Question about Samsung UpStage SPH-m620 Cellular Phone
This has to do with sides
Well the phone side is fine... but the player side (when flipped) is plain white and you cant see S't that your doing but you can still do it. and on the phone side isnt there any other USEFULL ICONS like messaging not just send message or settings and tools or missed alerts or anyway to get to those? the navigational buttons dont even have shortcuts. the only way to do anything is to be on the other side and the other side doesnt F'n WORK. yes ive plugged it in, yes i used an earring to push reset, which all it does is turn it off and not help my problem. advise??
SOURCE: Samsung Omnia - Main Menu Function key gives a shortcut error.
Assign the key to another function. And then reassign it back to the main menu short cut. It worked for me.
Posted on May 11, 2009
  • 66 Answers
SOURCE: phone has completely frozen
water damage
Posted on Jul 01, 2009
  • 37 Answers
SOURCE: Screen turns white when I slide it Up
The only fix is to replace your flex cable. On a scale of 1 to 10 in difficulty. It is a 3.
Posted on Jul 17, 2009
SOURCE: My New Mail & Missed Call alert gone
I just fixed it on my S8300... just try to recover the alert screen from outside the visible edges of the screen (move your finger by the edges, randomly, until you achieve to get the alert screen partially visible, then move it carefully to the center of the screen).
Posted on Oct 08, 2009
SOURCE: cant send text messages, get sent to enter center
how do you get rid of the enter center i can'teven snd a text message to anyone i have a samsung sgh-J706 i need help
Posted on Jun 16, 2010
My display screen comes on plain white without the location bearings
take it to a shop that installs remote starters dvd players etc... have them make sure the connections to the radio are right also try the neg cable wire make sure there is no corrosion on it
Nov 12, 2013 | 2009 Toyota Highlander
HP7130 Incompatible settings
Please , you have to download the driver for win8 ,by samply serching on for example "
HP Officejet 7130 All-In-One driver for win 8
Mar 21, 2013 | HP Officejet 7130 All-In-One InkJet...
Ms Pacman/Galaga Cocktail Arcade//side 2 not working
1.Check the dip switches for cocktail set up/ no upright.
2.does the screen flip to the player 2? if yes
3.make sure you have good dc ground in player 2 joystick.
4.if no picture flip for player 2, go to solution 1.
Thank You.
Jun 15, 2010 | Namco Ms. Pacman Galaga Cocktail Video...
The display screen is gone white on one side! is there any way to fix this?
The problem is from your flex.
A flex is found in Flip phones and slide phones,it is what connects the screen of the phone to the panel of the phone.
What you should do is this;
.open your phone
.you will see something like a little wide plasticlike cable (that is your flex)
.remove it and fix it back properly (be careful) you should hear a click sound
.close the phone and switch it on,you wont have a white screen anymore
if you cant do this yourself,get somebody with a bit of experience to do it for you
If this does not solve the problem then you will have to change the flex
Thank you for visiting fixya
Feb 28, 2010 | Sony Ericsson F305 White +512MB Unlocked...
Car Cassette Adapter keeps flipping from one side to another
This is a faulty firmware problem in the player. It may have a faulty internal capacitor that is screwing up the player. You can use a capacitor tester to find faulty capacitor or replace with a cd player
Aug 24, 2009 | Alpine TDM-7561 Cassette Player
I cant watch dvds on it what wire do hook up to what.
Take the green parking light wire and put it to 1 side of a toggle switch, ground the other side of the toggle switch. Put dvd in wait for warning screen, flip toggle swithc off, then on. You should be all set.
Jul 17, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Cant play All DVD - Band of Brother Has 2 Part on A Single DVD Part 1 Part 2
There is a button labeled FLIP on your remote control. It is on the far right column, and it is the fifth button from the top. It is also the first black button on the remote.
There is also a FLIP button on the front of the unit in the top right corner. It is white. When you push it, it lights up orange.
If the unit attempts to read on side of the disc and fails, it will rotate the carousel 180 degrees and automatically attempt the read the other side of the disk.
May 20, 2009 | Sony DVP-CX860 Multi-disc DVD Player
try hitting the side of your set to see if you can get it to jump out of place. If your can get if to fail by doing this your convergence amps have bad solder joints.
Aug 29, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Tmobile wing..
Hi Samantha
Try and do a soft reset for your device by pressing the reset button on the side of the device "It's a small hole just below the volume slider. You can press it with your stylus pen"
If that doesnt work, you may need to hard reset the device. Note, if u hard reset, you will loose all your data. Make sure you backup all your data before doing a hard reset.
It can be done by holding down the two soft keys on the front of the phone (the soft keys are two buttons with a "-" symbol on them.
To hard reset,hold down the two soft keys on the front of the phone (the soft keys are two buttons with a "-" symbol on them.
Hold those two down, at the same time, while pressing the reset button on the side of the phone. This will erase all data, and restore the phone back to factory condition.
Aug 04, 2008 | T-Mobile Wing™ Smartphone
Flip side is just a a blank white screen.
im having some similar trouble with my razr v3 screen turns white and sometimes it goes off altogether.i thought it might be a battery problem.then i was told it was my wire going to my screen that needed unplugging and plugged back i havent tried it yet.i have to have t6 star tool for that.with all my rambling what kind of phone is yours?so maybe your battery or maybe a loose wiring.forhave to take part of the phone apart. this you
Jul 09, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Samsung UpStage SPH-m620 Cellular Phone Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
