Question about NEC MT850, MT1050, MT1055, MT1056 Replacement Projector Lamp - MT50LP Projector Lamp
I have a NEC mt1055 and the unit just had new bulb put in here and it has the power and standby light come on and the fan doesn't turn on here and the standby light is yellow and status is red
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
Posted on Jan 26, 2010
Well never really got much good information on the unit here told me to check the fuse on the unit and see if that would take care of it but then said was inside the unit but unpon looking did not find it so the result was nothing i could use. Waste of my money
Posted on Oct 07, 2009
What does it means of 6 seconds red light interval of my NEC MT1050 projector,and how will I fix it to come back to life?
Holding down the "OFF" key on the remote control for 30 seconds
to reset the lamp timer
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jun 13, 2014 | NEC MT850, MT1050, MT1055, MT1056...
NEC VT440 projector problems can you help
Please check its vantilation fans, are they rotating or not?
Jul 24, 2008 | NEC VT460 Multimedia Projector
The status light is on our NEC MT850 and the bulb looks fine. What other problems could it be?
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Have a nice day!
Jerry
Lampdeng Limited
Nov 19, 2012 | NEC MT850, MT1050, MT1055, MT1056...
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
NEC LT240 has Power, Status & Lamp indicators lit & wont turn on!
If your bulb finally reaches it's end before you have the chance to replace it you unit will shut itself down and go into a permanent standby mode. Changing the bulb alone will not remedy the issue. The solution is quite simple but not posted in the manual or anywhere else that I could find for that matter! All that is required is to hold down the HELP button on your remote for 10 seconds while aiming at the infrared sensor on the unit. This will reset the units bulb timer and remove it from the standby mode.
Dec 10, 2008 | NEC LT 240K Multimedia Projector
NEC MT850
As there were no indicator lights lit I focused on the AC. The projectors work as they should in another location and as such I am fairly certain the problem is associated with the AC power in the particular room. I haven't isolated the exact condition as yet.
Thanks
May 20, 2008 | NEC MT850, MT1050, MT1055, MT1056...
NEC MT1055 Will not power up
Hi there
This sounds like a faulty Ballast ( lamp's power supply ) It will unfortunately need repair or replacement.
Mar 25, 2008 | NEC MT850, MT1050, MT1055, MT1056...
REPACEMENT PARTS MANUAL
Hi there
You will have to be more specific on wich fan you want the part number of !
Nov 27, 2007 | NEC MT850, MT1050, MT1055, MT1056...
947 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Piyal Perera
Piyal Perera
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
