Pilot light wont light & thermostat keeps saying low battery even after I put new ones in it
  • 80 Answers
Double check direction of batteries and test batteries to make sure they are good. If so, time for a new stat.
Posted on Oct 07, 2009
I have a magic chef furnace, armstrong series if the pilot light and ignightor both work but the burners wont light is it possible the thermocuppler bad?
The thermocouple keeps the pilot light on. If the flame blows out it shuts off the gas to the pilot lite only the board that has the igniter on it supplies power to open the main burner as long as the igniter is operating. Sounds like the gas valve is nor working.
Nov 19, 2014 | Magic Chef Refrigerators
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
Pilot light wont stay onfor outside pool heater. gas co made a service call & relit the pilot light, it went out again 4 days later.
Thank you for posting your question here on Fixya.com.
Has anyone replaced the pilot generator yet? A millivolt heater (one with a pilot light) requires about .75 volts from the generator to operate. As the generator ages it puts out less and less voltage and eventually gets to weak to even hold the pilot gas valve open. Replacing it with a new generator will usually fix the problem you describe.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 17, 2010 | Pool & Spa
No hot water
pilot may be blocked therm/coupling may need replaced
Oct 09, 2009 | Bosch Water Heaters
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
Frymaster gf 14 won't come on
Ok sounds like your problem maybe that the gas valve is set to low. If you have access to a manometer you can put it on the outflow port of the gas valve and see what the reading is. It should be at 4" water column for this fryer. You possibly might even have a faulty gas valve, these will go out sometimes and still let the pilot bypass maintain regular operation. Please comment me back if you need more assistance with this.
Thanks
Jul 14, 2008 | Frymaster Dean FM345EETC Deep Fryer
Digital Camera
wont take pictures and wont show and display
Nov 16, 2007 | Polaroid a300 Digital Camera
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
