Question about SharpVision® XV-Z3100 DLP Projector
Lines running trough screen I have had my projector for 2 years and this problem just recently started
  • 70 Answers
Clean the port inside your projector. the between main board and av board.
Posted on Oct 08, 2009
Greenish dark, with multible lines across top to bottom of the screen.
That looks like retrace lines. Anyway, you should try to adjust screen pot not focus pot. Make sure you are turning blue screen pot (there are 3 focus pots and 3 screen pots) and do it slowly. If you turn it too much, it will affect your grayscale
Jun 23, 2008 | InFocus ScreenPlay 7200 Multimedia...
With my old bulb I recently had black vertical lines. I just put in a new bulb and now the lines multi-colored. How do I get rid of the lines? This problem shows up from my TV and DVD feeds.
reset the settings to factory default. if you don't get the lines on the splash screen when you first start it up, try swapping cables. if that doesn't work or you do get the lines on the splash screen, you have a video processor chip issue. replace the main board.
Mar 18, 2010 | InFocus ScreenPlay 7205 Multimedia...
Our 10 yo Sub Zero 632 started leaking water out of the bottom of the refrigerator side recently. The water appears to be coming from the hose that runs behind the salad crisper. How do we fix this?
The water is probably from the defrost cycle. Normally, this water is collected in a trough under the refrigerator and a fan blows across it to make it evaporate. Your trough has apparently overflowed.
It may also be coming from the freezer. When the drain line from the freezer clogs or closes with ice, the condensate will run down inside the refrigerator.
Oct 02, 2009 | Refrigerators
I have a Hitachi PJTX100.....been using it for a year and a half and it has been flawless.....until recently....After about 30 minutes of use it shuts off....meaning the screen goes black and the actual...
i believe your problem is heat the bulb is getting hot and the air or fan is not working properly so when it hits temp it automatically shuts off check your fan air flow filters etc
Jan 10, 2009 | Hitachi PJTX100 Multimedia Projector
Vertical line
Hi Abouttime
This is unfortunately a sign of Mainbaord damage to any make of Projector.
But do give this a go , you've got nothing to lose.
Try using a different signal cable and then pressing Auto on either the remote of the Projector or the Projector it self once the line appears.
Thanks for using Fixya !
May 22, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Aug 12, 2007 | ViewSonic PJ551 Multimedia Projector
Horizontal lines traveling up screen
Sounds like a ground loop on the video signal. Try using a ground lift on your computer and or your projector.
Jan 09, 2007 | Sanyo PLV 70 Multimedia Projector
SharpVision® XV-Z3100 DLP Projector Logo
66 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
