver:
  • 9 Answers
I received an easycap and have had no problems with it, i use it to post alot of vids on youtube and have no problems with it. out the box i was able to plug and play, after installing the drivers, if you read the packaging it tells you to NOT run any anti-virus software on your pc as it will conflict with the software for easycap, i have used all programs realated to ulead etc. with no problems. and while there is a 1/2 second lag using a pc moniter i find using a tv to actually game on a prevents that cause ur not looking at the moniter. personally i dont use the avi format i use the mpeg 2 format and even the dvd format when making vids of my games, i run vista and have not run into any of the problems so many people claim to run into. at first i too couldnt get sound to record in easy view, but after using the movie wizard, the sound worked in the easy view as well..
Posted on Dec 26, 2008
On each of my xp computers, I have to install the drivers, then plug in the USB Easy Capture Device and then restart my machine with the device plugged in. After that, everything works well until I unplug the USB Device.This works with an Intel motherboard, a ThinkPad T40, and a Dell EVO Workstation.
Posted on Apr 25, 2009
Yes
Posted on Sep 22, 2008
    New Friend:
I got this Multiviewer v 2.00 for easycap usb 2.00 it works for me hope it works for u http://depositfiles.com/files/fcxel1lyn download and enjoy any question ask asleyferns@yahoo.com
Posted on Feb 11, 2013
I have easycap002 4channel USB 2.0 DVR and svat model wse103 pinhole camera and its wireless receiver (Svat receiver). I am using Xp professional sp3. I installed easycap driver and multiviewer and they are ok.
When I connect my pin hole cam and its Svat wireless receiver to my TV input, I can see my cam view from my TV screen. This means there is no problem with you Svat pin hole cam kits, they are working well.
But When I connect my wireless receiver to easycap camera #1 connector, I am trying to find in my multiviewer program as camera # 1. But there is a message as no connection.
I am asking to you that maybe that pinhole camera receiver is not compatable with this easycap usb dvr or not? Or how can I see this wireless cam on my laptop screen?
Best regards.
Posted on Jan 09, 2010
I have a 4 Channel USB DVR (STK1160) with Easyviewer 3.0 and doesn´t work with Windows Vista and with Windows XP. I try with the solution #5, but is the same, I can see the aplication Easyviewer 3.0 opened but with no signal for all the four inputs. Someone have another solution to porpouse?, please let me know.
Posted on Jun 08, 2009
  • Harsh
    Harsh Dec 30, 2012
    i too have the same device But it works Perfect To me
I discovered that there are two versions of the Easycap device. One is NOT compatible with Vista, and one is. You have to check the fine print when you are buying the thing (online).
Posted on Oct 26, 2008
Easycap for windows 7 how do I install
The easiest way is probably to watch the Youtube demos.
How to Install Easycap Drivers for Windows 7 (and Vista) - YouTube
This is a tutorial on how to properly install the Windows 7 and Vista drivers for the Easycap ... install the Windows 7 and Vista drivers for the ...
youtube.com/watch?v=IwI6uuQqLok
Nov 05, 2015 | Computers & Internet
I have easycap capture device DC60 but the cd supplied will not load on to my computer.I have disabled the firewalls etc to no avail. I have vista on Ei systems acpx86 32 bit have you any suggestions....
Have you tried finding the right drivers for the device?
Once the drivers are installed, the device should work fine with all software that supports video capture, including movie maker.
May 14, 2010 | Computers & Internet
I'm Having Problems With My Easycap DC60. I'm Using Windows Vista 32-Bit. I Need A Working Driver!!
ive have a problem with my laptop its a windows vista then i downgrade to xp.now i want to return my original setting or vista...the problem is where did i get an original OS?im using a compaq fresario f700
Jan 10, 2010 | Microsoft Windows Vista Home Basic Edition...
I cont remove the mcafee from my compaq laptop
Go to the McAfee website and download their McAfee removal tool. By running this you will completely remove all of your McAfee software. You will then be able to install your Kapresky anti-virus.
Sep 22, 2009 | HP Compaq Presario V6000T Notebook
I can not install easycap driver.
I also just received my Easy Cap today (for a 64-bit Vista PC) and a little hunting online revealed the following web page which has a link to some drivers for Vista 64-bit:
http://dekonass.no-ip.biz/?p=462
The link is just under the picture. Worked for me.
Good luck
Jul 16, 2009 | Ulead Videostudio 8 for PC
Mc cafee ePO management version 4.0
Hello jsnikhal,
If you are running Windows Vista, here is a good article that may help lead you a sulotion: Installing McAfee ePO Common Management Agent (CMA) on Windows Vista - http://neverblog.net/installing-mcafee-epo-common-management-agent-cma-on-windows-vista/
I hope this helps. If it does then please rate this solution.
Have a great day,
martyshaw152
Mar 21, 2009 | Compaq Computers & Internet
Have EasyCap video capture device and vista x86
I have windows vista and my drivers load fine. Plug in the unit and the drivers load. I have the 4 camera easycap and the VCR easycap. Install drivers first before plugging in the unit. Restart computer, plug in unit, check device manager if there is a stk1150 loaded under image. My problem is getting small files from the recordings. I converted 2 mins of my daughters dance solo and it turned out 1.7gb AVI file without sound. Changing the options to mpeg or WV files will crash the program becuase something doesn't match. I need to play with it more to understand it better.
Jan 20, 2009 | Ulead Videostudio 8 for PC
I HAVE PURCHASE A MCAFEE SECURITY SUITE FROM AOL,BUT IT NOT COMPATIABE WITH MY WINDOWS VISTA I HAVE DOWNLOADED TO MY LAPTOP BUT IT WILL NOT RUN CAN YOU HELP ME THANK YOU
of course MOTARO can help you.just install winxp professional on your system and install the mcafee.after installing the mcafee then upgrade your system back to windows VISTA
Feb 05, 2008 | Computers & Internet
EasyCap in Windows Vista
you will need ulead 10 on vista or download amcap free that works well on vista
Nov 10, 2007 | Ulead Videostudio 8 for PC
Ulead Videostudio 8 for PC Logo
30,018 people viewed this question
Top Ulead Computers & Internet Experts
Alun Cox
Karan Sethi
 Grubhead
Grubhead
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
