Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Lock preventing me from setup menu
Someone has set the lock on for my setup menu. I don't know how this happened, but I do not have an owner's manual, and I need to know how to turn the lock off.
    President:
  • 4,402 Answers
Do a hard reset and if it is just a software corruption this will cure it. Unplug the power cord for 4 hours, then power up again. The reason for the long DISCONNECT time is to allow internal voltages to discharge down to absolute zero. Then when the power comes back up it automatically pulls of the eprom files and loads in the factory preset conditions.
Posted on Jan 08, 2008
Locked out front control panel while in menu. Now I can't unlock front control panel and I don't have original remote control or owners Manual. Help me please. The front panel is all I use for DVD pla
Hi there, if you know what model it is you can do a google search for the owners manual. There should be a sequence of buttons you can push or hold to reset to factory/default settings.
Jan 25, 2013 | Televison & Video
I can't change the audio settings in the setup menu on my marantz dvd7600
Gray means they are locked out---consult the owner manual to see what can be done----sometimes it is how the unit is hooked up and to what.
Dec 04, 2012 | Televison & Video
No mirror lock-up option in setup menu. actually several fields are missing including Folders, File # Sequence, Dust Off Ref Photo
In the Setup menu, select "CSM/Setup menu" and set it to "Full" instead of "Simple." For some reason Nikon thinks that most users don't need those options.
Aug 07, 2011 | Nikon D40x Digital Camera
My rca is locked don't have my owners manual how
Hello
If you have its original remote control, you can unlock it by one amoung the following methods. If you don't have its original remote control, try to gather it from any of your friends or relatives to get the lock out. Then you can use any other remote controls.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jul 05, 2011 | RCA Televison & Video
We have the M220MV. Cannot change channels using the numeric keypad on the remote. I know it should be possible, the manual says you can change channels this way. If not, the last channel button would be...
Hello
Reset your Tv to factory settings. It will unlock all locks including front panel lock.
Reset All Settings
Return all Picture and Audio settings to factory default. A screen will come up to confirm your
selection or to cancel it. Press Left or Right Navigation buttons to make the selection, and then
press OK to accept it.
Setup Wizard
Use this function to return to the Initial Setup menu
Go to its user manual for Initial setup menu details.
OK.
Apr 24, 2011 | Vizio M220MV 22 in. HD-Ready LCD TV
I have copied and pasted someone elses problem, because it is the same one I am having. So if I want to use the aperture for taking Manual photos I cannot do this because when it goes off of F22, it reads...
Lock the aperture ring at its smallest opening (in this case, F22). Change the aperture setting by turning the subcommand dial (the one in front, unless you changed it in the setup menu).
Of course, you can only change the aperture directly in Manual and Aperture-Priority modes.
Mar 23, 2010 | Nikon D80 Digital Camera with 28-80mm Lens
I Have a HP laserjet 3380 and I do not know how to change the answer mode and rings to answer settings. Everytime the phone rings it goes straight to fax. It has distinctive ring set on it for the fax...
You switched it to manual. Can you switch it to automatic? (Then check "Rings to answer below)
1. On the control panel, press MENU/ENTER.
2. Use the < or the > button to select Fax setup, and then press MENU/ENTER.
3. Use the < or the > button to select Fax Recv. setup, and then press MENU/ENTER.
4. Press MENU/ENTER to select Answer mode.
5. Use the < or the > button to select Automatic or Manual, and then press MENU/ENTER.
The control panel display shows the answer mode setting that you specified.
Rings to answer default is 5 rings. Did someone change it? You can check that it is still at 5 rings:
4. Use the < or the > button to select Rings to answer, and then press MENU/ENTER.
5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press MENU/ENTER.
Dec 31, 2009 | HP LaserJet 3380 All-In-One Printer
Belkin lock
To secure your wireless network and prevent unauthorized access you need to setup your wireless router with these settings :-
When you first setup your wireless router you should change the login password and then the wireless configuration, setup WAP or WAP2 encryption (WAP2 is the strongest encryption) and change the SSID and turn off SSID broadcast.
For further wireless protection enable MAC address filtering. The MAC address of the wireless card in your computer is entered in the router MAC address filter table, which allows only the wireless card with this MAC address to connect to the wireless router.
Also if your router has a firewall then you should enable this feature.
The wireless card on the computer needs to be configured with the wireless router's settings. The LAN cable can be removed and the computer communicates wirelessly with the router.
Sep 21, 2009 | Belkin Computers & Internet
In Tally T2240/24 Matrix Printer i am not able to take test page,
The menu on the T2240 is locked to prevent accidental changes to menu settings, you can unlock the menu in the following way;
  1. Start with the printer powered OFF
  2. Hold down the SETUP button
  3. Keep the SETUP button held down and power the printer ON
  4. Keep the SETUP button held down until the printer has finished initializing, then release the SETUP button
The menu will be unlocked until the printer is reset or powered off.
You can turn the menu lock off by changing the MENLOCK option in the printers menu to OFF.
Mar 31, 2009 | Tally T2240/24 Matrix Printer
Denon 1508
This should resolve your propblem... taken from the Denon USA FAQ...
You’ll rarely need to "initialize the microprocessor" under normal operating conditions. In a few cases, the microprocessor will temporarily freeze or "lock up" just as your home computer does. When this happens, just follow the guidelines in the back of your owner’s manual to "unlock" the microprocessor and restore normal operation. (This is directly comparable to rebooting your computer. It’s an electronic wake up call to your unit’s temporarily paralyzed microprocessor "brain.")
If you experience some unusual behavior -- a channel that’s suddenly silent, "forgotten" level adjustments, some eccentricities in your unit etc. -- you may need to reset the microprocessor. Of course, you should check all connections carefully first. But if you’ve eliminated these items as a source of potential problems, you may need to go through the initialization process.)
Initialization is easy. Please refer to your owners manual for instruction on reseting the microprocessor as each unit may have its own individual protocal for reset.
What causes these problems? Several things can -- a jolt of static electricity, a current surge through an antenna input, etc. But don’t worry, the microprocessor is well shielded from any permanent effects.
When you do initialize the microprocessor, remember that this erases any setup instructions you may have previously programmed into the unit. However, the on-screen menu will quickly get you through a new setup. And, if you write down your preferred settings BEFORE you reset your unit’s microprocessor, you’ll have an even easier job!
If in the event you do intialize microprocessor reset please refer to your owners manual for instructions on setup..
Sep 20, 2008 | Denon AVR-1508 Receiver
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
