Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
Cannot connect to access point
Can see wireless networks but cannot connect to access points
  • Linksys Master
  • 2,263 Answers
Are you using the Linksys utility to connect to the wireless network?
If you are using that then you can switch over to windows utility.
It is very simple to connect to the wireless network.
Click Here for More info
Posted on Oct 07, 2009
  • Prashant M
    Prashant M Dec 04, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
Canot connect to 192.168.0.50 on a DAP-2695 wireless access point
It is extremely unclear from this what you are trying to achieve and what machine you are on. If the machine you are on is a desktop connected straight to the access point it may not have a wireless adaptor so you may see nothing like that in network connections. Cant comment on setting a static address without understanding why you are bothering with that and not just picking up a DHCP address from the router.
Jul 09, 2014 | D-Link AirPlus Xtreme G DWL-2000AP...
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Slow connection low signal
If a wireless network has low signal strength, the transfer of information across the network could be slow or you might not be able to access certain parts of the network. Here are solutions to some common problems with low wireless signal strength: Your computer is too far from the wireless router or access point. Move your computer closer to the router or access point. If your computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer. If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than the built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna. The wireless router or access point is turned off or isn't working properly. There are two things to try: o Make sure the router or access point is turned on and that the wireless signal light is illuminated. o Reset the router or access point by turning it off, waiting at least 10 seconds, and then turning it back on. If you don't own the access point or don't manage the network, contact the network administrator. There is interference from other devices. If you have 802.11b or 802.11g network hardware, it uses the 2.4 gigahertz (GHz) frequency. Other devices that use this frequency include microwave ovens and cordless phones. If you have 802.11a network hardware, it uses the 5 GHz frequency. Some cordless phones also use this frequency. These devices can cause interference between your computer and the network. There are two things you can try in this situation: o If any devices like these are near your computer, turn them off temporarily or move them farther away. o Change the router or access point settings to use a different wireless channel, or set the channel to be selected automatically if it's set to a fixed channel number. Sometimes one wireless channel is clearer than others. In the United States and Canada, you can use channels 1, 6, and 11. Check the information that came with your access point or router for instructions about setting the wireless signal channel. The network you're looking for is set to not broadcast its network name (SSID). Wireless routers and access points can be set up so that they don't broadcast the network name. In this case, you can't detect that the network is in range (in order to connect to it) unless you've previously connected to the network or you manually connect to the network using the service set identifier (SSID). To connect to a network that's not broadcasting, follow these steps: 1. Open Connect to a Network by clicking the network icon ( or ) in the notification area. 2. Click Unnamed Network, and then type the network information. The network will be added to your list of networks and will be available to connect to in the future when your computer is in range of the network.
Dec 27, 2012 | Computers & Internet
I'm trying to connect another computer to my home wireless network. When editing my profile it asks for the Network name (SSID). What's (SSID?
Improve the Fixya.com experience for everyone by voting!
The SSID (Service Set IDentifier) is a token which identifies a 802.11 (Wi-Fi) network. The SSID is a key which is set by the wireless networkmag-glass_10x10.gif administrator. You must know the SSID to connect to a 802.11 wireless network. However, the SSID can be discovered by network sniffing/scanning. By default, the SSID is part of the packet header for every packet sent over the WLAN.
SSID access points continuously broadcast radio signals which are received by client machines if enabled. Based on the automatic or manual configuration, the client can connect to the access point. A SSID is generally 32 bit long, but when displayed to the user, it is projected into a human readable ASCII format. Multiple access points can possibly share same SSID if they are for the same wireless network. Many wireless access points support broadcasting multiple SSIDs, permitting the formation of Virtual Access Points. Such Virtual Access Points partition a single physical access point into many logical access points, each of which can have a special set of security and network settings.
SSID Security Issues Every user of the network must configure the SSID into their system. If the network administrator seeks to lock a user out of the network, the administrator must change the SSID of the network, which will require reconfiguration of the SSID on every network node. Some 802.11 NICs allow you to configure several SSIDs at one time.
Default SSID's Most 802.11 access point vendors allow the use of an SSID of "any" to enable an 802.11 NIC to connect to any 802.11 network. This is known to work with wireless equipment from Buffalo Technologies, Cisco, D-Link, Enterasys, Intermec, Lucent, and Proxim. Other default SSID's include "tsunami", "101", "RoamAbout Default Network Name", "Default SSID", and "Compaq".
Every time a client connects to the wireless network, the SSID is communicated in plain text format, which can easily be sniffed by eavesdropper using sniffing applications like Kismet. Hence, additional security techniques are required to be implemented in order to enhance the wireless security.
All the best
Ben
Jun 06, 2011 | Computers & Internet
How do i set bridge mode?
Depends if you need a wireless or wired bridge?
Here is some info for you.
Infrastructure Mode
With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
mode provides wireless connectivity to multiple wireless network devices within a fixed range or
area of coverage, interacting with wireless nodes via an antenna.
In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
mobile computing device moves out of the range of one access point, it moves into the range of
another. As a result, wireless clients can freely roam from one Access Point domain to another and
still maintain seamless network connection.
Wireless Bridging Overview
Using Wireless Router as a Wireless Access Point
May 03, 2011 | NetGear RangeMax WPN824 Router
No puedo intalarlo
The Zero Configuration Utility built into Windows XP may vary depending on if you have installed Service Pack 1 or not.
Download Service Pack 1 here.
Without Service Pack 1
Step 1 Right-click on the two computer monitor icons in the system tray and select View Available Wireless Networks.
