Question about Apple iBook G4 Mac Notebook
Ibook display problem
One day, I booted up my iBook and got a weird display of lines across the upper portion of the screen. When I first boot up, I hear the familiar startup sound. However, then the screen lights up but with only the very top part being a dark gray color, then a series of lines, then a relly dark black area, and finally a much lighter blue area.
One more thing, there is a cursor displaying in the dark upper portion of the screen, and I can move the cursor arrow in that gray area. But when I try to move it beyond the lines, it will not go any lower than the series of lines. I am suspecting that because I can see the cursor arrow, this means that the computer is not the issue and that I might possibly need to replace the screen. Any other suggestions?
Linda
  • bastida1 Oct 12, 2009
    Thanks, but this did nothing to fix the problem. I strongly suspect that the ibook might have ben dropped, but cannot prove this to be the case. When I power the computer on, I get the chime sound, then I get a display that is two different shades of gray with some lines in the middle of the screen. There is a cursor arrow on the upper part of the screen above the lines. I can move that cursor arrow around the upper part of the screen. But when I try to move the cursor arrow past the lines, it will not go beyond the lines to the lower part of the screen.
  • 558 Answers
You can reset the pmu this might help to stable the display,this is only used as a last resort and not a possible solution.
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the iBook computer.
Posted on Oct 07, 2009
I have replaced my harddisk in ibook G4...how to install mac os
The problem appears to be that your ibook is only a G4 processor snow leopard needs an intel processor. The highest system you can instal on it is 10.5 i.e. leopard.
Jun 25, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
Reset_To_Factory_Setting on mac ibook g4
Justin I suppose the easiest way to do this would be to insert your system disk into your ibook boot it up holding down the c key on your keyboard and then instal a fresh system. Use the erase and instal option as this will erase your hard drive. Any other queries get back to me, hope this helps. By the way a step by step way of doing this can be found at http://macs.about.com/od/leopard105/ss/installleopard.htm although it's leopard it should be similar across system.
Oct 31, 2011 | Apple iBook G4 Mac Notebook
I want to install linux on an old ibook cd drive wont let me boot from it . I have a powerbook that i can hook up to the ibook thru firewire. the ibook harddrive has been wiped clean. what would be the...
I would recommend booting from USB. Go to pendrivelinux.com and pick a distro. The utility is awesome and makes it easy to boot from usb. make sure that bootusb is an option in BIOS.
Good luck
Joe
Jan 08, 2011 | Apple iBook G3 Mac Notebook
I Apple Ibook G4 Machine 1. Machine boots up fi...
Machine 1. The dim display is likely the result of an old or failing compact fluorescent lamp (CFL), generally refered to as the backlight lamp. This CFL is a long, narrow, delicate, and normally very bright light that runs along the bottom of the LCD screen and is powered by the inverter. You could replace the CFL yourself however or simply look for a used iBook screen assembly or the LCD by itself for about the same cost. CFL sell for $7-15. The first time you attempt to replace it, you should buy two because you'll likely break the first one learning how it work. Watch out for mercury! Machine 2 The graphic processor unit (GPU) is attached to the logic board using a grid of solder balls. With normal wear and tear the logic board flexes and breaks and cracks the solder joints which results in the same exact symptoms that you are experiencing. The chip must me removed and the solder joints "re-balled" to fix it correctly. Again, you could do this yourself or find a reputable service on eBay for $30-55.
Sometimes, if you grip the iBook with your left hand and apply pressure just below the alt key with your thumb and your fingers on the bottom, while booting, the symptoms go temporarily appear to go away. It's a good way to test for this very common iBook problem.
May 21, 2010 | Apple iBook G4 (Z0AZW13397068) PC Notebook
My apple ibook G4 cant boot operating system. Whenever i on it, it will only display a folder with question mark on it. Pls what can i do. I am a nigerian.
The folder is a sign that there's a problem with the system software. Reinstalling the system software should allow your iBook G4 to boot up.
Apr 14, 2010 | Computers & Internet
Black screen on iBook makes boot up sounds
Well, its only the bad news first, your ibook has fallen as many other thousands have, prey to the design flaws of apple, heres an article on it all and some strongly opinionated comments attached,http://johnbakersblog.co.uk/design-fault-in-apples-ibook-g4/And heres how to repair DIY style ;7)http://www.coreyarnold.org/ibook/I've personally done this repair myself aswell, not a bad result but not a guarantee it will work 100% all the time.these machines are cheap on ebay, goodluck, try repair and if not great, then sell as is and buy new used on ebay, youll end up spending $50 and have a wrking ibook...? goodluck, chazz
Jun 07, 2009 | Apple iBook G3 Mac Notebook
My iBook G4 continues to run slowly and/or freeze
Try resetting the PRAM by turning on the iBook then holding option + command + P + R and wait till u hear another chime. If it still freezes, it may indicate an application may be causing it to lock up hold shift after you hear the chime to boot OS X into safe boot.
Mar 18, 2009 | Apple iBook G4 Mac Notebook
My iBook is Sad.
I would connect another monitor to it, if you see the same on the monitor, the videocard/GPU is toast, if not , the onboard display is.
Aug 22, 2008 | Apple iBook G3 Mac Notebook
Always freeze
Firefox will use a lot of disk space over time for temporary use. You might try starting up and run the Disk Utilities program to repair disk permissions.
Dec 25, 2007 | Apple iBook Mac Notebook
Apple iBook G4 Mac Notebook Logo
290 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
