Question about Olympus SP-550 UZ Digital Camera
My camera will not turn on. It worked perfectly fine a few days ago, then the batteries died. I put new ones in and it refuses to turn on. Every battery I put in doesn't seem to change anything. HELP!!!!!
  • DarkKnightBS May 11, 2010
    What type of batteries are you using? The best rechargeable batteries for today's digital cameras are the Sanyo eneloop NiMH. Before you go out and purchase a new lot of batteries, use a Q-tip with alcohol to clean the battery contacts and try the batteries again.
5 Suggested Answers
SOURCE: Olympus FE-115 : wont turn on..turns iself off!!!
I've experienced a very similar problem. I took our camera to a Bridal shower with 2 sets of freshly charged (I validated the charge) NIMH rechargeables plus a set of new alkalines. Regardless of which batteries I used, the camera indicated low battery after one or two pictures were taken, if it would take one at all. Its NOT a battery problem in my case.
Posted on Jun 14, 2007
SOURCE: Olympus Stylus 730 Digital - Won't work 60 days old
I'm having the exact same problem. I was in the middle of zooming on a shot and it froze, so I turned the camera off and on, and now I get the 5-chimes+Zoom Error screen. This is nuts, I've only had the thing for six months, and it was $250 (got the Stylus 730). I *think* I got a replacement plan so that's good. But still... I hope circuit city lets me get a different brand b/c I'm not happy with this now. The only problem I had before was the HORRID shutter delay. I want a model that doesn't have that problem .
Posted on Mar 29, 2008
  • 90 Answers
SOURCE: My Camera stoped recharging for no apparent reason.
Please contact Jazz at 732-572-7050 for customer support.
Thanks,
SHeryl
Jazz Products, LLC
Posted on Dec 20, 2008
BillB-SA
  • 2761 Answers
SOURCE: my camera keeps turning off when i try to take a picture even whe
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 29, 2009
Camera does not turn on
Rosa, I think the only thing you did was get out the batteries and tried to charge them and then jut put them back in the camera.
Only a few things could have gone wrong.
One or more cells could have died, during charging. It can happen, special with batteries that have a uneven use. Like once or twice a year the camera comes out the box and then the batteries are charged. Even when you don't use he camera, make it a habit to charge the batteries every few months.
Then it could be your batteries are still in good shape and fully charged, but you put in one or more calls the wrong way around.
Please check carefully if all the cells are inserted correct.
If nothing works, and you can't check the voltage of your batteries, try another set of batteries.
Dec 30, 2013 | GE Cameras
Why does my 2004 BMW 525 intermittedly have no power?
IT DOES SOUND LIKE KEY FOB DYING AND I HOPE IT IS AS IT WOULD BE CHEAPEST PROBLEM TO SOLVE. GOOD LUCK
Apr 14, 2017 | 2004 BMW 525 i
My Vivitar Vivicam 5399 is refusing to turn on. It has worked perfectly up until a couple of weeks ago, when it started to turn off at random moments, usually soon after I had turned it on. Now, it doesn't...
Have you tried to see if the battery door is completely shut? This is usually the problem with many digital cameras with batteries. Clean the battery door and where the battery touches the metal of the door. Check to see if the door is completely flush with the camera body when you close it. I know for a fact that Vivitar cameras **** the juice out of batteries fairly quickly also. If you have the USB-cord provided with the camera, plug it into your computer and see if that holds a charge to your camera. If all else fails, call up Vivitar for further inquiry, your battery may be dead.
Mar 08, 2011 | Vivitar Vivacam 5399 Digital Camera
The red light on the front stays on but the camera won't work. i haven't dropped it or anything. It is a kodak easyshare CD43. It was working fine a couple days ago. I put new lithium batteries in and it...
he red light on the front stays on but the camera won't work. i haven't dropped it or anything. It is a kodak easyshare CD43. It was working fine a couple days ago. I put new lithium batteries in and it has the same problem as before.
Feb 14, 2010 | Kodak CD43 Digital Camera
Cannot see anything on the screen
Ensure that settings are OK, and check if the curtain is opening.
If everything else is OK, then all black picture means that lens assembly, wiring to CCD sensor, or main digital board is faulty. More likely one of the first two.
The fault must be fixed at a repair shop.
Regards
Jul 02, 2009 | Canon PowerShot A470 Digital Camera
Thanks,
SHeryl
Jazz Products, LLC
Nov 30, 2008 | Jazz DV-179 Digital Camera
It dont turn on
dont buy this c*#p again thats the best solution i can give
Jun 23, 2008 | Samsung Digimax S700 Digital Camera
Wont turn on.... flashes on then off
Get out the batteries then leave the camera for about one day, Put a pair of new batteries then try to switch on.
Nov 25, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
FujiFilm FinePix A500 screen turns off when trying to take a picture
I had the same problem with a fujifilm finepix... It didn't take pictures with 2 sony batteries, just turned off after pressing the shutter. Then I tried 2 panasonic batteries and it worked fine....
My solution: try panasonic rechargeable.
Oct 24, 2007 | Nikon COOLPIX P4 Digital Camera
I had the same problem and i called up cutomer support on 1300 659 678 (Australia) and they said that the problem may lie in your batteries. It was advised that you use Lithium batteries, and to avoid use of Alkaline, since they dont have the required power to operate the camera which is why it turns off right away. As to what type of rechageable batterires to use i am not sure, i think it was Nickel-metal-hydride (NiMH) batteries. Hope this solves your problem.
Sep 10, 2006 | Olympus FE-115 Digital Camera
Olympus SP-550 UZ Digital Camera Logo
22 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
