Question about Pioneer TS-A6872R Car Tweeter
Where to find the enclosures for PIONEER TS-A6872R
Where to find the enclosures 6x8" for PIONEER TS-A6872R .I only find 6x9 Thank in advance.
  • 1,147 Answers
Get some MDF board and make them.or buy the 6x9 box cover front with a peice of mdf screwed down good where the speaker will go and cut out a 6x8 hole.
Posted on Oct 07, 2009
Manual Pioneer TS-SW1241D
Hi:
I suggest visit this links:
- pioneer-latin.com/en/operating-manuals/mobile-electronics
- manualowl.com/p/Pioneer/TS-SW1241D/Manual/18391
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 01, 2012 | Pioneer Premier® TS-SW1241D Car Subwoofer
WHAT SIZE AND TYPE BOX DO I USE FOR ONE PIONEER TS-W304C SUBWOOFER
You have a lot of choices for this. First, unless you are tuning the sub to a specific frequency you have options. You didn't specify the size of sub so it's difficult to say specifically, but if it's a 12 inch sub, you need about 1.5 to 2 cubic feet. Of course the performance of the sub depends on the music you listen to. If you listen to rock, pop, classical, or country, I recommend a sealed box. A sealed box gives you better control over your sub. The air acts as a cusion and decreases the return time of the cone to rest position. This gives you tighter bass. If you listen to rap or hip hop, I recommend a ported enclosure. This type of enclosure allows for more cone excursion, thus allowing the sub to recreate lower frequencies. Hope this helps.
Aug 12, 2011 | Pioneer TS-W304C Car Subwoofer
Hi i have a pioneer subwoofer ts-w2501d4 and i want you to tell me the exact dimensions for a sealed enclosure box!!! thanks regards
1.2 cubic feet, tuned at 32hz - 35hz
this will help you alot trust me.
http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
Mar 30, 2010 | Pioneer TS-W2501D4 Car Speaker
I need bow specifications for a pioneer ts-w308f
Hello, The problem with the enclosure is that you purchased a "free-air" sub, which is designed to NOT use an enclosure. You need to simply mount the sub on a baffle (board) that covers the whole entire rear deck of your vehicle, and seperates the inside of the trunk from the cabin of the vehicle. Use sealant to keep the two compartments sealed air-tight and mount the sub on the baffle-board. The other option, is to build a very large box (larger than 3 cubic feet) that would be incredibly huge for the subwoofer, as a free-air, it has a VERY high QTS, and relies on a massive amount of air behind the woofer to allow it to reach low frequencies. The best bet would be to get rid of the free-air sub and purchased a sealed enclosure subwoofer for use in a small (.6-1 cubic foot) sealed box.
Feb 16, 2010 | Car Audio & Video
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Pioneer ts-w3001d4 enclosure box specifications
big red
all you need is about 1 and 1/2 foot deep for relly good bass even better if it is vented
Oct 23, 2009 | Pioneer TS-W3001D4 Car Speaker
What is the optimal volume for a speaker box for two Pioneer TS-W26C sub woofers? I know that enclosure speakers have an optimal volume for the boxes, however, I can not find out what the optimal volume...
try this site very hepfull if you can find all the speakers spec's.http://www.ajdesigner.com/speaker/ajvented.php . if you have the latest pioneer speakers they were designed for small enclosures if you imput speaker code in to google search you should find all the details you need .
Sep 05, 2009 | Audio Players & Recorders
I need the manuals for the following speaker - Pioneer CS-522A
you won't find a manual for speakers. now if you want to specs, you can go to your nearest car audio shop and ask, or you can go to the pioneer site and hopefully get the answers you are looking for.
Aug 24, 2009 | Pioneer TS-A6872R Car Tweeter
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
May 07, 2009 | Car Audio & Video
Pioneer TS-A6872R Car Tweeter Logo
122 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
