Question about Honda Garden
Shark pressure washer with honda 5.0hp motor when in use spraying with good pressure it the pressure shuts off and motor sounds like its about to shove a rod through the cases shut it off restart it andd the same thing occurs all fluid levels good pump and motor. water pressure from hose bib good. may b low water pres. for short time due to possible kink in hose reel not sure
What type pump oil to usefor karcher 2400 psi
Posted on Aug 06, 2011
  • 5,603 Answers
The valve that limits the water inflow when output pressure is up is stuck open.
Probably needs new O-Rings.
Posted on Oct 07, 2009
Honda powwer boss 3000-whenyoupull the handale to spray it kills the engine
Sounds like the unloader (regulator). Try removing the nozzle, the pull the trigger with the engine running. If motor is still running then it could be the Unloader malfunctioning. If you require a new one try a bypass system for the unloader. The bypass will help save the life of the unloader.
Jun 26, 2014 | Honda Pressure Washer PSI 3000
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
I have a Honda GCV 160 pressure washer from TROY-BILT and when I start the washer the motor starts but when I use the Spray Gun the motor stops and the pressure washer is jam. I think it is the motor and...
Mine is doing the same damn thing! Trying to figure out how to take off the high-pressure hose connector because I need to inspect it for clogs.
Jan 06, 2011 | Garden
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
It won't stay running
You need to either clean the carb really good (take it apart) or rebuild it or both. Sounds like your needle is gummed up and not letting fuel through.
May 29, 2009 | Honda Pressure Washer PSI 3000
I have a preesure washer with a honda motor. will only start with air cleaner removed
The air cleaner filter may need to be replaced. Also, it sounds like the carbeurator needs to be cleaned. Get a can of aerosol carbeurator cleaner and spray four or five quick bursts into the air cleaner while the filter is off. Run the pressure washer for 30 seconds to get the cleaner into the carberator. Then let it sit for a couple of hours and repeat the process.
May 07, 2009 | Karcher 2500 PSI Pressure Washer
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 | Garden
No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Oct 28, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
154 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
