Question about Acer Aspire 6920 Notebook PC
Battery meter is low, even though computer is always plugged in
Whenever I unplug my laptop from the power cord and use it without it being plugged in, the battery meter says that my battery only has 5 minutes left and that I should plug in if I don't want to lose my work. The funny part is that I keep my computer plugged in for a few hours before unplugging it, so the battery should be fully charged (and the meter says it's at 100% when it's plugged in). Also,even though the meter says that I only have 5 minutes left of power, I really have more time than that (it'll shut off maybe 30 minutes or so after the warning).
What's going on with my computer? Do I need to replace my battery? My lap top is only a little over a year old.. why would this be happening?
Please help!
    Scholar:
  • 67 Answers
My first reaction would be that you have simply worn the battery out already and it can no longer hold a charge. Discharging and re-charging constantly will do that even in a year. Or leaving it plugged in 24/7 for week at a time can hurt it as well.
Sometimes if you run it all the way down to nothing/as dead as possible and then charge it back up it will "re-train" the battery where dead and fully charged are.
In the case of this battery it sounds like it's just worn out. Sometimes turning off extra features like bluetooth if it has it or the WiFI card along with dimming the screen when possible will get a few more minutes out of it.
I'm going through something similar with my laptop right now. I found a "universal laptop battery" and just carry that around now (amazon is a good place for such batteries). It was only about $30 or so. Sorry it's not good news!
Posted on Oct 07, 2009
    Scholar:
  • 144 Answers
Hi, I recommend you to try refreshing your battery by doing this step for 3 -5 times 1.Make a fully charge it take around 10 Hours. 2.Unplug your adapter and use the battery until it fully finish.Off by itself. 3.Repeat step1-2 for 3-5 times and see it again
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
Laptop wont recharge the battery
Even though you battery appears A OK, it most probably isn't, all one can do is check the power adapter, by replacement, OR trying another one, from some friendly soul, ... and/or replacing the battery,the same way...
Feb 21, 2010 | Computers & Internet
When i unplug it it shuts down even though there is battery life left. It will restart without cord...
It sounds like your battery will need to be replaced.
If the power save features are set for high proformance and the battery is low and will not hold a correct charge, the unit will display those kind of actions.
Sep 27, 2009 | Computers & Internet
When i unplug charger computer switches off
som problem for the hardware.. did you check the programs.. try to re instal the os then connect again the charger into laptop then unplug it.. if the same problem.. check your hardware.. plug in another divice like another charger then unplug it.. to check your charger..
Sep 10, 2009 | HP Compaq Presario V2000 Notebook
My power cord not charging battery
you may have damaged the power input port.
broken solder joint. or your power supply took a dive. if you have a DMM 'meter' check the power supply to see if you are getting power from it.
if it is the power input port, you will have to either open up the laptop and see if it is a fixable soldering job or take it to a pro.
Happy Fixing =)
Jul 11, 2009 | Dell Inspiron 6000 Notebook
Inspiron E1505 - ac power not always on when plugged in outlet
I've had both the battery and the cord die in my old Dell laptop. Assuming it's like mine and the light is on while the battery's charging and turns off when the it's full....
Dell batteries don't last more than a year or two, so my first question would be how old is the battery you are currently using? When a battery is dying, it essentially isn't able to use its full capacity. So in addition to lasting less than an hour or so, it will try to charge for 6-12 hours trying to get a full charge even though it can't. So the light will stay on until it gives up. It will start charging again if you unplug it and plug it in again. If this is the case, you can either replace the battery ($100+ bucks) or ignore it and don't use the battery.
If the power cord is going, it will only work at certain angles. Play around with wiggling and bending the cord (not TOO far though!!) to see if you can get the battery light to shut off when you move the cord in a certain direction. A new power cord/adapter will cost you around $50 I think, if that's the problem. Let me know if your problem doesn't seem like either of these.
Hope this helps and best of luck!
Jun 18, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 8500 no lights, no fan, nothing.
First remove the battery and try it. If it works without the battery, then that is the problem. My Inspiron 2650 suddenly started acting like that with the battery in but works perfectly without the battery.
Whenever you replace a battery ALWAYS let it completely charge BEFORE you try to use the computer with the battery in place.
Do the POWER, DISK ACTIVITY and/or BATTERY CHARGING light stay on?
If so try powering the computer off; unplug the power cord; remove the battery; carefully remove the RAM modules; check the connections for corrosion/dirt; them reinsert the modules; close up the case; plug the power cord in and try powering it up without the battery inserted to further eliminate the battery as the problem.
If you get NO lights or fan noise without the battery installed, you probably have a mother board problem, most likely in the power switch. With the 2650s the switch is an integral part of the motherboard (DELL calls them system boards I believe) and DELL recommends replacing the board. I guess if you can find someone brave enough to work on the board, you could fix the switch because DELL refurbishes them and if the board isn’t working anyway, then you have nothing to loose.
I hope this helps you. Good luck. The 8500s are good computers if you get enough memory in them.
Don Jones
Jan 25, 2009 | Dell Inspiron 8500 Notebook
Battery indicator flashes even when plugged in to electrical plug, computer recognizes plug-in. Computer will not run with power cord.
The battery indicator flashing when plugged in to electrical plug means your battery is completely dead and won't charge. You're computer should run with just the power cord. Your power cord most likely needs replacement.
If you know anyone with the same model of laptop ask if you can borrow their power cord and/or battery to test it out. It is rare for the problem to be the motherboard, though it does happen.
It may just be the power cord at fault as the computer should run without the battery, so you should replace the power cord, as it is probably the reason the battery is completely dead.
If the battery is at least a year old I would replace it since they generally don't last too much longer than a year.
Sep 09, 2008 | IBM ThinkPad T40 2373 Notebook
No juice
Sounds like a battery issue. Try powering up without the battery, just AC. If it powers properly, then the battery needs replaced. If it doesn't then it may be the power supply malfunctioning, or the motherboard.
Jun 19, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 6920 Notebook PC Logo
440 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
