Question about Sony FD Trinitron WEGA KV-27HS420 27" TV
My sony trinitron wega says no signal when I connect the coaxial cable.
  • 530 Answers
Your Sony has several varieties of possible connections.
They include,
  • HDMI (High-Definition Multimedia Interface)
  • Component video
  • S VIDEO
  • Composite video
  • RF/Coaxial
Make sure that the appropriate choice with in the menu "SETUP" option matches the connection at the rear.
If this is done correctly and you still have now picture it may be an issue with the cable or the connector on the end. Check the tip to make sure that there is between 1/8 to 1/4 inch of the internal wire past the end of the connector.
If this looks ok try a different hook up such as the "S-VIDEO" cable and seperate left and right audio "RCA" cable.
If you have no image after trying one of the other connection types then the issue may be with the TV itself which would require servicing.
Hope this helps
Posted on Oct 07, 2009
No signal on some channels but signal on others
Need more info. Are u using a cable box? Or are you using tv's tuner? Does coaxial cable come out of wall and connect right to tv??
Dec 28, 2012 | Sony Grand WEGA KF60DX100 60" Rear...
Is the sony trinitron 32"
U have pay cable or satalite service tv incomming broadcasting signal.Yes,than ur tv no need for a DTV converter.Those pay boxes will revert back to analog signal for ur analog tv.If u planning to get free over the air broadcasting,than u need a converter box to convert digital signal to a analog tv.
Mar 21, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I did a reset on my Sony WEGA TV but now it's not connect with the cable box. Just says no signal. Screen is all snow and no sound other than static.
you need to reprogram channels. Itll only pick up 3 if you are still using coaxial cable from box, or change input to DVI/HDMI, aux, etc.
Oct 21, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My (Sony FD Trinitron WEGA KV-32FQ) is not switching itself on?
I think your control board might be your problem can you get a signal out of the normal composite or coaxial outputs?
Suggest download this service manual first
http://depositfiles.com/files/l51shqooy
Aug 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Lost some stations on my Sony lcd TV.
It is most likely a signal issue. Bad coax connections, splitters and faulty cable are usually the culprit. Best to call your cable company and request a signal test. You may also try swapping tvs. Swap sony with viewsonic in the room where viewsonic tv is.
Jul 03, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 36 inch trinitron no picture no sound
i cannot get a signal from my HD cable box to my Sony Wega KDF-E50A10 TV's thru the HDMI cable.
Jun 20, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV XA 21M80 Trinitron- HUMMING NOISE AND PICTURE NOT CLEAR
If your set has a humming noise when connecting the cable, call your cable company. There is a ground issue. This can also be a safety issue.
If your signal is PAL, and your TV is NTSC only, you will have to replace the TV with a PAL one in order to properly view the programs.
Jerry G.
May 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega
have you tried an external antenna?
Dec 11, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I want to connect HD cable signal to HD projector
not directly unless it says hdtv somewhere or you need a converter box.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27HS420 27" TV Logo
1,314 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