Step 2 Highlight your wireless network which is the SSID of your wireless network (if you are connecting to a D-Link router or access point it will be default) and click Connect.
Step 3 If you do not see your wireless network in the available networks box click on the Advanced button. Select Add and type in the SSID of your router or access point, uncheck this computer is connected in and ad-hoc peer-to-peer network, and then click OK.
With Service Pack 1
Please read here regarding Service Pack 1 and disabling the SSID Broadcast.
Step 2 Uncheck the Allow me to connect to this wireless network even though it is not secure box. Highlight your wireless network (if you are connecting to a D-Link router or access point it will be default), and click Connect.
How Do I enable Encryption using the Zero Configuration wireless utility?
Jan 18, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
How to use wireless without beinbg plugged in to ether cable
Scan foir the wireless network on the laptop and connect to the network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connect
May 17, 2009 | NetGear WG602 54Mbps Wireless G Access...
Connection to internet through netgear wireless access point
Hmm,,,best I can say then is reset the modem to factory settings and then set it up all over
Apr 15, 2009 | NetGear (WG602MES) 802.11g/b Wireless...
I have a laptop run Vesta trying to set wireless connection to HP Potosmart C4385 print using ad hoc network setup. When selecting Ad Hoc connection in the printer setup it saids it can not find it or...
For this specific issue about installing the printer to a wireless connection. You need to install the software first as a usb connection. After the successful installation of the usb connection then you can add a device and it should work.
Step one: Gather the necessary hardware and information Follow the procedure below before obtaining your wireless network:
  1. Obtain your network SSID and WEP. To simplify this process, press the Wireless button on the all-in-one, and select Restore Network Defaults . This turns wireless off and sets the all-in-one's SSID to hpsetup .
  2. Press the Wireless button to turn wireless back on. Look for hpsetup when you select your network.
  3. Make sure that wireless is enabled on the all-in-one.
  4. Make sure that the computer that will be using the all-in-one has access to the router/access point.
You will need the following to set up the product on a wireless network:
  • A wireless 802.11 network that includes a wireless access point.
  • A desktop computer or laptop with wireless networking support or a network interface card (NIC).
  • Broadband Internet access is required for some features of the HP software to function. Cable Internet or DSL are examples of Broadband Internet access. NOTE: If you connect the unit on a wireless network that has Internet access, HP recommends that you use a wireless router (access point or base station) that uses Dynamic Host Configuration Protocol (DHCP).
  • The network name, or Service Set Identifier (SSID). NOTE: The SSID is obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.
  • The Wired Equivalent Privacy (WEP) key or Wi-Fi Protected Access (WPA) passphrase, if needed. CAUTION: To prevent other users from accessing your wireless network, HP strongly recommends using a password or passphrase and a unique SSID to your access point. Your access point might have been shipped with a default SSID, which can be accessed by other users using the same default SSID. For more information on how to change the SSID, see the documentation that came with your access point. NOTE: The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.Some access points provide more than one WEP key. Use the first WEP key (index 1) when setting up the wireless network.
  • If the network is set up with an Apple AirPort base station and you are using a password instead of WEP HEX or WEP ASCII to access this network, you need to get the equivalent WEP key. See the documentation that came with the Apple AirPort base station for more information.
  • If IP address filtering is set up, verify that the unit address is listed.
  • If MAC address filtering is set up, verify that the unit address is listed. NOTE: HP cannot set up or change the SSID, WEP key or WPA passphrase. This information is required before connecting the HP All-in-One to the wireless network.
Step two: Connect to an integrated wireless WLAN 802.11 network Follow the procedure to connect the unit to the wireless infrastructure network:
  1. Insert the software CD.
  2. Click Install .
  3. Click Next on the Please Allow All HP Install Wizard Processes screen.
  4. Select Easy Install on the Choose Easy Install or Advanced Install screen.
  5. Select Through the Network on the Connection Type screen. Figure 2: Connection Type screen c01160788.jpg
  6. When it doesn’t find your device, click Next . Figure 3: Using Network Setup c01164746.jpg
  7. Plug in your device via USB (it will tell you when to disconnect later). Figure 4: Making a connection to your all-in-one c01160790.jpg
  8. Select your network from the list, and click Next . Figure 5: Wireless Network Setup c01160791.jpg
  9. Enter your WEP key (if applicable). Figure 6: Specifying your network security settings c01160792.jpg
  10. Once it has completed connecting to the network, click Next . Figure 7: Network connecting completed c01160793.jpg
  11. Disconnect the USB cable from the computer and the All-in-One . Figure 8: Disconnecting the USB cable c01160794.jpg
  12. Click Finish to complete the software installation process. Figure 9: Software installation complete c01160795.jpg
Aug 04, 2008 | HP Office Equipment & Supplies
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER stopped working
What are you trying to connect your USB wireless device to?
Is it to a wireless hot spot?
or to a Wireless Access Point/Router?
When you find a connection, what is the signal strength?
I assume you have configured your Access Point correctly as well as making it secure. You should connect a computer to the Access Point using a network 10BaseT cable to check the Access Point configuration, especially the wireless configuration.
If you are trying to connect to a wireless Access Point and you have a weak signal, move your computer closer to the Access Point or move the Access Point to a better and higher location to give you a better wireless coverage. Note, walls can affect the wireless signals between the Access Point and the wireless network card and wireless USB device, especially reinforced concrete walls.
Jun 01, 2008 | Computers & Internet
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
397 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
