Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
The brushes will not turn when on and cannot move them even manually
  • 636 Answers
Drive belt has most likely broke and jammed inside the power head. Remove the bottom plate on the power head and replace the drive belt.
Posted on Oct 07, 2009
  • 701 Answers
Turn the power brush over so the bottom faces up. On the bottom thereare two access screws. Remove the two screws and then the top cover canbe removed from the base. With the top cover off you can access the beltthe brushes will not turn when on and cannot move - 2_bing.gif. You can get a replacement belt for your model here:
Kenmore Progressive Replacement Belt
Posted on Nov 19, 2009
I replaced belt that was broken and went to put it back togehter and it starts to work and the light on the vacuum goes out and the suction stops...what could be the problem now?
Posted on Nov 14, 2009
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
Aug 01, 2014 | Shark Rotator Professional Lift-Away...
Dyson brush not turning?
The brush wont move it is quite often that your belt has snapped you can get them from any good hoover outlet or order on li
Jul 23, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
My brush stopped spinning, but instead makes a loud plastic grinding noise.
Both ends of the brush roll should spin freely. You need to replace the brush roll.
Jan 21, 2014 | Hoover SH40060: Multi-Cyclonic Canister
The brushes on my Hoover Steamvac Widepath LS SpinScrub model # F6040 900 are not spinning. What should I do to get the brushes spinning again?
On those models the brushes are turned by suction.
1. Check the lower tank to be sure its completely closed and sealed.
2. Check the lower tank to be sure the tools filler plate is in place (if you used the tools recently)
3. If both 1&2 ok, manually turn the brushes, if they do not turn freely you may have a stuck turbine or bad brush block.
4. Take the brush block out by releasing the tabs on each corner being careful not to break them.
5. Place a large flat blade screwdriver in the square drive hole that drives the brushes under the machine. Gently turn. It should turn slowly with some resistance. If it turns slowly it is ok. If it turns with no resistance it may be bad as well. If it will not you may be able to break it loose with some even pressure being careful not to strip the hole. If it will not turn or makes a lot of noise replace the Turbine assembly.
6. If the brush block has a broken drive shaft or will not turn replace the brush block.
Here is what that brush block should look like.
http://www.vacuummedic.com/product.php?id=206
Good Luck!
Aug 21, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Green light does not come on ans brush does not move. belt is good and brush does spin manually.
I assume this is a Kirby. The belt is not on the motor shaft if you can turn the brush manually. Remove the head, turn the belt lifter assembly clockwise to stretch the belt into a loop, place the head back onto the motor unit and latch it in place, then turn the belt lifter counterclockwise to drop the belt onto the motor shaft.
Jan 22, 2011 | Vacuums
The brush on my vaccum stopped rotating, we replaced the belt thinking that could be the problem. It seems that the belt is working fine and the brush will not rotate even manually- what can I do to get it...
Remove the brush from the machine and clean as best you can. At each end of the brush there is a plastic clip that holds it into the vacuum. Add some WD40 between the clip and the brush and turn the clip around the brush until it moves freely. Do this for both ends. Reassemble making sure the belt is properly installed.
Oct 13, 2010 | Bissell 6595 Lift Off Bagless Upright...
The brushes will not turn even though I have the switch on for the brushes
When you move the swwitch to on, you are moving a baffle to allow air flow into the turbine to rotate the brushes. try to move them by hand with the machine off. if you cannot the turbine nees service. if you can check the tank lid is on, foam filter for dirt.
Sep 06, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a dyson upright and he beater brush is not turning
There are four possible reasons for the problem. We will take them from the easiest to fix to the hardest.
1. The manual clutch is not engaged. On the bottom right side of the vaccum is the manual clutch knob. Be sure it is rotated all the way forward. The clutch should now engage when the handle is lowered from the upright position to the vacuumig position.
2. The brush bar is entangled with debris keeping it from turning. Turn the vacuum over, remove the brush bar cover by using a coin to turn the screw like pinions a quarter turn counter-clockwise. Remove any hair, carpet fibers or other items wrapped around the brush bar. Disengage the manual clutch by turning it toward the back of the vacuum. Try turning the brush bar by hand to see that it moves freely.
3. The brush bar is broken. While you have the brush bar cover removed, inspect the brush bar for any cracks or other signs of damage. The frequency of a damaged or defective brush bar is higher than most people may think. If damaged, the brush bar will need to be replaced.
4. The clutch assebly is not functioning properly. In that case, it would be best to have a service tech handle the matter. If you want to inspect the clutch or even consider replacing it yourself, this link may be of interest: http://www.youtube.com/watch?v=7_CtaFcc5HU
Hope I've been of some help.
Jul 03, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brushes won"t spin, Model F7452-900
SAME PROBLEM Hoover F7452 900 brushes won't spin; cleaned and move freely, under filter slid out and cleaned, still froze up....had it a little more than a year so probably no warranty.....assuming turbine related and will take it to dealer......how common is this problem with this model???
Jun 15, 2009 | Hoover F7431-900 SteamVac Vacuum
Irobot Roomba will not turn off
I think both of you who responded are tools.
The issue is on the main board. What JBugs is saying is the brushes continue to run even if the unit is manually turned off.
There is no fix other than to replace the main board. There is a circuit which drives the brushes. If the circuit electronically gets stuck in a closed position, then the brushes will run until out of power.
There is a way to install a switch in the brush circuits but then you must manually turn the brushes on each time you want to clean.
Best bet is to call iRobot, complain and buy one of the out of warranty replacements for $99. This replacement will allow you to schedule the unit to wake up and will perform exactly like the Scheduler.
Jan 11, 2008 | Vacuums
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
270 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
