I am able to print email and other files, but when I want to print a saved pdf file, the message ''Unable to start print job. Is printer available?'' come up. I recently purchased and installed a new program called ''Driver Robot 1.0'' and since installing this program i was not able to print pdf files. I am sure that the printer is installed and is named as my default printer.
    Guru:
  • 126 Answers
You Adobe Acrobat Reader is old version, install a new one version of Adobe Acrobat Reader.
www.adobe.com
100% works.
Please rate us!
Posted on Oct 07, 2009
    President:
  • 2,049 Answers
Driver Robot seems like it is most likely the issue. I've read review after review which says some really bad things about the software.
Many users report that they are now having issues with their PCs after installing Driver Robot.
I would uninstall Driver Robot and reinstall your printer. I suspect things will clear up after that.
Here are some of the reviews...
http://download.cnet.com/Driver-Robot/3640-2094_4-11003186.html?tag=uo;uo
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    Cannot print full page from email. It starts half way down the page and does not get the full message
    Instead of printing directly from within the email, you might try saving the email (either under "save" or "export" in the menu) as a PDF file and then printing from that file instead. Sometimes this fixes the issue.
    If this was helpful, please remember to leave me positive feedback!
    May 13, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
    I cannot save a calendar as a pdf file. I get the
    When your want to save your file as .pdf extension, you have to select a "virtual printer" from your "Printers & Faxes" when you install the software you are using to save as pdf file.
    If you select your physical printer install on your PC, the error message you mention will appear.
    Hope it helps.
    Jul 21, 2010 | Broderbund American Greetings Creatacard...
    I can't print pdf files from the internet, I have to "save as"1st
    Sometimes the file name assigned to a pdf is not compatible with our printer's memory. For example, if the file name includes brackets [ ] or other punctuation, or is very long, the printer won't recognize it. One print job that stalls will hold up the entire print queue, so delete your job from the queue.
    First, look at the file name displayed in the print server's list of print jobs. The same file name also appears in the top blue bar of your Acrobat pdf display. Are there brackets, per cent signs, or other punctuation marks in the file name?
    Dec 28, 2009 | Microsoft Office Home and Student 2007...
    I can't print a pdf file with officejet hp5600
    hi,
    please check if the print spool service is working or not.( start - run - services.msc)
    Sep 27, 2009 | HP Officejet 5610 All-In-One InkJet...
    Unable to save scanned document in html format
    You can print save as a HTML File, most printers defaults print save as PDF files, Since PDF files are none editable you will not be able to convert this into a HTML file.
    Regards
    Jul 23, 2009 | HP PSC 2110 All-In-One InkJet Printer
    Scan multiple pages to one file
    Hi Clint...
    There are several programs available for downloading that work as print to pdf... some free some not. You can try pdf creator it's free and works well for me, the download isn't very long and the install is super easy.
    after you install the program, you should see a pdf printer in your printer selections. You don't want to try to save your file, you have to select print and then select the pdf print to file option in your printer selection. Print the first file to a file you create to save it as a pdf. for the subsequent files you will need to choose Append to an existing pdf file and select the file you have created.
    Test the file to see that both of your scans are in there and that they are in the order you want them to be in. If all that works find, you can follow the same procedure with each scanned page and they should all end up in one file.
    the pdf print to file is also a great way to save webpages in one single file :)
    hope that helps!
    bru
    Jan 29, 2009 | Brother Multi-Function Center MFC-240C...
    Msg 'unable to start print job, is printer available'
    A customer called me with the same msg. Let me explain first what the problem was..they had a Graphic PDF that on the HD was 20 MB but when extracted was well over 200 MB..first I had thought the pdf was exeeding the Printers memory but after testing it was not. The customer was printing the document using adobe PRO I had him print the document in reader 8.1 and made sure the print as image under advanced was selected and the document printed..
    Aug 09, 2008 | HP PSC 1410v All-in-One Printer
    Computers & Internet Logo
    123 people viewed this question
    David Payne
    David Payne
