Question about Maytag Washing Machines
I have constant HOT water even on cold cycle - Maytag Washing Machines
  • 31 Answers
Are you sure? the so called cold water is approx 70 degrees. and even on cold, it periodically mixes with warmer water.
Posted on Oct 07, 2009
The coils on my w64 are very hot and the machine display will not light up
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
Mar 04, 2015 | Wurlitzer W 64
ENGEL STILL GETS COLD BUT RUNS VERY HOT AND USES MORE POWER
FRIDGE COILS SEEM VERY HOT:
You can check that all fans are running.
Feb 27, 2015 | Engel MT-35F-U1 34 Qt Portable...
Door rubbers heating up to much
FRIDGE COILS or door walls SEEM VERY HOT:
The refrigerator should not run constantly but shut off with each defrost cycle.
Dec 25, 2014 | Samsung Refrigerators
Out side gets really hot why?
Jun 30, 2014 | Kenmore Refrigerators
My Frigidaire front load washing machine feels warm/hot even when I chose the cold wash cycle. My clothes are even hot at the end of the cold cycle.
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
Jun 08, 2010 | Frigidaire ATF6000ES Front Load Washer
The cold water is constantly running in the machine. It runs through all cycles and even when the machine is off.
Water fill valve is bad. This is where the hot and cold water connects to back of washer. Common problem, gets loaded with sediment
Dec 29, 2009 | GE WBSR3140DW Top Load Washer
Cold water constantly runs even when the knob is pushed in to turn washer off.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing. The cold side can fail independently of the hot side.
Oct 14, 2009 | Frigidaire FWS833A Top Load Washer
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Hot water goes into cold water washes
Jan 12, 2009 | LG WM-1832C Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
