Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Not make ice, not cold? please help? is this a problem with thermostat
    Sergeant:
    Champion:
  • 257 Answers
I am not a expert just trying to help,,try cleaning the bottom of fridge of dust cause dust can cause the fridge to heat up,, make sure to clean all under the fridge pull out and take plate off to clean ,, hope this help you
Posted on Oct 07, 2009
HAVE GE PSS26MSRSS SIDE BY SIDE THAT WILL NOT FREEZE COLD ENOUGH OR MAKE ICE
Hi , you probably need a repairman to check the freon level and test the thermostat
Jun 19, 2015 | GE Refrigerators
Won't make ice in cold weather
Check the thermostat of your Ice maker whether it is in working condition or not. For More information please visit GE Ice Machine Cleaner.
Nov 08, 2012 | Manitowoc 1400 Modular Ice Machine Sd1492n
Refrigerator is not getting cold
There is a small fan, behind an inlet panel, somewhere in the freezer. This fan is electrically inline with the refrig side thermostat. The refrig gets its cold from the freezer as needed via this fan. It is likely that the little fan motor has gone out. Usually when the freezer is working ok (although it can be "spotty" because its not getting proper circulation either with some models), but the frige is not getting cold -- it is because either this little fan motor has gone bad, or the thermostat it is inline with.
If you have a multimeter, you can check to see if 115 volts AC is being applied to the fan motor. If it is and the fan is not spinning then the motor is bad. If there is a lack of voltage, then the thermostat is bad. The thermostat sits behind the control knob for the refrig.
Good luck with it. If this has helped you, please take a sec to rate me. Thanks!
Don
Mar 18, 2012 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Fridge and freezer doesnt seem cold enough. Things are cool but not cold. Ice cream is not as hard as usual (soft but not melted). Ice maker not making ice. Adjusting thermostat doesn't seem to make a...
Please check the timer the thermostat and the heater for the auto defrosting to work. Switch off the fridge and after all the frost has gone off switch on to see if the sooling returns . If so you can be sure that the timerr does not work and so reduces cooling on frosting. If there is still no cooling then you will need to check onthe compressor and the gas pressure. Get help to confirm and take an estimate before attempting, get an warranty assurance for work. Hope you try out and see first.Good day
Aug 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge is not cooling enough
I had the same problem. Freezer at the top and Fridge below it? In the back of the freezer is the evaporator. It is the thing that supplies the freezing air. Some of that cold air is channeled into the fridge. On mine, the defrost thermostat had failed and my evaporator was a solid block of ice. The engineer fitted the thermostat in 5 minutes and took an hour to defrost the ice with a heat gun.
Being on maximum doesn't help of course. The other possibility is that it has a refrigerant gas leak and needs recharging. You need an engineer.
Oct 23, 2017 | Frigidaire FRS6R5ESB
Kenmore refriderator Model # 59658632890, its stopped getting cold, we emptied the fridge waited 3 days plugged it back in after 24 hours it got cold, made ice and then got warm again. Help.
hi it is a thermostat problem.,,,,
som heating is done by thermostat...it is not working properly,,i think u should check ittt..
thank u..please rate it/..
Jul 01, 2009 | Kenmore 15358
Commercial freezer (Randall) with a Ranco thermostat, not cooling
clean condenser? is evaporator free of ice? may need defrosting or low on freon. Tom
Jun 30, 2009 | Freezers
ICE MAKER GETS COLD-DOES NOT PRODUCE ICE
Hi
Try turning the thermostat to a lower setting. (warmer) It might be set too cold and the thermostat isnt being satisfied. Usually this is all thats wrong with it. Temperature in bucket between 10-15 degrees.
Jun 08, 2009 | U-Line Icemaker
Refrigerator and Freezer are not cold enough
sounds like your fridge is iced up.To cheak this you will need to remove rear panel in freezer compartment and cheak if there is ice buld up.If so you may need a defrost timer or your drain tube may be plugged..If those are fine cheak if your defrost thermostat is ok and not split.Hope this helped:)
May 20, 2009 | Refrigerators
Fridge and freezer not cold
hiya
sounds like there's a thermostat problem.
hope this helps
please dont froget to rate the helpfulness of this reply, thanks kj
Jul 16, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
