Question about Roper REX4634KQ Electric Dryer
Dryer want heat and element is good - Roper REX4634KQ Electric Dryer
  • Roper Master
  • 7,482 Answers
Check the thermistor/thermostats....that could be your problem.
Good luck,
I hope this helps
Posted on Oct 07, 2009
Does not heat up
what type of dryer rate these
Open The Cabinet
  • Unplug the dryer's power cord from the electrical outlet. Remove the toe panel by inserting a putty knife between the toe panel and the front panel. There are retaining clips 4 in. from each corner. Slide the putty knife blade over each retaining clip and pull the toe panel away from the dryer.
Test the Heating Element
  • If you own an electric Whirlpool dryer, locate the heating element. The heating element is the workhorse of the heating operation. The heating element is most often inside a can. The thermostat mounts to the side of the heating element can in most Whirlpool dryers. The thermostat looks like a small oval part with two wires connecting to each side.
    Pull the two wires that connect to the heating element terminals. Set a volt-ohm meter to the RX1 scale to check the continuity of the heating element. Clip each probe from the volt-ohm to each of the heating element terminals. A good element will give you a reading between 8 ohms and 12 ohms. If you get no ohm reading, the heating element is faulty and you will need to replace this part.
Jan 15, 2013 | Dryers
Dryer heat not working
Without knowing your problem, I would guess that the heating element has burned out. This is a common issue with many dryers, regardless of brand.
The hearing element in a clothes dryer is like any other heating element, such as in a space heater, heat gun, or hair dryer. It is basically a continuous coil that is held in place by insulators, usually ceramic.
As the element ages, the coil becomes brittle and can often break. When a breakage occurs, the circuit is no longer complete and will not produce heat.
Replacing one is fairly simple.
  1. The first thing that you should do is unplug your dryer.
  2. Once unplugged, remove the exhaust duct.
  3. Use a screwdriver to remove the electric access panel in at the rear of the dryer.
  4. Locate and remove the heating element.
  5. Inspect the element for a break in the coil. The problem is not always obvious so it may be good to do a continuity test on it.
  6. Replace part if necessary. Elements will usually run $20 or so.
  7. Assemble in reverse order and test.
This website has some really great detailed step by step instructions on replacing a heater element.
Good luck.
Jan 11, 2013 | Frigidaire FFLE2022MW Electric...
Maytag dryer heating element won't come on
you should have a nominal 240 volts between the 2 heating element connections
Feb 07, 2012 | Dryers
Dryer does not heat
Well first all you may check out the heating element, it is possible that your dryer isn't heating because its heating element is defective. Heating elements are not repairable. You need to open your dryer's cabinet and locate the heating element so that you can test it. and you need a multimeter to check it out. Secondly you may check out the Thermal Fuse Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you need to replace it. Post further comments for further help or information.......
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Bosch WTMC632SUS Electric Dryer
Dryer won't heat
Good Luck!!
Jan 26, 2011 | Kenmore HE5 Electric Dryer
Kenmore dryer makes no heat
replace the heating element. Or the control panel has weakening capacitor not sending correct current flow to the heating element
Jul 09, 2009 | Dryers
No heat
if it's a gas dryer, it's the thermal fuse. if it's an electric dryer, it's the thermal cut-off located on the heating element housing. good luck bud :)
Jul 06, 2009 | Dryers
Dryer will not heat
Check to make sure you have 240V at the outlet. If you do, check the continuity of the element and thermostats. If still no heat, it could be the temperature setting switch, the timer or the motor.
Feb 19, 2009 | Kenmore 65924 Electric Dryer
No heat from dryer
is it 220 volt dryer,if so check the plug at the wall and make sure you have 220,the plug runs off 2 circuit breakers at your electric panel,1 breaker may be no good so your only getting 110 volts to the dryer which will run the dryer but not the heating element
Jul 08, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
