Question about Garden
John deere mower deck belt
I have a john deere g110 with a 54'' mower deck. How do you get the new belt around the tension pulley? Is it suppose to come off. If it is how do you get it off?
    Sergeant:
  • 302 Answers
Try this. unhook the tensioning spring so you can get the belt on and the get some vise-grips on the spring and re-connect it. hope this helps
Posted on Oct 08, 2009
The belt keep jumping off the tension pulley
If the model of deck you have has a belt coming from the engine to a double pulley on the back of the deck you might want to check to see if the bearings are bad on the double pulley. If I had the model of the mower it would help, they make different types of 47" decks.
Jun 02, 2017 | John Deere Garden
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
Jun 24, 2015 | John Deere Garden
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
John Deere L111, belt for deck falls off engine pulley. Seems too big but matches up to a new belt, size-wise. Not sure what to do ?
Yes there should be a belt retainer around the pulley so that the belt is not allowed to pull too far away from the pulley.
Sep 29, 2014 | John Deere 108 111 116 & H L&g Tractor...
I need a diagram to replace belt on a 60 in deck on a John Deere 420
Make a loop with the three drive blade pulleys, the other two are tensioner pulleys, if they are flat pulleys as they should be the back side of the belt rides on these , if they have been changed then use them as tension pulleys anyway you can, hope this helps.
Sep 14, 2014 | John Deere Garden
I need the deck belt routing diagram for my John Deere 185 42" deck.
I fiound some beautiful pictures in a manual for the 48" mower deck by John Deere. I haven't
found the 42" diagrams yet, but I can TELL you how it goes on (or is supposed to). Loosen the sheaves (pulleys) and belt guides. The inside of beltl go on back side of each of th 2 blade pulleys. On the discharge side it will come around to the back side of smaller pulley. On left side it will come to back side of the foward pulley. Then it will go around the jacksheave on the engine shaft. Just remember, th notched side or inside of belt will always go to the v side of pulley and the back side or flat side of belt will go to the flat pulleys. Good luck
Jun 18, 2011 | Garden
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Noise, idler pully rubbing against middle blade
Unless there is some other means of placing tension on the deck belt, I would say that the idler pulley does. If the idler pulley is on a pivot arm, there is a spring that typically is attached to the pivot arm, near the pulley, that attaches to a post or some other part of the deck, that creates the tension on the belt. Check the belt for proper tension.
Aug 01, 2009 | John Deere Garden
Installing mower belt
The pulley at a wierd angle is the tension pulley. You may get the manual on line for free if you are lucky but not all mower manufacturers are that generous. What kind of mower do u have?
Mar 31, 2009 | Garden
Garden Logo
613 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
