Question about Mitsubishi Heating & Cooling
Mr Slim - MSZ-A09NA quits - error light blinks every second after every rain. The circuit board, I understand 2 different ones, replaced more than once. Sometimes after a period, unit will operate normally - as if something dried out. Circuit breaker tripped twice but unit stopped several times. Any ideas? (I have 3 of these, only one has the problem)
watugot
  • 290 Answers
SOURCE: Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Posted on Nov 20, 2007
  • 124 Answers
SOURCE: York Air Handler trips main circuit breaker
almost has to be the electric heat strip coils. they usually come on in stages. when the damaged strip comes on it kicks breaker. turn off all power, check with a meter , gently remove strips and inspect for broken or shorted coils. usually best to buy a new heat strip module. they are usually held in place as a module with 4 screws and a snap together wire connector .good luck. i have had some success if the wires are broken and not to brittle by bending a minute loop in the end of each wire and reconnect with the tiniest screw and washer and nut you can find, i'm talking real tiny. about the size of a bb if you can find em , or you can remove the damaged strip wire entirely to get some heat from remaining.
Posted on Nov 23, 2008
SOURCE: will not blow cold air
pls check your remote setting
Posted on Apr 27, 2009
co7196
  • 3433 Answers
SOURCE: Hi,
Moisture/ water is getting into the electrical. Locte exposed connectors or wiring and protect from water and moisture.
Posted on Jun 09, 2009
icemelts
  • 246 Answers
SOURCE: Air Conditioner trips the 110v breaker, only when
'Breakers' - are tripped because they are exceeding their amp limits.
The 'hotter' it gets outside - the 'harder' your AC has to work - and under normal circumstances this is not a problem - but when you have a fan motor or a compressor that is starting to 'break-down' (electrically) - often the AC's amp draw will exceed the limits of the breaker - thus 'tripping' the breaker.
I would suspect either the fan motor or the compressor is causing your breaker problem.
Eventually - the component (either the fan mtr or compressor) that is 'going bad' will go out completely and your breaker will 'trip' and not stay on when you try to reset it.
At this point you will need a Service Tech to determine which one is bad.
There is a possibility that your condenser coil (the one that blows hot air) is 'dirty' which will also cause a problem similar to the one you have - but it is less likely.
Also - if you've had the AC 're-charged' lately - it's possible you are in a 'over-charged' condition - but again, this is not very likely.
hope this helps.
Posted on Jun 12, 2010
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
How do I clean Mr Slim MSZ 24NA
usa.mylinkdrive.com/.../MSZ-MSY-A09-24NA_GA24NA_Service_OB
Sep 19, 2014 | Mitsubishi MSZ-GE24NA Mr. Slim Wall...
Mr slim msz geo9na heat pump
If you have no fault codes...check the batteries in the remote. Make sure the remote is synced with the air handler.
Dec 17, 2013 | Heating & Cooling
I have Mr. Slim MSZ-GE09NA-8. I have four of these units in different rooms. All but one if functioning properly. The malfunctioning unit is in my office; it will turn on and run for about 45 seconds, then...
try running the unit in the fan only mode. if problem persist this will insure it's an indoor problem. also turn all 3 other systems off and only running problem unit. narrowing down is key
Oct 28, 2017 | Mitsubishi Heating & Cooling
Hi - I have a MR SLIM MSZ A09NA HEAT PUMP. It is dripping inside the room. It was installed in 2008. Is seams to be loose on the wall. Is it supposed to be level? tipped to the right ?
An air conditioner should be installed so it's level. These appliances are designed so that condensate collects below the fan and runs into the slinger ring, which is made of sheetmetal and is part of the fan assembly. The bottom of the ring acts like a gutter to collect condensate. The fan then picks the water out of the ring and slings it against the condenser coils.
Recycling the condensate in this manner increases the coils' cooling capacity. Check the air conditioner for level -- front to back and side to side -- when you install the unit.
If it is tipped a little to the Front then you will Get water inside room.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have 2 of the MSZ-A09NA Mr. Slim model in my 400 sq. ft. cottage. In the summer time my cottage is always damp feeling and the ducts drip condensation. How do I prevent this dripping?
It sounds like you have too much air conditioner vs. conditioned space. This would cause dripping and short run times. Air conditioners are designed not only to cool the house but to pull the moisture out, if it is too big and cools the area too fast the outside of the ducts will begin to collect condensation like the outside of a cold glass of water.
May 04, 2011 | Mitsubishi MS09TW Air Conditioner
Will not blow cold air
Apr 27, 2009 | Heating & Cooling
Heating & Cooling Logo
122 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
