My Mackie SRM450 appears to have a faulty volume pot. I have to tweek it in both directions several times and then it may come on but it's not reliable. I can relace the part myself but am unable to seperate the heatsink from the cct board. Any hints...??
Inside the amp, on the back side of the circuit board is a tony Black Plastic "Jumper" with a "pull tab" on it.
If the pins have lost their 'straightness' from dropping the speaker or rolling it around in the van, the Jumper may be intermittently making contact.
Of course when full voltage is applied via the volume knob, there is enough to "connect" the jumper sleeve temporarily.
When you turn the volume back down, this repeates the cycle.
All you need to do, is remove the entire amp panel on the back, locate the "Jumper" (near the Volume Pot on the circuit board), straighten the pins, "clean" and inspect the jumper for "loose contacts" (very tiny parts in there!), and make sure it re-seats firmly.
This should solve the problem. If not, I would investigate a crack in the circuit board, etc...
Posted on Nov 19, 2009
  • Audio Player... Master
  • 5,151 Answers
It may be just dirt. Try spraying it with either Super Servisol Switch Cleaner or Servisol Video 40.
Both can be found at Radio Shack (USA) or Maplin (UK).
Posted on Oct 07, 2009
Mackie srm450 v2 no top end.
Check the aspect of the crossover filter for the speakers, inside. Sometimes they fry.
Apr 14, 2014 | Mackie SRM-450 System
Blown Mackie srm450 woofer makes sound but rattles when turned up
I need more information, but some similar event i remember with SRM450 and was the paper cone on the speaker, not visible from outside but inside was severely cracked all round, hope this helps.
Apr 23, 2012 | Mackie SRM-450 System
What size internal fuse on mackie srm450v2 speaker
Mackie say this is not a user service part. If the fuse has blown there is probably a fault in the unit being their reasoning. I know for certain they tend to blow for no apparent reason so it is worth giving it a go. They are 5 x 20 Slow or time fuses. 7A for 120V and 4A for 230V
Jul 13, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
Hi; My mackie srm450 is not giving bass anymore what can I do to repair it ?
FIrst of all this is not a repair site per se. We help by providing information that you may require to repair something.
For your specific problem, there can be many causes. The speaker itself can be defective, the amp may be blown or the crossover could be malfunctioning. Without seeing the actual unit, I cannot possibly know which is the case. These are decent units and rarely fail in this manner. In my experience, the likely problem is the speaker itself. You can contact Mackie directly for a replacement. If you have an ohmmeter, disconnect one of the speaker wires and measure across the speaker terminals. You should read either 6 or 3.6 ohms. If you read infinity, the coil is open and the speaker must be replaced. If you feel that you cannot attempt this repair, please update this with your location so I can suggest a repair facility close by.
Thanks,
Dan
Apr 12, 2011 | Mackie SRM450 PA Speaker
When turned on: srm450 has no sound, but all leds (power and signal) is normal. If I turn the volume up (near maximum) , the srm450 sound is activatet again , and peforms normally. I then turn volume down...
1 TAKE THE MAINS PLUG OUT
2 Unscrew the fixing screws on the back. (just the outside ones)
3 Take the back off and turn the amplifier circuit board to face you.
4 About 2" from the left and about 4" from the bottom you will see a sort of tab. pull it off gently and widen the 2 prongs slightly.
5 Put the jumper tab back on and re fit the amp.
Dec 26, 2009 | Mackie SRM-450 System
We use a mackie dfx 12 mixer and 2 mackie srm450 active speakers for a band situation the mics are sure sm58s we have to keep the levels of each cannel mixers quite high what are we doing wrong
Does the VU-meter (green/yellow/red strips of LEDs) on the mixer go all the way to the top when you adjust gain and slider level?
If yes, try boosting up the active speakers by adjusting the small volume button at the back of the speakers.
Also, make sure the equalizer (on the mixer) is set at 0 (the middle) for every slider (And not at -12). The 'voice cancellation' and 'break swich' should also both be unpressed.
Dec 13, 2009 | Mackie SRM-450 System
Repair a Mackie SRM 450 Speaker The Speaker is making a crackling sound while playing. The sound keeps cracking up.
You probably need to replace the diaphragm. The diaphragm is located behind the back cap. Simply remove the back cap, remove the diaphragm, clean the voice coil gap with a piece of masking tape, install a new replacement diaphragm, reinstall the back cap. That it!
You can see videos on how to replace diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-c/INST/Installation+Instructions
You can buy a new Mackie SRM450 diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-cp/SRM450-DIA/DIA-Mackie/Mackie/
Jul 20, 2009 | Music
335 people viewed this question
 Grubhead
Grubhead
