Question about Air Tools & Compressors
Runs continuously and will not go beyond 25psi
I have a 1hp. 5gal oil bath type and when I plug it in it runs continuously and pressure will not go beyond 25psi
  • 41 Answers
(1) check the air filter
(2) suction valve
(3)if there internal blowing check this also
Posted on Oct 10, 2009
Why does my oil light come on in my 2003 dodge durango even after getting tune up and oil changed?
Your oil light is not a lvl indicator, it is a pressure indicator. If it is coming on you need to verify what your pressure actually is. Get a mechanical gauge hooked to the engine, you should have above 25psi. If not then you will need to go into the engine and figure out if you have a plugged sump tube, bad oil pump, or too much bearing clearance causing your low pressure condition.
Feb 10, 2016 | Dodge Cars & Trucks
What is oil type for my pressure washer pump (K2300G)?
PDF]Service Handbook High-Pressure Washer Pump 3.532-629.0
www.mymowerparts.com/...Pressure-Washer.../Karcher-Pressure-Washer...
Sep 28, 2001 - For Karcher Pressure Washer Parts Call 606-678-9623 or 606-561-4983 .... Oil Bath. The swash plate and pistons are bathed in oil. (oil type ...
Oct 21, 2015 | Garden
Whats oil pressure on 3.1 isuzu
4psi idle (bad) and revving to 3k does what, you didnt say.
what was idle RPM 800 or 400>?
the answer is different by hot and cold oil
and oil type, no type stated (do not say brands) 10w30?
running 0w are you>?
and is as low as 8psi hot. at idle ,that is if idle speed is at spec.
is it?
and 3000 rpm would be like 25psi hot, and more cold.
the max pressure will be the pump regulator value.
here is the sensor spec.
The sensor closes when the oil pressure drops to between 4-7 psi (28-48 kPa).
the oil type and bearings clearances (in total) dictate pressure.
3,1 CPC engine spec is.
Jun 17, 2014 | 1994 Isuzu Trooper
How do I adjust the pressure on front and rear shocks on a 2001 HD FLHTCUI, there appears to be fluid in the lines. Pressure guage shows 55 lbs on dash
Yes there is fluid in the lines it's called oil. and if you're running 55psi it's too much. Let the pressure down to 25psi max you will lose a little oil. When was the last time the fork oil was changed?? If never, the rear shocks mybe garbage by now.
Sep 18, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
Past weekend check engine light comes on, engine sounds and feels fine. However the oil pressure is running slightly slow
Check that the oil level is full.If the oil has been in service for more than 4,000 miles, change it. Replace the oil pressure sending unit. If nothing changes, put a mechanical gauge on the engine and read actual oil pressure. Though "acceptable" low pressure is only 5lbs, I would never accept that as safe. Minimum pressure should be at least 20-25psi and normal running pressure between 35 to 45psi.
How low is "slightly low"?
Mar 22, 2010 | 1996 Jeep Grand Cherokee
I have a Craftsman 3 gallon 1HP air compressor that will only build pressure up to 25psi. The check valve was checked and looks ok. The pressure regulaor appears to be working ok. Bled off tank.The...
Sounds like the compressor has failed -- probably the valve -- tear down and rebuild is probably the solution, or replace compressor, or just buy another unit. My nature would be to tear it down and see what's going on.
Mar 22, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Have craftsman 1hp motor with two capacitors,
you posted this under dryer problems , but i give it a shot. Maby your compressor is out of oil or rings worn out and its to tight to turn under pressure. Or your not getting the voltage or amps you need. You cant run on a extension cord or at least a cheep cord. Your plug is or outlet is burnt not tranphering volts and amps.
Nov 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Craftman 3gal/1hp air compressor runs normal, but
Chek for pressure BEFORE REGULATOR,if the problem remains worn rings or valve seats most likely source of trouble.
Aug 09, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
94 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
