Question about Watts Onan Portable Generator - 4000 , Model# 5500
I need a free service manual for an older Onan 4 bge RV generator
5 Suggested Answers
SOURCE: Onan 4000 RV Generator - where is the oil drain plug?
It should have a cover on the floor bottom that is held in place with two torx (star) screws. remove the cover and you can remove the plug with a 9/16 socket.
Posted on Dec 02, 2008
joboo1
  • 257 Answers
SOURCE: onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Posted on Mar 02, 2009
SOURCE: 6.5KW Onan generator. wont run when the start button is released
Flight systems can test the onan circuit boards. google them they will come up. First class operation my board was was checked out and back to me in about a week, They also sell new boards and deduct the 20 dollar bench fee if yours is bad and you buy a replacement from them.
Posted on Mar 23, 2009
  • 12 Answers
SOURCE: Have an Onan RV generator. WHat kind of oil do I
30W
Posted on Apr 30, 2009
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
Free onan generator manual
i have a onan model5.5 HGJAB-1038C GENERATOR IT SHOWS CODE 14 IT WILL START FOR 15 SECONDS AND WILL STOP -- I HAVE REPLACED THE FILTER, NEW FUEL PUMP. NEW SPARK PLUGS- CLEANED CARB AND STILL NOTHING I AM IN MEXICO AND NO SERVICE PEOPLE I NEED A SERVICE MANUEL FOR THIS UNIT--THANKYOU PLEASE
Jan 12, 2014 | Computers & Internet
Onan 7000 watt generator rv starter problems
Can you be more specific than just starter problems?
Jan 17, 2013 | Onan Marquis RV Generator 7000 Watts Gas
I need a manual for onan 6500 lp genset
You can buy a service and or operator manual from advanced-power-technologies.com
Aug 13, 2012 | Onan Cummins RV QG 6500 Generator, 6500W,...
Manuals for Onan 6.5NH-3CR/16004P RV generator
onan mcgraw RV model NH-3CR/1600HP, need to know how much oil,what weight of oil how much etc, the type of spark plug , oil filter, all the specs
Aug 04, 2010 | Garden
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Jan 10, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan genset generator in rv is running but no power to rv...circuit breaker has been checked and main breaker in rv has been checked still no power
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Aug 29, 2009 | Watts Onan Portable Generator - 4000 ,...
6.5 RV Onan generaotr wont kick in when loaded. checked automatic transfer switch and excited it manually, worked one time but never again,
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Mar 08, 2009 | Watts Onan Portable Generator - 5000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
169 people viewed this question
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
