Question about Garden
What is the gas/oil mixture ratio for the Makita eh450 hedge trimmer
  • 636 Answers
Usually it would be about 50:1 in todays engines, but if you are unsure mix 40:1 wouldn't hurt it , may run a little rich,
Posted on Oct 07, 2009
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
Two stroke ratio calculator
If you are referring to the fuel mixture, it is 50:1. So for one gallon of gas, use 2.56 oz. ( US measure) of two stroke oil. Gas Oil Mixture Ratio Calculator
Jun 30, 2014 | Garden
What is gas mixture for weedeater poulan pro 25cc 17" cut
40:1 ratio is the manufature spec for 2 stroke units. unless it is a four stroke then there is no mixture just a good quality gas.
Jun 03, 2014 | Poulan WeedEater Hedge Trimmer 25cc Engine
Gas oil mixture
use a good quality 2 cycle oil at 50:1 thats about 2.6 ounces of oil per gallon if you are using Red Armour or most other high quality oils. I have ran everything that calls for 40:1 at the 50:1 ratio with NO failures using Opti 2 premix.... all modern hand held equipment is usually 50:1
Dec 22, 2013 | Ryobi 26CC, 22 In. Hedge Trimmer
POULAN 25CC NOT STARTING AND BEFORE THIS HAPPEND IT WAS OVER HEATING
overheating on a 2 stroke is usually caused by lack of oil mixture. try draining all the fuel and re mixing the ratioo to a 40 to 1 ratio. if no smoke then richen the mixture till it slightly smokes. i.e. 50:1 ratio
Aug 30, 2012 | Poulan WeedEater Hedge Trimmer 25cc Engine
Oil/petrol mixture for GPHS 26cc gardenline hedge trimmer
Petrol / oil should be in ratio 50 to 1
Apr 13, 2011 | Garden
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
What is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Dec 10, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Garden Logo
136 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
