Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Belkin g wireless modem router f5d7634 always disconnect
Why does my belkin g wireless modem router f5d7634 always disconnect every hour? i already turned the firewall off and yet it still disconnects from the internet. the globe led does not turn off but i cannot access any site. so i always have to unplug the router and plug it again or sometimes restart it from the router webpage. please help me. thanks
some settings:
UPnP Enabled
Firewall Disabled
WLAN MAC Address (erased it)
Wireless Enabled
Mode Mixed (11b+11g)
ESSID Broadcast Disabled
SSID Belkin
Channel Auto
Security Enabled
  • mcloving163 Oct 08, 2009
    still disconnecting every hour. i reduced it already to 1400. what is the recommended amount for MTU? already upgraded it to the latest firmware. could it be compatibility issues with the router and my dsl line? any thoughts?
    thanks!
  • 2,263 Answers
Try to reduce the MTU settings on your router.
If possible upgrade the firmware of the router.
Click here for more info about the networking
Posted on Oct 07, 2009
  • Prashant M
    Prashant M Dec 04, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
2 Suggested Answers
govinda123
  • 2263 Answers
SOURCE: why does my belkin g wireless modem router f5d7634
You said that the Internet connection is dropping. It is a modem *** router.
If there is any MTU settings , then reduce the MTU.
For example If MTU is 1500 then reduce it to 1400.
Otherwise you will need to upgrade the Firmware of the router.
Click Here for more info about the networking
We have recently installed a Belkin Surf Modem Router. Since it's installation, we are sometimes having issues sending & receiving email. Internet and wireless connection are fine. We are able to...
HI,
I got your issue, you must make sure the firmware is upto date in your router since in the surf wireless router we have the issue only because of firmware.
Click here to download the firmware.
Update it in the router using a wired computer, if you do it in a wireless comp, connection will be disconnected.
I'm sure this will work.
Good Luck!
Thanks in Advance!
Regards,
Prema.
Dec 27, 2010 | Belkin Wireless Surf Router (F7D2301)
F5D7634 Belkin Router how do I disable wireless option
1. log into the router and click the "wireless" and uncheck the radio brocast.
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Modem-router connection
ur wireless Network remain unavailable cause may be u have kept it in hidden mode... check the settings once again inside the router
If the problem still persistes... reset the router and reconfigure the same.
Jan 06, 2010 | Computers & Internet
Why does my Belkin N wireless router disconnect and reconnects
Turn off the firewall in the Router
Step 1 : Open RSP By typing 192.168.2.1 on the address bar of internet explorer
Step 2 :On the left side click Firewall
Step 3 : Leave the password blank and click submit
Step 4 : Disable it and click Apply
Step 5 : Restart te Router And try a Skype call
Step 6 : If it works let me know at warrierrakesh@ymail.com
Jan 04, 2010 | Belkin Wireless-N Wireless Router with...
Belkin Wireless Modem Router, model F5D7634-4.
If the reset did not help ,i would suggest you talk to the Belkin Support team and get a replacement. Since its a new router, I assume it has an up to date firmware .
Dec 16, 2009 | Belkin (F5D6230-3) Wireless Router
Why does my belkin g wireless modem router f5d7634 always disconnect every hour? i already turned the firewall off and yet it still disconnects from the internet. the globe led does not turn off but i...
Oct 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Sep 14, 2009 | Belkin N1 Vision Wireless Router
Router disconects from modem-Belkin router/Wildblue modem
hi,
try to chk out the firmware of the router. in most of the cases firmware are the major problem for the disconnection of the connection if the device has been purchased a while ago. visit ur belkin website and look for the firmware for your router model no.
if the device is new then try to decrease the mtu size and temporarily disable the firewall of the router
gud luck
thanx and regards
sukhiii
Aug 19, 2009 | Belkin (F5D5231-4) Router
Gaming problems
Try disconnecting your firewall. If you have windows xp operating system, you can disable the firewall by typing firewall.cpl in RUN : which is located in your startbar. then you should disable it. Then you still have your firewall configuration which you need to setup in your router, you need to make sure that all applications can access the internet including your game. I hope this works. :)
just pm me if problem still persists.
Thank you .
Jul 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Random disconnections and pauses, belkin router f5d7230-4
I already fixed it. The firmware was out of date, should had known.
Jul 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
1,983 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
